Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 11-07-2009, 09:52 AM   #1
AVANTI R5
Member#: 73805
Default Hybrid vehicles have higher pedestrian crashes
A recent report from the National Highway Transportation Safety Administration (NHTSA) has found that hybrid electric vehicles have a higher incidence rate of pedestrian and bicyclist crashes than do conventional vehicles in certain situations.
NHTSA looked at state-level crash files to compare crash rates on these two types of vehicles. Out of 8,387 hybrids 77 (or .9 percent) were involved in crashes with pedestrains. Out of 559,703 conventional vehicles studied, 3,578 (or .6 percent) were involved in crashes with pedestrians. In crashes involving bicyclists, 48 (or almost .6 percent) were involved in crashes with a hybrid vehicle whereas conventional vehicles were implicated in 1,862 (or .3 percent) of crashes.
The study (pdf) found that these incidences were more likely to occur in areas with low speed limits. The hybrids had a higher incidence—two times more likely to have a pedestrian crash—when they were slowing or stopping, backing up, or going in or out of a parking space. Most hybrids employ their electrical motors only at these situations, making these cars eerily quiet.
In 2007, there were 70,000 pedestrians injured and 4,654 deaths due to crashes. A number of organizations, including the National Federation for the Blind, are pushing for legislation that would require all hybrid and electric vehicles to emit a sound. A number of car makers are looking into warning systems, as well.
In the meantime, hybrid drivers need to be aware of their stealthy approach and use extra vigilance and possibly look into installing a backup alert warning device or even a backup camera to be able to see pedestrians and bicyclists around their vehicle. Likewise, pedestrians need to be vigilant as electrified automobiles will become increasingly common.
http://blogs.consumerreports.org/car...n-crashes.html
Old 11-07-2009, 10:24 AM   #2
whoosh
Member#: 40989
OT vag inspector
maybe if pedestrians and cyclist would watch where they're going it wouldn't be a problem
whoosh is offline   Reply With Quote
Old 11-07-2009, 10:35 AM   #3
Mike Wevrick
Member#: 24654
1957 Taggart Comet
gold
Putting backup beepers on them would make sense. Its very easy; you just replace one of the reverse light bulbs with a combination light/beeper.
Mike Wevrick is offline   Reply With Quote
Old 11-07-2009, 10:40 AM   #4
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
The second-gen Prius has one, but for some unfathomable reason it's INSIDE the car. Fortunately you can turn it off fairly easily.
Chromer is online now   Reply With Quote
Old 11-07-2009, 10:47 AM   #5
AVANTI R5
Member#: 73805
I guess to make the driver More Focused, that is strange.
Old 11-07-2009, 10:49 AM   #6
sxotty
Member#: 95600
2003 WRX wagon
It is annoying is what it is beep-beep If only it was outside it would make some sense. The rates are not too much higher though at least.
sxotty is offline   Reply With Quote
Old 11-07-2009, 11:01 AM   #7
bal00
Member#: 54772
Originally Posted by whoosh View Post
maybe if pedestrians and cyclist would watch where there going it wouldn't be a problem
Why hasn't anyone thought of this before? Now all we need to do is tell drivers to watch where they're going too and there will never be an accident again. Brilliant.
bal00 is offline   Reply With Quote
Old 11-07-2009, 11:04 AM   #8
Lantec
Member#: 48685
2004 Impreza WRX
QFT. How can you not see a 1.5 ton piece of metal coming at you? Even hybrids can be heard coming, tire noise will always be there, especially in those squeeky parking lots, and there's always that high pitched electrical transistor whine. It's not hard to detect.
Lantec is offline   Reply With Quote
Old 11-07-2009, 11:25 AM   #9
neko
Member#: 46500
2004 STi Sedan
Now with 100% more bugeye
Tire noise? aww, come on, i'd betcha most hypermiling, greenie, hybrid owners are running their super-skinny tires with 55psi in them to extend their mileage... :P
And no wonder they can't stop in time either to avoid the accident. when you've got virtually no contact patch because of those practices, its not suprising
I laugh every time i see some place recommending higher tire pressures to improve mileage.... Like there's no down side. The concept of proper tire inflation seems to be gone out the window.
neko is offline   Reply With Quote
Old 11-07-2009, 11:47 AM   #10
shikataganai
Member#: 92634
2009 Piaggio MP3 250
2008 Honda Fit
so loud car pipes save lives?
shikataganai is offline   Reply With Quote
Old 11-07-2009, 11:50 AM   #11
shikataganai
Member#: 92634
2008 Honda Fit
recommending that tires be properly inflated, or at the upper end of acceptable, is different than recommending they be overinflated.
besides:
2008 Prius 60-0 stopping distance: 134 ft per edmunds.
2008 Tahoe 4WD 60-0 stopping distance: 173.7 ft per the Michigan State Police.
which one is the dangerous one again?
Old 11-07-2009, 12:52 PM   #12
sir_wagon
Member#: 71549
I wonder if they took into consideration where the vehicles were driven before making the comparisons between hybrids and non-hybrids.
I would not be surprised if urban areas have a higher proportion of hybrids than rural areas.
sir_wagon is offline   Reply With Quote
Old 11-07-2009, 12:55 PM   #13
bal00
Member#: 54772
How do you not see parked cars or trees? People drive into them all the time.
Old 11-07-2009, 01:30 PM   #14
WRXBob
Member#: 12455
02 WRX
Around here, pedestrian steps into a vehicle path without even looking. Beside the slow parade across the intersection, they think it is only the driver that should look out for their safety. On the other hand, drivers of Hybrid vehicle are bathed in green eco glory and have less and less driving skill.
WRXBob is offline   Reply With Quote
Old 11-07-2009, 01:56 PM   #15
owace
Member#: 138000
73 cb 350f
black
i wonder how much of this has to do with jackass drivers who drive hybrids....
owace is offline   Reply With Quote
Old 11-07-2009, 02:05 PM   #16
CKxx
Member#: 33458
1988 Justy 1.2L 4WD
2002 WRX 2.1L AWD
Sight is one of several senses apparently being employed by the average cyclist or ped...
CKxx is offline   Reply With Quote
Old 11-07-2009, 03:48 PM   #17
robertrinaustin
Member#: 51964
2008 STi, EVO VIII
I bet most of the people hit by the hybrids were big SUV drivers.
robertrinaustin is offline   Reply With Quote
Old 11-07-2009, 04:35 PM   #18
KC
Member#: 442
2000 Honda S2000
Any demographics on the drivers of the cars? I see more "older" drivers in hybrids than younger drivers...
Sure, these cars are quieter, and stupid people need to stop walking on the street (or know which side of the street is the proper one if not in a crosswalk) but all the blame can't rest on the pedestrians shoulders...
--kC
KC is offline   Reply With Quote
Old 11-07-2009, 04:40 PM   #19
under5
Member#: 188980
2005 WRX
Stupid people buy hybrids, stupid people can't drive, therefore hybrid drivers hit people.
under5 is offline   Reply With Quote
Old 11-07-2009, 04:52 PM   #20
naimouasta
Member#: 47998
2002 WRX Wagon
2008 Legacy QSM
+1 simple as that.
naimouasta is offline   Reply With Quote
Old 11-07-2009, 05:22 PM   #21
Tim-H
Member#: 65751
Absolutely agree with you. The reason the pedestrians and cyclists get hit more is because they don't look before crossing the street. The biggest reason has to be people with earbuds in listening to mp3 players. There are so many cyclists I see around here with them in and they cant hear anything around them.
Tim-H is offline   Reply With Quote
Old 11-07-2009, 05:36 PM   #22
blkscooby
Member#: 44422
08 STI FP 20g
91 and E85 #'s soon
Ha, most hybrid owners I see drive like bats outta hell. I got passed by a Prius today going 65 in a 45. I was doing 50.
blkscooby is offline   Reply With Quote
Old 11-07-2009, 06:33 PM   #23
sxotty
Member#: 95600
2003 WRX wagon
That is a good point. I had not thought of it.
Old 11-07-2009, 07:21 PM   #24
whoosh
Member#: 40989
OT vag inspector
go to a walmart parking lot.
it doesn't matter how noisy your car is, the retarded fatties still walk in the middle of the aisles saving as many heart attack steps as they can to get to the 50 pack of donuts.
Old 11-07-2009, 07:24 PM   #25
whoosh
Member#: 40989
OT vag inspector
let me tell you about the abundance of non-hybrid jackass drivers that love to cut in front of prius's traveling in the right lane.
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 11:42 AM.
