Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 11-03-2009, 10:02 PM   #1
RoadTrippin
Member#: 161175
Default Hesitation?
From a stop I have a problem with slight hesitation during acceleration. Sometimes I feel like it is going to stall out on me but it has yet to do so. NO CEL, no backfiring yet, just the hesitation. It just started within the last two days.
I usually run 87 octane gas as that is mid grade up here in Denver and for the past two weeks have been running 85 octane gas just as an experiment. Im starting to think that may have been a bad idea but am curious as to why it would start now vs the 1st tank of 85. I bought some BG 44k today and plan on putting it in on the next fill up but was seeing if anyone else had an idea as to why all of a sudden this could start.
The car is an 02 RS, Auto
RoadTrippin is offline   Reply With Quote
Old 11-03-2009, 10:09 PM   #2
yarrgh
Member#: 80465
2001 2.5 RS
Black Diamond Pearl
search...
yarrgh is offline   Reply With Quote
Old 11-04-2009, 07:41 PM   #3
05Impreza2.5RS
Member#: 156674
2005 Impreza 2.5RS
I have been having the same hesitation in my 05 Impreza. I changed out the spark plugs and wires over the weekend, but that seemed to do nothing. I used my Accessport to check and see if there were any ECU trouble codes. To my surprise there were about 30 codes! Most of the important codes seem to involve the Secondary Air Injection System. Has anyone else had these codes, and if so what they did to fix the problem?
05Impreza2.5RS is offline   Reply With Quote
Old 11-05-2009, 02:55 AM   #4
01LGT
Member#: 224816
2001 Legacy GT
check upstream o2 sensor, i've had problems w/out a CEL where it does something similar. plugs may cause this as well
01LGT is offline   Reply With Quote
Old 11-05-2009, 11:53 AM   #5
RoadTrippin
Member#: 161175
I changed the fuel filter today and I still am having the problem. It isnt as bad as before but is still there. Im going to give it a few days before I try something else. After I changed the fuel filter the CEL came on and it was cylinder 2 misfire. There was a tiny bit of water in the spark plug boot from when I cleaned off the battery terminals, I blew it out and it hasnt thrown a CEL since.
Im thinking next steps would be fuel injector cleaning then spark plugs. Though I did change the plugs maybe 20k miles ago.
Old 11-07-2009, 11:56 AM   #6
RoadTrippin
Member#: 161175
Ok so did some checking and it turns out the valve cover gaskets were toast causing oil to leak on the plugs. New valve cover gasket, spark plugs, and wires runs like new.
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 08:25 PM.
