Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 11-06-2009, 11:32 PM   #1
emsmap
Member#: 159334
02 PSM WRX vf39
UTEC'ed, PPG'd, FMIC,
Default Just installed clutch. Grinding problem. Can I adjust the clutch?
my buddy and I just installed a Stage 2 SPEC clutch in my 2002 WRX. I got my ACT flywheel resurfaced and torqued it and my pressure plate to Spec. Installed everything back. Got in the car and tryed to shift into gear and it doesn't go into gear at all. I try to put it in reverse and it grinds horribly. Is there an adjustment to be made on the clutch pedal or the shift fork on the top of the tranny? I am in desperate need of help. Please help me. Thank you
emsmap is offline   Reply With Quote
Old 11-06-2009, 11:58 PM   #2
penusai
Member#: 102808
2002 v8 EJ207
v7 6spd FP Green
how did you install?
pull engine or pull trans?
penusai is online now   Reply With Quote
Old 11-07-2009, 12:09 AM   #3
emsmap
Member#: 159334
02 PSM WRX vf39
I pulled the motor. I had the motor on my hoist and installed the clutch fork and the throw out bearing then the clutch disk and pressure plate. I am not understanding why its grinding. I need my car tomorrow evening so I hope someone on here can give me some good suggestions on what to look for. Ill get on tomorrow morning and see what is said. Thank guys
Old 11-07-2009, 09:33 AM   #4
emsmap
Member#: 159334
02 PSM WRX vf39
Bump. I reall need some help guys
Old 11-07-2009, 09:39 AM   #5
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Did you try getting it into gear with the engine off? If so, does it work?
I would go back over everything, make sure the clutch fork pivot was reinstalled, etc.
Did you open the clutch fluid hose, if so rebleed the line.
Old 11-07-2009, 09:48 AM   #6
emsmap
Member#: 159334
02 PSM WRX vf39
We did not try geting it into gear with the engine off. We did not bleed the clutch fluid either. Is bleeding the fluid really necessary when changing a clutch?
Old 11-07-2009, 10:11 AM   #7
09rexwagon
Member#: 216135
2009 WRX
SSM
Not unless you open the hydraulic system, which you probably didn't.
How did you do the TOB? Did you put it in the tranny with the release fork attached and then mate the engine/tranny and pop the TOB onto the PP? Or did you preinstall it on the PP fingers and then manipulate the release fork into it after the engine/tranny was mated.
Anyway, that may not be it, but the end all say all is the disk is not disenaging from the PP/FW. Were you particularly careful when you aligned the disk before putting the PP back on? It can get pinched if it is not properly aligned and it will never release.
09rexwagon is offline   Reply With Quote
Old 11-07-2009, 10:22 AM   #8
emsmap
Member#: 159334
02 PSM WRX vf39
I installed it the first way you mentioned.
My buddy is the one that has installed several clutches in Subarus. He made sure the clutch and Flywheel was mated right and he was the one that aligned the clutch.
Old 11-07-2009, 10:28 AM   #9
biggreen96
Member#: 12535
vf39 93 Legacy Wagon
FMIC TEIN STI APEXI
well somethings up and needs to be fixed. Start taking it back apart....
biggreen96 is offline   Reply With Quote
Old 11-07-2009, 10:37 AM   #10
09rexwagon
Member#: 216135
2009 WRX
SSM
Did you manually push the release fork to make the TOB 'pop' onto the PP fingers?
Old 11-07-2009, 12:05 PM   #11
emsmap
Member#: 159334
02 PSM WRX vf39
yes I did. but that is what I think is the problem. I don't think the throwout beraring clicked into place. When I take the slave cylinder off the clutch fork, it has like an inch and a half play in it. What should it have?
Old 11-07-2009, 12:26 PM   #12
penusai
Member#: 102808
2002 v8 EJ207
v7 6spd FP Green
look through the hole.
pull the rubber boot off the top of the clutch fork and use and light and look in.
see if you can see anything odd.
Old 11-07-2009, 01:51 PM   #13
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Try getting into gear with the engine off, it that works then the clutch is not disengaging and with the engine running it WON'T go into gear.
No, you do NOT need to bleed the clutch, only if you open the clutch fluid lines.
Old 11-07-2009, 02:45 PM   #14
emsmap
Member#: 159334
02 PSM WRX vf39
Ok well I had one of my good subaru buddies come over and check it out. He seems to think that everything is fine and that I should bleed the slave cylinder and fill with new fluid to see if that works. If that doesn'r work, he said for me to change the slave cylinder. He said that there is air in the system and it is not pushing the throw out bearing out far enough to engauge the clutch. I will let you all know how it goes.
Old 11-09-2009, 03:01 PM   #15
emsmap
Member#: 159334
02 PSM WRX vf39
Well the problem was fixed for 20 minutes after I flushed the slave cylinder. It came back after sitting for 20 minutes so my guess is that the slave cylinder is gone
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 06:37 AM.
