#226 |
^ i agree!
#227 |
Member#: 226470
just ordered mine right now! this **** comes with all the wiring needed right?
hope so anyways. |
#228 |
#229 |
Member#: 192336
NESIC
Vehicle:2006 STi WRB |
Mine came yesterday. Can't wait to do away with the wiley coyote meep meep horn.
#230 |
Member#: 200229
W. Canada
Vehicle:04 Impreza White |
so is the purpose of these horns just to have a louder horn?
#231 |
Member#: 220727
Tri-State
Vehicle:05 Sti Aspen white |
Dam, someone sould of have bump this sooner. Or maybe I should of have look in this forum. Just spent $65 on them dam hella tones. I could of save some $ and gotten some hella bud to go with the install.
#232 |
Member#: 226412
Vehicle:1998 Impreza Wagon Black |
I installed mine on saturday and it was really really easy.
For anyone thinking about getting these all you have to do is- -Unplug the two wires from your stock horn -cut enough wire (I used speaker wire) to reach where you want to mount the new horns. -expose enough wire (On the stock wire) to splice in two wires on each (Positive and negative for each of the 2 horns) -Crimp a connector on the other end of these wires (Total of 4) to plug into the hella horns. -Test the horns before you mount -Find where you want to mount the horns, and if it's behind the grille, wire tie them into place and put the grille on to check the clearance. -bolt them up however you want and your done! I didn't bother using the relay they supplied, they seem to be working fine. Hope this helps any of you on the fence! It took maybe 20 mins? On a side note, they are a lot louder then expected and only get these if you don't mind having the loudest horns on the road. Next person I honk at is going to be very mad...... |
#233 |
Member#: 77366
MWSOC
Vehicle:2004 WRX Wagon stg.2 WRB |
I mounted mine on Saturday night before a trip into chicago. it took me longer to decide where to mount than anything else in the whole process. I tried them in a few places before deciding to go off of the center mount where one stock horn was and then relocated my beeper...
#234 | |
Member#: 113232
MAIC
Vehicle:MY02 WRX MY00 2.5RS Coupe |
#235 | |
Member#: 226412
Thanks though, I was waiting to see what the drawbacks were of me wiring them up the way that I did. |
#236 |
Member#: 152707
NESIC
Vehicle:2000 Impreza WRSX |
Are people getting the ones made in germany? I have heard there are a few different types of supertones and the german ones are what people seem to like best.
#237 |
Member#: 77366
MWSOC
I am not disputing this, but can you explain why? The hellas require a 12v supply and from my understanding that is what the stock horn relay is providing??
#238 |
Member#: 157924
TXIC
Vehicle:2010 WRX Sedan Back in Black |
Just ordered mine as well!
![]() Awesome deal - thanks for the link! |
#239 |
Member#: 13910
NESIC
Vehicle:1995 Legacy L Wagon |
Will order in the morning but did anyone have to make a mounting bracket?
I have a 95 legacy so I don't know if I need to or not it's going to be behind the grill. |
#240 |
Member#: 95337
Tri-State
Vehicle:2006 Professional s**t talker & theRapist! |
#241 | |
I have the India model, and believe me, they are plenty loud. |
#242 |
Member#: 190260
Vehicle:06 STI Aspen White |
I've been hesitant to buy a set but with this deal i had to pull the trigger. Thanks man
#243 |
Member#: 208152
South East
Vehicle:2007 STI LTD #576 Urban Gray Metallic |
It's getting 12V, but not the current necessary to drive the horn. Basically (from my understanding of what's been posted, don't have them yet) the skinny factory wiring is the culprit. By using the relay, you use the factory wiring as the trigger, and the horns get a nice, short fat pipe of current straight from the nearby battery.
#244 | |
Member#: 77366
MWSOC
#245 |
Member#: 1026
MWSOC
Vehicle:00' RS/WRX Stg4 Mindless Self Indulgence |
Supertones... bah....
FIAAM Riviera ... ~30$ shipped (one set of 3) from amazon.. lol.. ![]() ![]() |
#246 |
just grabbed a set as well, everything still works! what a deal!
#247 | |
Member#: 208152
South East
#248 | |
Member#: 77366
MWSOC
#249 |
AAAAAAAHHH $*&$#&^!!!!!! i forgot to put in the discount! oh well... on their way!
#250 |
Member#: 179573
South East
Vehicle:2002 VF22 Bugeye!! MBP |
