Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 10-17-2009, 01:12 PM   #1
RR-racing
Member#: 41632
2004 Spec C
WRC blue
Default Mixing Methanol and Gasoline
I tried searching but did not find much.
Anyone have any success in mixing say 25% methanol in pump gas??
Should give effective octane of about 103 in 93 pump gas...
I wouldn't think that there would be a problem with seals or lubrication in the cylinder as you are still running 75% gasoline.
I am not sure if it would be more or less corrosive than E85?
Rafi
RR-racing is offline   Reply With Quote
Old 10-18-2009, 12:29 PM   #2
Ultimate Collision Center
Member#: 69072
The problem arises with having inconsistent amounts of methanol:gas with a setup like this.
Ultimate Collision Center is online now   Reply With Quote
Old 10-22-2009, 12:07 PM   #3
RR-racing
Member#: 41632
2004 Spec C
WRC blue
Why would amounts be inconsistant... we are talking basic math here?
Rafi
Old 10-22-2009, 12:17 PM   #4
silversubiedude
Member#: 182010
2002 slow wrx
psm
Not 100% sure on this but I do know myth is very carosive and could damage your fuel system.
Theres nothing better than straight race gas 109 octane is only like 3 dollars more per gallon than myth. But of course that changes daily. Last I herd it was about a month ago and it was $9 per gallon.
silversubiedude is offline   Reply With Quote
Old 10-22-2009, 01:55 PM   #5
Phatron
Member#: 36033
02WR X HTAGreen+Meth
06 STi OG Green + Meth
I was just going to start a thread on the exact same thing.
All i came up with from some google reading is that meth is corrosive.....but really didnt say what parts it would damage.
Since meth injection kits spray into the throttle body i dont think it could be anything in the motor.....
So its probably just the tank and/or fuel pump that may get damaged.
My question was gonna be "whats the difference between running e85 and straight methanol?"
Old 10-22-2009, 02:27 PM   #6
Murphdog
Member#: 75414
2004 STi
I would think over time it would eat away any rubber seals in the fuel system that it makes contact with. I'd say the pump and regulators would see damage if it were used consistently.
Murphdog is offline   Reply With Quote
Old 11-05-2009, 01:39 AM   #7
RR-racing
Member#: 41632
2004 Spec C
WRC blue
It is true that E85 is much more practical than M85 because Ethanol is much less corrosive than Methanol.
But I am not talking about running 85% methanol.... just 10-20% as an octane booster.
10% should be fine, not sure how high you can go though or what the solubility of methanol in gas is.
Where I am from, methanol costs about 40% less than premium gas.
Rafi
Old 11-05-2009, 03:16 AM   #8
Iron Giant
Member#: 174780
2005 Impreza WRX STi
WR Blue
If you want to make an octane booster use Toluene or even Xylene. You can use Methanol, but the amount needed to significantly bump up the octane is enough to eat the fuel lines. Here is a nice table with different ratios and ingredients-
http://www.gnttype.org/techarea/misc/octanebooster.html
Iron Giant is offline   Reply With Quote
Old 11-07-2009, 02:35 AM   #9
RR-racing
Member#: 41632
2004 Spec C
WRC blue
I know... I have used Toluene up to 30%, it works. In fact, I have a 200 liter barrel of the stuff in my garage, but methanol is much cheaper.
Rafi
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 07:50 PM.
