#26 |
Member#: 128115
South East
Vehicle:2004 4EAT Wagon PSM enginuity is cool |
dumdum--
Was that TD04 map using the stock BCS? |
#27 |
Member#: 70395
Vehicle:02 wrx whitey |
...........double post
#28 |
Member#: 70395
Why? Look at where I'm using that at. It allows the GMBCS to act like a MBC by doing that. Better spool. "Crazy" overboost is generally a turbo dynamics problem.
#29 |
Member#: 70395
#30 | |
Member#: 128115
South East
That makes sense the more I think about it. I may try this format, not the exact same values, because its my understanding that the Grimmspeed BCS nees a bit less WGDC than the GM. What would happen if I significantly lowed my TD tables to not swing so much? Maybe only give them a 1% Correction or something like that? |
#31 |
Member#: 70395
It(turbo dynamics) would just have to repeat the process more to hit target boost. Thats why you should try to set realistic boost targets. Especially in the lower ranges. My car was very responsive with that setup. Lightning fast spool up.
#32 | |
Member#: 128115
South East
I'm going to model my target boost, wgdc and TD after your map and see what happens. I'll post back with results. |
#33 |
Member#: 70395
#34 |
Member#: 128115
South East
So far so good.
I'll post up some logs tomorrow. As of now the boost seems stable. I still need a bit of fine tuning, but it is a very good starting point. I logged 20.75 in one spot which is a bit higher than I'm comfortable with, but I can tune that out. I was holding 19 and tapering to about 13 at redline. Very minor occilation. (very minor) I also got to 13 psi by 3000 which is about 400 sooner than before. |
#35 |
Member#: 128115
South East
2nd gear log pulled last night. One small area of high boost, but I wouldn't consider it a bad spike. I think it could hold a bit more towards redline. As of now, dumdum's boost map is looking good to me.
#36 |
Member#: 128115
South East
Bump...
#37 |
Member#: 26568
Vehicle:2003 Yellow Bugeye Version 8-Vf37 |
i'm having a similar issue in my map where boost fluctuates after 5.5k. let us know when you figure it out.
#38 |
Member#: 70395
Have you tried removing some preload from the wastegate arm? Try a half a turn out at a time. Also don't forget about the IAT wastegate compensation map.
#39 |
Member#: 26568
dumdum,
should the wgdc IAT comp be zeroed out after 68F to 230F |
#40 | |
Member#: 128115
South East
Not yet. Thats my next move. I just really hate removing the stupid heat sheild cause its such a pita to get back on. My IAT map is basically stock. Would you recommend increasing the WG correction % ? Right now it feels pretty smooth. I just want to smooth it out a bit more and decrease the minor spike I'm experiencing. |
#41 | ||
Member#: 70395
![]() Also remember,just because this map (all the tables) on my car doesn't mean it will just automaticly work on yours. I ran a P&Ped Tdo4 with a BPM TMIC,TGV deletes,EL header,catted DP and some other goodies with that map. You might need to go back and retweak the Turbo Dynamic tables alittle or the Max wastegate duty table as well. |
