Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 09-21-2009, 02:51 PM   #176
scramjett
Member#: 192526
2008 WRX FMIC/VF48
Red/Steel Grey
Originally Posted by Tuned200 View Post
This thread is for the VF48, not the VF39 or VF43.
They're all the same... Now then, if it were a VF30/40/46, then sure I can see your point.
scramjett is offline   Reply With Quote
Old 09-21-2009, 05:08 PM   #177
BVM
Member#: 41049
2004 Subaru WRX STi
MASE tuned
PWN3D
Why do you think I posted my results here? Cause I have a VF48!
BVM is offline   Reply With Quote
Old 09-22-2009, 09:04 AM   #178
Tuned200
Member#: 127740
2007 Forester XT
VF48 PnL Tuned
Not really the exact same. But close, hence the VF48 thread, There is a vf39 thread, so this is for those of us who use the newer turbo.
Im sorry, I saw your car was a 04 STI and could not grasp why someone would swap the 39 for the 48 when the gains are min. Again, my bad.
Back on topic.
Tuned200 is offline   Reply With Quote
Old 09-22-2009, 07:01 PM   #179
BVM
Member#: 41049
2004 Subaru WRX STi
MASE tuned
Because my VF39 was cracked and I got a replacement for it (VF48) new for $600.
Old 11-02-2009, 07:14 AM   #180
shatteringstar
Member#: 149604
2006 Limited WRX
bump b/c i like this thread and it needs more posts.
shatteringstar is offline   Reply With Quote
Old 11-03-2009, 09:06 AM   #181
scramjett
Member#: 192526
2008 WRX FMIC/VF48
Red/Steel Grey
Can someone post their 3rd gear pulls to redline?
Old 11-03-2009, 03:48 PM   #182
Tuned200
Member#: 127740
2007 Forester XT
VF48 PnL Tuned
I would but it would be an auto, so bump for a manual 3rd gear pull.
Old 11-06-2009, 03:02 AM   #183
shatteringstar
Member#: 149604
2006 Limited WRX
video, dyno, or what?
Old 11-06-2009, 02:45 PM   #184
Squillo
Member#: 193400
02 Subaru WRX
mbp
oops double post
Squillo is offline   Reply With Quote
Old 11-06-2009, 02:48 PM   #185
Squillo
Member#: 193400
02 Subaru WRX
mbp
hey guys im trying to do a vf48 build in my 02 wrx this spring im aiming for 280-290 whp with 20 lbs. of boost, i plan on running
vf48
08 sti 560 injectors
255 fuel pump
fmic with hks ssqv bov
gms turbo inlet and after maf hose
short ram intake
full catless exhaust
lightned crank pulley
and im thinking about tgv deletes and the intake spacer.
My question is will these injectors do the job or should i look into 650cc i dont plan on going bigger and was told the 560 are fine. Also are the tgv deletes and the intake spacer worth it? And are there any other little parts i should think about getting i have a mbc i can use and i see a lot of people using the ebcs from grimmspeed.
Old 11-07-2009, 01:20 AM   #186
shatteringstar
Member#: 149604
2006 Limited WRX
560cc injectors will work but thier duty cycles will be high. i think u'd be off with bigger injectors if u can afford'em. IMO, tgv deletes and the intake spacer go the same way... if u can afford them go for it. all that little stuff adds up
Old 11-07-2009, 01:32 AM   #187
Squillo
Member#: 193400
02 Subaru WRX
mbp
^^^ thanks and im sure the 560 would be fine but i saw a guy with a 2.0 with a vf39 set up and he had some nice numbers like 282 whp but he had 650cc at 97%. What decides what size injectors you need?
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 07:39 PM.
