Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 11-03-2009, 10:41 AM   #26
Pavlo
Member#: 23015
95-> GC8
Black, blue and blue
On my own car it probably gets 40 seconds on the starter to prime the oil system on an oil change, it would get this probably 8 times a year, and it hasn't been a problem, the motor barely gets warm to the touch, certainly not hot. The current drawn by the motor will be much less with the plugs out than in. I wouldn't crank it for so long with the plugs in, the little battery wouldn't take it for a start.
Pavlo is offline   Reply With Quote
Old 11-03-2009, 03:58 PM   #27
Merp
Member#: 199106
red Le Tour 700 5mt
E85 HTA68 STi Wagon
KillerB, those figures are starter rpm, not engine rpm. Experience with electric motors, yea, sure.
Merp is online now   Reply With Quote
Old 11-03-2009, 05:10 PM   #28
gto7419
Member#: 44256
2002 WRX Wagon
KillerB - think about just starting the car without priming. you now have load at all bearing surfaces - with oil still not there to replace the engine lube you are displacing.
Priming without load allows oil to reach the passages. Although it might be a small amount of oil, it decreases the risk of the bearings being damaged when there is load. Plus, pressurizing passages that already have 2.1+ psi is bound to happen sooner than trying to pressurize completely empty oil passages.
gto7419 is offline   Reply With Quote
Old 11-03-2009, 08:28 PM   #29
Merp
Member#: 199106
red Le Tour 700 5mt
E85 HTA68 STi Wagon
Also, the unloaded cranking is somewhere around 500 engine rpm depending on the starter gear ratio, so it is not only less load on the bearings, it is also a similar amount of revolutions, at a lower speed, hence why it takes longer to get up to pressure.
For a daily driver, I'd much rather have a slight chance of burning out a starter than spinning a rod bearing.
Old 11-03-2009, 08:37 PM   #30
the suicidal eggroll
Member#: 51961
2005 STi
2001 Nissan Sentra
Originally Posted by Merp View Post
Also, the unloaded cranking is somewhere around 500-600 engine rpm, so it is not only less load on the bearings, it is also a similar amount of revolutions
How is 1 second at 1500 RPM a similar amount of revolutions as 45 seconds at 600 RPM?
the suicidal eggroll is online now   Reply With Quote
Old 11-03-2009, 09:00 PM   #31
Merp
Member#: 199106
red Le Tour 700 5mt
E85 HTA68 STi Wagon
How is 1 second at 1500 rpm anything like what we've been discussing?
I've never done it, so I can't comment with certainty, but those who have started unprimed motors said 5 seconds or so at nearly 2000 rpm.
2k*5 = 10k/60 = 166 revs is similar to 0.5k*30 = 15k/60 = 250 when you consider the life in revs of a motor, and the fact that it was previously stated to be nearly thirteen times that difference at 30s, ~6 @ 15.
After a closer look at the manual, it looks like the ratio is around 9 or 10:1, meaning even lower unloaded rpm that I had thought.
Old 11-03-2009, 09:22 PM   #32
Member#: 51961
2005 STi
2001 Nissan Sentra
I was under the impression that it took about 1 second for pressure to build, maybe that's not the case.
What do you think about the cam companies that specifically state to NOT crank the motor like this before starting on a fresh build, that you should start the car up instantly and bring it straight to 2-3k RPM to get oil to the mating surfaces as soon as possible.
Old 11-03-2009, 09:34 PM   #33
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Buy an accusump
wrxsti.l is offline   Reply With Quote
Old 11-03-2009, 09:39 PM   #34
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Your're correct... My bad, and I took those figures from the non-turbo page so lets fix it. These are for an STi:
No Load = 2,860 RPM (or more) starter speed --> 9 teeth on starter pinion, 120-ish (I think) teeth on flywheel = 220 Engine RPMs
Load = 860 RPM = 67 Engine RPM... Can this be right?
Anyone got a flywheel to count the teeth on? Or happen to KNOW how many teeth? I can't find it in the service manual and these numbers seem way low!! Once we get this we can put the topic to rest.
It looks like engine RPMs, even with no load, would be way below where the pump is efficient. If the Engine is truly spinning this slow it no wonder it takes so freakin long to to get the 2 PSI light to go off.
Old 11-03-2009, 09:40 PM   #35
Merp
Member#: 199106
red Le Tour 700 5mt
E85 HTA68 STi Wagon
It does seem a bit low, could have been whatever test method they used to grab those specs. I'd suspect the actual loaded cranking is somewhere between 100-150rpm just based on typical cranking numbers for other cars, but it will vary with the type of motor and starter.
I think I might have a FW in the garage, I'll check it if nobody chimes in.
Regarding the cams, I'd call them and talk to their engineers.
fwiw, after an unloaded prime, I get plenty of pressure in the heads, enough to discover a leaky avcs banjo last time. So I don't think its as much an issue of getting the cams lubricated as it is running them in at the elevated rpm.
In that case, it'd probably be best to prime/pressurize by some other means. Accusump would be a great choice.
Old 11-03-2009, 10:03 PM   #36
Member#: 51961
2005 STi
2001 Nissan Sentra
Here you go:
http://www.thesuicidaleggroll.com/hosting/IMG_0070.jpg
Old 11-03-2009, 10:14 PM   #37
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
124 teeth
Old 11-04-2009, 08:47 AM   #38
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by williaty View Post
124 teeth
OK so then the numbers I posted with my 120 teeth FW guestimate will be a touch lower.
I honestly had no idea the motor cranks THAT slowly. Good thread.
Old 11-04-2009, 10:40 AM   #39
48mpg
Member#: 58405
2004 Element GT65'd
Hydra, Hydramist'd STi
too bad there is no real place for suby engines to have one of these
http://paceperformance.com/index.asp...&ProdID=113715
48mpg is online now   Reply With Quote
Old 11-04-2009, 01:53 PM   #40
Gixxer1K
Member#: 81631
BC 272s HTA68
Sounds like a right angle impact wrench will work great then, since it should turn it over around 2000 rpm.
Gixxer1K is offline   Reply With Quote
Old 11-04-2009, 01:54 PM   #41
Gixxer1K
Member#: 81631
BC 272s HTA68
I think that's legit. Why spin the cams if cranking isn't going to get oil pressure up there quickly.
Old 11-09-2009, 12:14 AM   #42
BAN SUVS
Member#: 28685
1993 L wagon
swapped w/ 2001 OBS
Just out of curiosity, is there any indication anywhere that a few seconds of "dry" running before the oil primes are harmful to an engine that was assembled properly with lube? Or is this much ado about nothing?
BAN SUVS is online now   Reply With Quote
Old 11-09-2009, 12:46 AM   #43
CKxx
Member#: 33458
1988 Justy 1.2L 4WD
2002 WRX 2.1L AWD
My non-professional opinion is that w/o plugs the starter can crank for quite a while before you do damage. Just listen to it...
CKxx is offline   Reply With Quote
Old 11-09-2009, 11:54 AM   #44
soon2bblackongold
Member#: 81102
01' BMW K1200RS
90'Maco Red Camry GST FTW
I agree
I know the Kelford installation instructions specifically state to NOT crank the motor over and over and over without firing to build up oil pressure, because it takes too long and you'll do more damage to the contact surfaces than if you just fire it up dry (well, not dry, since you have the assembly lube on there).
I mean it takes how long to get oil pressure on a fresh build starting dry? 1 second? At 1500 RPM that's 25 revolutions. I'm 100% sure that cranking the car for 15 seconds at a time, 3 separate times, is a LOT more than 25 revolutions, and the end result is still only 2-3 psi of oil pressure.
+1234
soon2bblackongold is offline   Reply With Quote
Old 11-10-2009, 12:27 AM   #45
smoky
Member#: 221439
I had the same problem tonight, no pressure with the starter even after 1 minute (no spark plug). Since it is my first build I didn't want to start it with no oil pressure, too risky...
I had an idea that solve the issue, let's build pressure in the crank case to help the oil pump. You need to know your crankcase ventilation system, but that's pretty easy with the help of someone. In my case I had hoses for my catch can, I simply capped the head breather (at intercooler) and then plug the crank breather to the air compressor at 40 psi. Pushed a bit of air in the crank and made sure there was no leak. Then I started the car while my father was pushing air in the crank, it took 2 sec to get the oil light and about 10 sec to get 75 psi. With that trick there is no reason to not prime your engine all the time.
It is late, so we'll wait until tomorrow to fire it up!
Hope this help.
smoky is offline   Reply With Quote
Old 11-10-2009, 12:33 AM   #46
BAN SUVS
Member#: 28685
1993 L wagon
swapped w/ 2001 OBS
Sure there is, and it's been outlined in posts above. The reason is that you spin the engine fewer times with no oil by just firing it up, than by trying to "prime" the oil pump.
Old 11-10-2009, 05:35 AM   #47
Merp
Member#: 199106
red Le Tour 700 5mt
E85 HTA68 STi Wagon
Try actually reading the thread next time.
First of all, it's been determined that the starter spins much slower than cold idle speed, so the number or revolutions is close, if you run the math on the supposed 10 seconds needed while pressurizing the crankcase, it's actually much less revolutions than a cold start.
Second of all, the problem isn't so much the amount of revolutions as it is the amount of bearing load without oil flow. No plug cranking only loads the mains with gravity, and the rods with inertia loads, vs both compression and combustion loads during starting.
1. Cranking should be done in one shot provided the starter doesn't heat up (mine didn't).
2. 1 second? 1500rpm? Not likely.
3. End result for me was 30psi, and great looking bearings immediately afterwards.
4. Again, the Kelford instruction depends if the dominating factor is lubrication or the need to run the cams in at a certain RPM.
Old 11-10-2009, 07:02 AM   #48
Pavlo
Member#: 23015
95-> GC8
That is exactly what I recommended earlier in the thread as a possible solution to the "non-priming" engine. And lo and behold it works!
Hope this help.
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 07:28 PM.
