Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 07-09-2009, 01:12 PM   #126
KitchenerWRX
Member#: 79934
2002 wrb wrx
6spd, vf39, 44mm ewg
2002 Subaru WRX (sedan)
4.0 F / 4.5 R *Break in only*
RCE yellows (+scooby strut spacers) ; spring rate: 295f / 275r (lbs/in)
Group N F & R tophats
Other noteable suspension: Cusco adj rear-sway @ 23mm setting with Group A endlinks, subframe lock bolts, rear adjustment arms
17x7.5 w/ Bridgestone RE070s
Alignment specs
-1.8 R both sides
-1.6 L both sides
*stock camber bolts*
0 toe all around
Just got the d-specs installed with rce yellow springs, and it is a NIGHT and DAY difference from the oem blown shocks + eibach pro-kit lol. After alignment was done last night, Im even more shocked at how well it handles!! I cant wait for it to settle and break in so I can go 3.5 F and 4.0 R and give that a shot! Will keep you guys posted.
KitchenerWRX is online now   Reply With Quote
Old 07-22-2009, 09:37 PM   #127
trick3d
Member#: 202146
2006 Impreza WRX
Default D-SPECS Tomorrow, YAY!
Tomorrow my friend and i are installing on my 04 wrx sedan:
D-Specs
RCE Black Springs
Scooby Spacer
Stock Tophats
I cant wait
trick3d is offline   Reply With Quote
Old 07-23-2009, 01:17 AM   #128
SubySal
Member#: 43011
2004 Impreza RS
PacificaBlue/BlackTarmacs
D-Specs
RCE Black Springs
Scooby Spacer
Stock Tophats
I cant wait
ooo... take a pic if you can. You have the same MY as me and I'm thinking of upgrading from my Prodrives to some stiffer RCE blacks. It'd be nice to see how an 04 sits on those springs.
SubySal is offline   Reply With Quote
Old 07-23-2009, 01:12 PM   #129
trick3d
Member#: 202146
2006 Impreza WRX
Default Yay
Yeah I sure will. supposedly it will drop it something like 15mm front and 10mm rear. I will have some pics posted tomorrow.
Old 07-24-2009, 05:55 PM   #130
Sir_Xenon
Member#: 9666
02 WRX
WRB, COBB Stage 2
Great thread people. what alignment settings would go on an 02 wrx with 04 STI springs and D-specs? (I've searched)
Sir_Xenon is offline   Reply With Quote
Old 07-26-2009, 09:05 PM   #131
trick3d
Member#: 202146
2006 Impreza WRX
Default Type of Driving?
I think it mostly depends on what type of driving you will be doing. so...?
Old 07-26-2009, 09:19 PM   #132
Sir_Xenon
Member#: 9666
02 WRX
WRB, COBB Stage 2
"aggressive" street + mountain road carving, couple of track days. It's not an everyday driver so I'm willing to live with performance over a bit of comfort.
Old 07-27-2009, 07:33 PM   #133
sr20dehauler
Member#: 98950
2005 Subaru FXT
1992 Nissan SE-R
Originally Posted by poison View Post
Anyone running Prodrive Red's on these?
I have the same question.
sr20dehauler is offline   Reply With Quote
Old 07-30-2009, 08:15 PM   #134
trick3d
Member#: 202146
2006 Impreza WRX
So last thursday my buddy installed the Tokicos and RCE Black Springs. First impressions at the 5f 5r setting was amazing. I had a completely stock suspension before the install so large gains in handling were immediately noticed. It took about a week to pass the 500 mile break in and last night I adjusted the settings to 4 turns from full FIRM in the front and 3.5 TFFF in the rear. I haven't taken it through the canyons on these settings but so far it seems pretty stiff for a DD so Im going to back it off to 4.5 TFFF in the Front and 4.0 TFFF in the rear. I have been really impressed so far with the RCE Black springs and their progressive nature. The drop was a little less than I wanted but its great because I dont scrape on anything. The Adjustment Extenders in the Rear are AMAZING.
2004 WRX Sedan
Tokico D-Specs @ Front: 4.5TFFF Rear: 4.0 TFFF Rear
RCE Black "Regular Guy" Springs Front: 285 lbs/in Rear: 265 lbs/in
Adjustment Extenders for the Rear
Stock Top Hats
Scooby 921 Spacers
No Knock
Alignment
Camber Front: -.5 Rear: -1.5
Toe 0
Future: What would be the best next upgrade, Group-N Tophats or Sways? Currently both parts are stock.
Old 07-30-2009, 08:49 PM   #135
viper74656
Member#: 84758
'04 WRB WRX
2004 WRX Sedan
Stock Top Hats
Scooby 921 Spacers
No Knock
Alignment
Toe 0
First, you'll want the struts to be softer in the back than in the front on those springs. Try 4TFFF front and 4.5TFFF rear and see how that feels.
You should get some more negative camber up front as well, go for -1 to -1.5 degrees or more. Aftermarket camber bolts will get you there easily if the stock bolts won't.
Group N top hats would be a nice addition but since you just had the suspension apart (and putting top hats on would me doing it all over again) I'd say go for some sways. They are a great bang for buck anyway. Definitely plan on upgrading your top hats in the future though. Enjoy!
viper74656 is offline   Reply With Quote
Old 07-30-2009, 08:59 PM   #136
trick3d
Member#: 202146
2006 Impreza WRX
Default Thanks
Ok so thanks for bringing up the point about the front being stiffer. Its a bit of confusion for me but I was under the impression, via the tokico manual, if you want to eliminate some understeer one should run a it more firm in the rear than front. Any thoughts why the manual would say that?
I was thinking about the sways over the top mounts for that exact reason.
Old 07-31-2009, 12:01 AM   #137
viper74656
Member#: 84758
'04 WRB WRX
^^^Well the manual is right, sort of. Stiffening up your compression/rebound ups the stiffness of the rear which increases oversteer, but ideally you should match the compression/rebound settings on your dampers to your spring rates. Since the RCE Blacks are 285F/265R the fronts dampers should be set slightly stiffer than the rear. This is mostly for balance and of course better ride quality.
You would essentially would be compensating for the softer rear spring rate by stiffening the damper. If you end up getting sways it'll be a much more effective way of killing the understeer. Adjustable rear sway bar is the way to go IMO, helps you set the car up the way you like it.
Old 07-31-2009, 08:57 AM   #138
Sir_Xenon
Member#: 9666
02 WRX
WRB, COBB Stage 2
Anyone notice the knob adjustments for the struts were "soft"? Well, three of the four struts offered little to no resistance when turning the knob while one was stiff..? Not sure yet what impact that has on the struts themselves as the car seems to handle amazingly..?
Old 08-08-2009, 12:07 AM   #139
haberkorn
Member#: 97732
2004 WRX STi
Anyone found the sweet spot with a set of prodrive red's on d-spec's yet? I'm ordering up a set next paycheck and was just curious where to set them after break in.
haberkorn is offline   Reply With Quote
Old 08-14-2009, 01:14 PM   #140
Seanco
Member#: 187051
Not sure if I missed it, very possible but, does anyone have any specs with the gf210 combo? Im installing mine today.
Seanco is offline   Reply With Quote
Old 08-14-2009, 11:52 PM   #141
sperry7
Member#: 110079
06 WRX
Black on Black
2006 WRX
42,000 miles on the odo
Crucial Racing Springs (257/217)
Grp. N top hats f/r, 24 mm sways f/r, kartboy endlinks, fender braces
17X8 O.Z. Ultraleggara's Goodyear Eagle F1 235/45/17
-2.75 front -2.0 rear camber
I run them at 5.5 turns from full stiff and find it to be the best setting for daily driving. I think it is faster this way as well, not bouncing or skipping across bumps and losing traction. I am flabbergasted as to why Tokico had these struts mated to 175/175 rate springs as their package because these struts could handle some serious spring rate... like 400/400 I'm guessing based on 257/217 using 5.5 turns from full stiff.
sperry7 is offline   Reply With Quote
Old 08-18-2009, 09:41 PM   #142
lizzardo
Member#: 109765
2005 Saab 9-2X
I've only had these on for a week, and only got the alignment today, so I expect the damping settings will change a bit as the struts break in and I get a feel for how I like them.
2005 Saab 9-2X Linear
Approx 43K miles.
Front: 5 turns out from maximum damping
Rear: 5.5 turns out
Camber: -1.5* front, -1.0* rear (camber bolts in front)
Toe: zero all around
Springs: Subaru STI Pinks, wagon-specific
Relevant mods:
IxizShim (6mm) on rear struts (a little more ride height for when I carry stuff or tow)
IPD/Rallitek front sway bar
FHI 20mm rear sway bar
Kartboy front and rear endlinks
BBS RK 17" wheels w/Bridgestone RE960AS 235/45R17 (yes, one size too wide for the rim)
Whiteline QD rear strut bar
Cheap front strut bar
Turn In Concepts cowl braces
TiC Klunk Killer Kit
Comments:
Overall, I'm really happy with the feel. I like the fact that the compression and rebound both change with the adjustment (I think that some adjustables only change rebound) but suspect that at some point I'll feel like I'm compromising between too much/too little on compression/rebound.
I feel like all the little things I did to tighten up the chassis were just in preparation for decent shock absorbers. I considered the Koni inserts, but didn't want to either do the extra work or pay to have it done.
lizzardo is offline   Reply With Quote
Old 09-08-2009, 09:21 AM   #143
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
View Member's Myspace Profile
do a search for QuikWgn he has them and a there are some photos running around.
R-
Sorry Ty
labcoat is offline   Reply With Quote
Old 09-08-2009, 11:08 AM   #144
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
These are not the letters you're looking for...
Old 09-08-2009, 12:26 PM   #145
Scooby921
n00b Moderator
Member#: 88606
~ FBHIC R&D~
Fluffy McBlumpkins
mQumQu this thread is for discussing damping settings with the d-specs. If you are having issues with your installation, setup, or springs please find a more appropriate thread to post questions in or start your own thread to get a little help.
Your posts were moved and a new thread created for you. You'll find it here
http://forums.nasioc.com/forums/show....php?t=1840645
Scooby921 is offline   Reply With Quote
Old 10-10-2009, 07:54 AM   #146
nightcrawler60
Member#: 126438
2004 WRX
Correct Fitment Crew #30
Picking some D-Specs up today. Current mods are.....
Fender Cowls
22mm front sway, 22-24 rear sway
Front/Rear Strut Towers.
17x8.5 +45 Wheels
245/40/17 Hankook Evos
Rear Group N Top Hats
My last alignment I had it set as close to stock as possible. But after install im going for max -camber front and rear with 0 toe.
Im interested in knowing if anyone is running the springs that come with the shocks and if so how is the drop. I have a choice between the Tokico(F175 R175?) or Progress springs(F210 R150). Trying to remain around USDM Pink height for a WRX and keep it correct, car is a d/d with auto-x every now and then. Appreciae any help.
nightcrawler60 is offline   Reply With Quote
Old 10-10-2009, 01:05 PM   #147
Dubstar112
Member#: 143149
07 WRXtra especial
those spring rates are relatively soft. with your sway bars and tires you can get away with something like RCE blacks and still be comfortable with a sporty handling car.
Dubstar112 is offline   Reply With Quote
Old 10-10-2009, 03:46 PM   #148
nightcrawler60
Member#: 126438
2004 WRX
Yeah, that's what Im hearing. I actually want and plan on getting the blacks...just can't get them at the moment and Im kinda limited to Tokicos or the Progress springs right now.
Old 10-11-2009, 02:14 AM   #149
trick3d
Member#: 202146
2006 Impreza WRX
go for the blacks. I just installed my second set about a month ago. Great progressive spring. Comfy and pretty aggressive when you want to be. Worth the money.
Old 11-07-2009, 04:57 AM   #150
nightcrawler60
Member#: 126438
2004 WRX
Fender Cowls
17x8.5 +45 Wheels
Currently running 3 turns from full soft. Going to play with it more after alignment next Friday. As of right now I can't tell the diffrence in feeling from my last set up...AGX USDM Pinks. Guess once they settle and Im aligned the fun stuff will happen.
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 08:38 PM.
