Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 11-06-2009, 02:51 PM   #1
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Default my in-car camera mount solution...
Just thought I'd share what I came up with today...
It uses the two dome light screws and the two rearmost grab-handle screws. Very sturdy, good location and good view.
The drops and cross-bar are aluminum flat, the braces are aluminum "L" channel, and they're bolted together with 4 small angle brackets and some 6mm bolts. It's pretty easy to put in and take out. Everything is available at home depot.
Will have some sample video after the weekend.
sniper1rfa is offline   Reply With Quote
Old 11-06-2009, 03:07 PM   #2
chimchimm5
Member#: 88501
2006 WRX Wagon
CGM
Does the camera sit above or below the flat bar?
If above, won't the rear view mirror get in the way?
And I'm assuming you'd only use this when all passengers are wearing helmets.
But you're right, that is the best in-car camera location for really capturing the feel of what it's like in the car and not just artistic shots. Hence this is essentially the location of incar cams when there is a full cage inside.
chimchimm5 is offline   Reply With Quote
Old 11-06-2009, 03:10 PM   #3
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Below, upside down. I plan on removing the rear view while using it. It's actually far enough away that helmets aren't needed*, but i only plan on using it for events that require helmets anyway (rallycross).
* well, for the front two seats.
EDIT: I may make another one that drops lower, to save myself the processing required to invert the image, but there is less clearance for the camera that way. I'll do it when i own my own camera.
Old 11-06-2009, 04:24 PM   #4
MasterKwan
Member#: 98961
2003 WRX
You need to check with who you run with. Not sure that would fly on the tracks I run.
MasterKwan is offline   Reply With Quote
Old 11-06-2009, 04:36 PM   #5
jc8587
Member#: 76201
2002 Impreza WRX
This is a nice setup if you dont have access to removeable headrests...
But if you do, another simple solution is to get a peice of PVC pipe, drill 4 holes where the removeable headrest's poles can slip through and drill a hole in the middle with a camera bolt sticking up. Easy, and under $8!
jc8587 is offline   Reply With Quote
Old 11-06-2009, 05:51 PM   #6
pete_falcone
Member#: 123330
06 Pedosoob
NJIC (2004-2009)
That's a nifty setup, but jc is right. Take advantage of the headrests. My buddy did a home depot-style setup for the same price and it's very effective.
This setup would definitely not be allowed in some of the sanctioning bodies I run with.
pete_falcone is offline   Reply With Quote
Old 11-07-2009, 04:37 AM   #7
Bueller
Member#: 154696
That is not safe, even with helmets on. That should not pass tech at any event.
Bueller is offline   Reply With Quote
Old 11-07-2009, 03:38 PM   #8
leecea
Member#: 37359
2003 WRX (Sedan)
I attach a monopod to the passenger seat via the headrest. It's not quite centered - closer to the passenger side - but lets me get a pretty good shot out the windscreen.
http://home.comcast.net/~leecea/misc/monopod.htm
leecea is offline   Reply With Quote
Old 11-08-2009, 10:41 PM   #9
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Seriously? It terminates behind the seats and is bolted into the car in four locations. How is that unsafe in any way?
Old 11-08-2009, 11:03 PM   #10
cooleyjb
Member#: 55727
#533 Spec Racer Ford
In a big impact your seat could deform and the mechanism that holds the back of your seat could fail and you have a nice spear sitting just behind your head that is well bolted into the car.
cooleyjb is online now   Reply With Quote
Old 11-09-2009, 02:01 AM   #11
Bueller
Member#: 154696
Because it has the potential for a catastrophe. Anything can happen, and when it happens, are you seriously going to trust having that contraption bolted above you on the inside of your car a few feet from your body? Furthermore, you dont have rollover protection. Now use your imagination, and imagine what can happen. Assume the worst. Beyond that, OEM seats are designed as such so that if your roof collapses in a rollover, your seats collapse back so that you have a chance to survive when your roof collapses onto you. When that happens, what do you suppose that contraption of yours is going to impale into? Like i said, assume the worst, and the catastrophic scenarios are pretty much endless. Long story short, get rid of that thing.
Old 11-09-2009, 03:30 AM   #12
AnthonyA182
Member#: 59990
2003 Bugeye Wagon
so what is the best solution if you have seats WITHOUT a detachable headrest??
AnthonyA182 is offline   Reply With Quote
Old 11-09-2009, 08:50 AM   #13
cooleyjb
Member#: 55727
Suction cup mounts on a window.
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 09:24 PM.
