Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Go Back   NASIOC > NASIOC Technical > Factory 2.0L Turbo Powertrain
Old 11-06-2009, 07:52 PM   #1
ch@0$
Member#: 178508
2004 wrx
aspen white
Default bov sound changes
I have a 04 wrx. The car is completely stock as far as i know since i bought it used and was told it was. The bov just doesnt sound like it did when i first got it. Now instead of a quick loud pssshhh, i have a low drawn out psshhh. This really doesnt bother me expect for the fact i just want to make sure it isnt damaging the engine.
Thanks for reading
ch@0$ is offline   Reply With Quote
Old 11-06-2009, 07:55 PM   #2
Audiosavvy
Antique Roadshow groupie
Member#: 150794
2.3 built bugeye
In it to win it
View Member's Myspace Profile
You say the car is stock and then mention a BOV. Does it have a BOV or no? If it's BONE stock, you shouldn't really hear ANY of that.
Audiosavvy is offline   Reply With Quote
Old 11-06-2009, 08:06 PM   #3
ch@0$
Member#: 178508
2004 wrx
aspen white
thanks for the reply....i guess now that i look. Maybe it has a forge bov. if that makes any sense........im a noob to the whole turbo and its components so it may not help this at all.
Old 11-07-2009, 03:02 AM   #4
JON-E25WRX
Member#: 225389
03 wrx, 07 2.5i
Midnight Black Pearl
maybe check if the adjustment screw got loosened or something.
but you know a bov isn't all that great for the car if its stock, yer car is runnin rich.
JON-E25WRX is offline   Reply With Quote
Old 11-07-2009, 03:06 AM   #5
ADAS1223
Member#: 159853
2005 concaved cusco
www.subieworld.com
take a picture and post it up for us.
ADAS1223 is offline   Reply With Quote
Old 11-07-2009, 10:39 AM   #6
ch@0$
Member#: 178508
2004 wrx
aspen white
like i said, i bout the car last year and it still sits the same. Only thing i have done to so far is change the oil/filters and put a new set of tires on it. From looking at the bov and reading online i dont think mine has an adjustment screw. It seems as if the only way to change the adjustment is to get a spring kit from forge.
http://www.stratmosphere.com/forge_w...d_plug_320.jpg
that is the bov, not my car but the same one. thanks for the help
Old 11-07-2009, 06:15 PM   #7
lil'redwagon
Member#: 10854
2002 WRX Sedan
still lil' and red
get a new spring. it sounds like yours is going soft. or you can open it up and stack some quarters in there like the stock bpv mod. and it's pretty normal for aftermarket bov's to not have adjustment screws.
Old 11-07-2009, 08:02 PM   #8
ch@0$
Member#: 178508
2004 wrx
aspen white
thanks redwagon i figure i will just get a new spring. but until would the spring getting soft create any issues with the engine or will it just let of the air slower? thanks again for the help
Old 11-07-2009, 08:20 PM   #9
woodys77
Member#: 192147
2007 STI EfiLogics
407whp 402wtq fpgreen
are you 100% sure that your car is still making the same boost that it was before? if you are low on boost that will def change your bov sound. and bov's don't make your car "run rich" its only rich between shifts and is very minor.a junk bov or a bov not setup properly is were the real negative effects come from. finding a bov that doesnt leak or surge is the trick thats why the oem bpv is so nice.
woodys77 is offline   Reply With Quote
Old 11-07-2009, 08:23 PM   #10
02boxer
Member#: 139853
2002 wrx, it's TSX'y
check the lower spring. Mine went last year and did the same thing. If it needs replacing, contact Forge directly they warrantee their parts. So you should get a replacement for free. I will say, these guys are flat out rad in the service dept. After getting lost in the mail, they sent out a 2nd new spring right away, it literally got to my house (near detroit mich.) from Orlando within a few hours.
If ya let it go, it would likely create a noticeable vac. leak when it's open for the longer period...mine never stalled, but came pretty close a few times
chris
02boxer is offline   Reply With Quote
Old 11-07-2009, 08:24 PM   #11
ch@0$
Member#: 178508
2004 wrx
aspen white
i would assume it is still making the same boost levels. the car still runs as it did when i got it. i would think that with lower boost levels it wouldnt pull as hard but like i said in a pervious post i am a complete noob to this and still learning so any info, suggestions is appreciated.
Old 11-07-2009, 08:30 PM   #12
02boxer
Member#: 139853
just take it off, remove the 6-7 hex bolts, the top spring and piston and check the lower one. Once it's apart, it's a good idea to clean it and relube. the o-rings too
chris
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 05:39 PM.
