Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 11-03-2009, 09:30 AM   #1
stu1811
Member#: 124651
2006 WRX Wagon
Default Lights keep burning out
Last year I smashed in my passenger front. Had to replace hood, fender, bumper, and radiator support. Ever since then both low beams and both fogs regularily burn out. The bulbs often have a black bubble. Overheating? I need to get under the car and poke around. What should I be looking for? Why is it affecting both driver and passenger lights?
stu1811 is offline   Reply With Quote
Old 11-03-2009, 09:38 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO
Put a voltmeter across the battery while the engine is running. At operating temperature you should see about 14V max. If it's much higher, especially if it's 15V+, the voltage regulator in the alternator may be bad. Excessively high voltage will cause bulbs to burn out prematurely/frequently.
This may be related to the damage or it could be coincidental.
Too-high voltage will damage the battery as well, so if you find this to be the case the battery should be checked and replaced if needed. The overvoltage will cause overcharging and boiling of the electrolyte, so fluid coming out of the battery is a visual clue.
Old 11-03-2009, 09:49 AM   #3
stu1811
Member#: 124651
2006 WRX Wagon
I replaced the battery over the summer. Stocker wouldn't hold a charge. My audio system might be putting too much strain on the alternator. Carputer + 4 channel amp + mono sub amp. I'll post the voltage when I get home.
Edit: new battery is optima redtop
Old 11-03-2009, 11:10 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO
The Optimas, and other sealed/AGM type batteries, will be permanently damaged by overcharging as any lost electrolyte cannot be replaced. Optima specifies a maximum charging voltage of 15V. So, if you find that you've been running at a higher voltage for any length of time, your Optima may need to be replaced.
Old 11-03-2009, 01:21 PM   #5
stu1811
Member#: 124651
2006 WRX Wagon
According to tactrix cable, voltage holds at 14v at idle. I'll verify with a multimeter later.
Old 11-03-2009, 06:13 PM   #6
stu1811
Member#: 124651
2006 WRX Wagon
14.08v at idle. Just measured with multimeter.
Old 11-03-2009, 07:32 PM   #7
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Check the DC voltage at around 2,000 RPM along with measuring the AC voltage. There should be no more than .1 volts AC across the battery.
Cougar4 is offline   Reply With Quote
Old 11-05-2009, 09:55 AM   #8
stu1811
Member#: 124651
2006 WRX Wagon
I measured the battery voltage via tactrix on my way to work. Max was 14.41. When I got to work I put my multimeter in the cigarette lighter and measured a voltage of 14.14 at 2k rpm.
Old 11-05-2009, 12:52 PM   #9
Cougar4
Member#: 53443
Winestone
The DC voltage you measured is good at both locations. Take an AC voltage measurement across the battery if you can and see if that is okay.
Old 11-05-2009, 03:43 PM   #10
stu1811
Member#: 124651
2006 WRX Wagon
10-30 mv ac at idle across battery and at 2k rpm
Old 11-05-2009, 03:43 PM   #11
stu1811
Member#: 124651
2006 WRX Wagon
Old 11-05-2009, 03:59 PM   #12
dangerousatom
Member#: 70710
FAST 04STi in a 02RS
PPG tranz "rally blue"
Where the mounts for the headlight assembly damaged at all? If the bolt holes or rubber bumper/slip in mounts are off, it may be allowing extra vibration in the headlight assembly. It may not be visable to the eye but it may be causing the bulb filaments to vibrate and occasionally the sections may touch witch causes those touching sections to fuse together. The more section the filament looses the brighter and hotter it gets till poof. If the headlight assembles where removed during your front end repair, they may not have been tightened all the way down or did not seat correctly?!?
Like Mulder stated it could be just coincidental crappy or bad bulbs
Water or vapor build up can cause bulbs to blow out black as well....like the tubes in a 500w flood light do
I assume your not touching the glass part of the bulbs at all when installing, for that will kill a halogen bulb quick!
dangerousatom is offline   Reply With Quote
Old 11-06-2009, 09:05 AM   #13
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Originally Posted by dangerousatom View Post
I assume you're not touching the glass part of the bulbs at all when installing, for that will kill a halogen bulb quick!
+1. If your skin touches the glass, it needs to get cleaned off (the glass, not your hand).
Old 11-06-2009, 10:19 AM   #14
Cougar4
Member#: 53443
Winestone
Well the voltages readings you took show all is well with the power. You might try a different brand of bulbs to see if that helps. I assume you aren't trying to use a higher power bulb than the normal spec'ed ones.
Old 11-07-2009, 01:09 AM   #15
stu1811
Member#: 124651
2006 WRX Wagon
The whole front was replaced. I tried to move the headlight assembly and it seems stable. I'll try different bulbs. I've been using whatever I could find at autozone. Pretty sure they are 55w. I'm very careful not to touch the non-metal part of the bulb. I know the oil on my fingers will cause the bulb to burn out.
Old 11-07-2009, 01:49 AM   #16
penusai
Member#: 102808
2002 v8 EJ207
v7 6spd FP Green
the glass is what you don't want to touch.
penusai is offline   Reply With Quote
Old 11-07-2009, 09:37 AM   #17
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Ummm....stu knows that...."I'm very careful not to touch the non-metal part of the bulb."
Old 11-08-2009, 09:22 PM   #18
stu1811
Member#: 124651
2006 WRX Wagon
Where are the grounds for the low beams and fogs?
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 09:55 AM.
