Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 09-15-2009, 10:11 AM   #401
Mechie3
Member#: 120152
2006 WRX, ESP 92
CNY Overall Pax Winner!
Yeah, just put some smoke tint in front of the gauge face. Only downsides are: potential for th needle to snag and the lights must be on to see the gauges at all. Alternatively, you could try using a VHT smoke paint. Not sure how well either will really work.
Old 09-15-2009, 02:58 PM   #402
je255j
Member#: 202284
Originally Posted by ProDriven Auto View Post
Just a couple of months ago we did GC8 Cluster in Hyper White. Came out GREAT.
MAN, that looks good! I can't wait until you're able to do that to my '09 OBS.
je255j is offline   Reply With Quote
Old 09-17-2009, 12:50 PM   #403
Interior Flair
Member#: 208601
2005 STiw/RED LIGHTS
Originally Posted by Mechie3 View Post
Blue is pretty much a no go. It will always come out looking teal.***********
Not necessarily true. If you add enough intense blue lighting it will eliminate the teal affect.
That is why our blue 05-07 climate control conversions are $65. We add two more LEDs per knob for a total of 5 super bright LEDs per knob. The result is pretty good:
Interior Flair is offline   Reply With Quote
Old 10-07-2009, 12:20 PM   #404
DerickRyoung
Member#: 178050
02 wrx
psm
all of these pictures show the check engine light and others...is this b/c the cars are not on or are all of the lights on all the time??? Just curious...I was hoping all of the cars are turned off? I am really interested in this mod...
DerickRyoung is online now   Reply With Quote
Old 10-20-2009, 06:42 PM   #405
boostin23
Member#: 204172
---- WrX
i sifted through the first 3 or 4 pages... did anyone do a STi cluster? Ive got an 05 STi cluster and think i want to turn it blue and put it on my 03 wrx
boostin23 is offline   Reply With Quote
Old 10-21-2009, 03:21 PM   #406
Mechie3
Member#: 120152
2006 WRX, ESP 92
CEL is because key is in, car is off.
I have not done an STI, not sure if the pro's have. It's a bit different stock setup.
Old 11-05-2009, 01:24 PM   #407
Spliffnugz
Member#: 224514
2007 Impreza 2.5i
Urban Grey
you still doin these for people? If so how fast and how much can you get it done for?
Spliffnugz is offline   Reply With Quote
Old 11-07-2009, 03:32 AM   #408
Exarch
Member#: 208321
2007 WRX TR
For what it's worth, I had the blinking/dead LED problem in my cluster.
I deviated from the DIY in terms of LED's, I picked up Digikey part number 67-1691-ND. These LEDs are made by Lumex and are terrifically bright at 3500 mcd. They have a 3.4v voltage drop, so when working with series circuits containing four of these, they can be hooked up to the car's power with no risk of cooking them.
Fast forward a bit, the LED's worked fine for a while, but eventually one of the circuits began blinking with the blink slowing over the course of a few days to the point at which it was dead entirely.
Removal showed that the third LED of each circuit appeared burnt with the visible light-emitting medium taking on a brown tinge. Testing showed that the burnt looking LED would blink with power applied, but the rest were fine.
To combat this, I threw two 1000 micro-ferad capacitors in series to provide some AC filtering, noise filtering, and general power smoothing.
I replaced the burnt LEDs on all of the circuits, and have been running the lighting now for several hours a week of driving with the power filtering capacitors in place with no problems.
I will make a rough sketch of my circuit and throw it up as it's easier to see. At some point I will also upload the pictures of my build and post them here.
Color wise, I started out with a VW-esque 485nm light filtered using Rosco 2008 gel. One layer of the gel was insufficient to give it the right deep color, so I doubled up. The problem with the gel only having 7% light transmission compounded nicely to leave me with some very hot-spotted gauges. In addition, the Rosco 26 light red I had picked out for the redline was problematic. Not in color, the color came out perfectly, however from certain angles, the light would appear to "bleed" between the numbers and the red-colored hash marks. This was unacceptable, I would rather have a purple redline than a red one with purple bleed.
I was going to trim so that the tach's numbers past the redline would have red gel behind them, but figured that would compound things as the numbers and the red-line itself would be two different colors.
Instead of continuing to cut out endless sets of gels for the cluster, I caved and threw in forms cut from Rosco 121 diffuse blue, which is a diffused blue sheet of slight rough texture, and is incidentally a perfect color match for the blue of my Alpine iDA-200 media deck.
For the LCD screens, I flexed the screen away from the housing and yanked the green plastic filters, replacing them with similar size pieces of Rosco 120 red diffusion gel. I cut the gel slightly larger than the recovered piece of green plastic to help it sit flat against the back of the LCD. After a good bit of fighting with them with the LCD's flexed forward away from their housings, I finally got them to lay flat...
Last but not least, I used one of the sample gels from the Rosco gel swatch book to find a pink that roughly mimics the STi pink on the STi cluster, and placed that behind the "IMPREZA" at the bottom of the tach.
So far so good, I should really get some pictures of it in action!
Next up will be the HVAC controls by somehow cavorting flat gel into a suitable bulb condom...
Exarch is offline   Reply With Quote
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 09:01 PM.
