Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Go Back   NASIOC > NASIOC Classifieds > Private 'Wanted' Classifieds
Old 11-04-2009, 10:07 PM   #1
vsmack
Member#: 92872
Default TGV Sensor broke, I need to confirm the right part
I've search around Nasioc carefully and my friend has an 2006 WRX. He broke the sensor and I found this number 22633AA210 but for older models.
I found it here: http://forums.nasioc.com/forums/showthread.php?t=630216
The sensor is in the picture so if someone could confirm this I would really appreciate it and where's a good place to buy it?
vsmack is offline   Reply With Quote
Old 11-04-2009, 11:26 PM   #2
Member Sales Rating: (5)
tic- toc
the countdown has started
google is your friend
a part number is a part number
what is the problem??
Old 11-05-2009, 12:25 AM   #3
vsmack
Member#: 92872
The problem is that I've had trouble confirming the part number, had trouble at subarugenuineparts.com etc finding it. It's my first time actually asking because I haven't really found a concrete answer.
What happened was that he was working with his car and he broke the sensor. Whenever he hits around 3.5K or so rpm at full throttle it feels like it hits fuel cut and you hear like a backfire through the external wastegate. Sounds bad but the car runs fine below it.
Also he got engine codes p1491, p2016, p2433, and p2431.
Our conclusion is that it's that part obviously. Also, the local subbie mechanic suggested that he did the TGV delete once n for all and clear the codes when he gets retuned.
Anyhow that's the problem in general.
Any insight would be appreciated. Thanks
Old 11-05-2009, 01:20 AM   #4
STIBungy
Member Sales Rating: (48)
Member#: 51684
2004 Impreza WRX STI
On the older wrx/sti, the sensor was one one end and the motor was on the other. On the newer ones, the motor and sensor are integrated.
STIBungy is offline   Reply With Quote
Old 11-05-2009, 12:24 PM   #5
vsmack
Member#: 92872
Really! My friend said his looks exactly like the one on top in the picture
Old 11-05-2009, 05:58 PM   #6
573
Member Sales Rating: (4)
Member#: 144821
2007 WRX wagon Black
http://cgbagne.com/wrx
Negative.
I have some sensors and motors from a 2007 sitting around from when I did the TGV delete mod. If you don't mind waiting a few weeks, I can send you a sensor next time I'm home.
573 is offline   Reply With Quote
Old 11-05-2009, 09:21 PM   #7
importlife
Member#: 155488
2006 wrx
I will like to get that part #. I haven't been able to find it anywhere including subaru Genuine parts.
Thanks for your help!
importlife is offline   Reply With Quote
Old 11-06-2009, 09:13 PM   #8
importlife
Member#: 155488
2006 wrx
Originally Posted by 573 View Post
Negative.
When you expect to be home?! I need it ASAP and Seems like no one here know the F.. part #.
Old 11-07-2009, 12:20 AM   #9
573
Member#: 144821
I won't be home until the 25th. If you still don't have it by then, pm me and I'll send it out promptly.
Old 11-07-2009, 10:37 AM   #10
Darkness Of Death
Member#: 167172
2007 B Spec
i can't seem to find mine...i took them off before i sold the tgv's.
i dont think they would have changed the sensor..it's very possible they might have changed the part number for the exact same part as well
Darkness Of Death is offline   Reply With Quote
Old 11-08-2009, 12:59 PM   #11
STIBungy
Member#: 51684
I guess the STI must be different than the WRX. I bought a set of TGVs off an 07 STI. I still have the TGV motor/sensors somewhere.
Negative.
Old 11-08-2009, 08:50 PM   #12
importlife
Member#: 155488
2006 wrx
PM me for sale of the passenger side sensor
Old 11-09-2009, 10:20 AM   #13
GT35RHybrid
Member Sales Rating: (1)
Member#: 223237
PM me for sale of both sides of TGV sensors and motor.
GT35RHybrid is offline   Reply With Quote
Old 11-09-2009, 11:59 AM   #14
VIR EURORALLY
Member Sales Rating: (17)
Member#: 53517
STi Outback STi
Epic Motorsports
The TGV and TPS sensors are the same.
22633AA210
VIR EURORALLY is offline   Reply With Quote
Old 11-09-2009, 04:08 PM   #15
White out
Member Sales Rating: (54)
Member#: 46277
1998 Hummer OpenTop
1999 Dodge Viper GTS ACR
If you haven't found any luck with the tgv sensors/motors PM me. I can send you mine, just cover shipping.
Thinking about it, you might just want to delete the tgvs & have the rod holes welded shut (local welding company could do it in less than a day). The only parts you would need is new intake manifold gaskets.
Nick
White out is offline   Reply With Quote
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 11:35 AM.
