I'm thinking about bypassing the variable fuel pump voltage controller. I don't think the Walbro is as responsive or in other words I think the flow rate of the walbro at the reduced voltage during closed loop ops is not as stable as the factory denso pump or a better quality pump like the AVO. I know in all my past import cars i have bypassed the voltage reduction circuit to ease tuning. Currently i'm seeing irratic A/F's during closed loop ops. Sometimes i'll be cruising and the car starts leaning out outta nowhere. I blip the trottle and presto and then it's a random when it returns. I don't think the walbro likes the reduced voltage at all. Anyone have any reason why I should not bypass the controller? Anyone done it yet or know a thread on this? thanks, stephen.
2008 STI WRB, Mahle pistons, water/meth, GTspec header/uppipe, LFR7AIX's, Invidia Catless Downpipe, 3" midpipe, Tein S-type springs, 15mm bolt-on spacers, PNP TB, PNP Turbine exh housing, TGV deletes, Harmon Motive CAI, AEM UEGO, GS EBCV, GS phenolic Spacers, PCV delete, daytime running lights deleted, debadged, AP 22mm rear sway, Walbro Fuel Pump Mod, Modded Stock Injectors(816cc), Tinted Tail lights, Kartboy Knob........
