Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 11-08-2009, 03:28 PM   #1
subie420
Member#: 110142
02 black impreza
Default Car pulling in Third. High Speed wobbles.Please Help
I replaced the bearings in my LR tire about three months ago the tech said he will probably need to replace the hub but didnt. I have no idea what is going on but in third the the car seems to pull to the left and gets wobbly then when i shift it straightens back out. Also at high speeds, especially when turning right i would say above seventy the car seems very unstable and moves around alot. Its a 2002 2.5rs. Please if anyone knows whats going on, i figure maybe an engine or tranny mount, or something to do with the wheel. Thanks
subie420 is offline   Reply With Quote
Old 11-09-2009, 12:30 AM   #2
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
try asking in the suspension forum. they could probably give you a couple things to look at to start.
RaceFaceXC is offline   Reply With Quote
Old 11-09-2009, 06:57 PM   #3
subie420
Member#: 110142
02 black impreza
ok thanks
Old 11-09-2009, 07:08 PM   #4
GrimmSpeed
Member#: 136396
96 L 10 Genesis 99RS
It's kinda weird that it's only happening in the 3rd.
When was the last time the wheels were balanced and your alignment was done? I would check your axel nut too and make sure it's still in place. Also, get all of the wheels off the ground and see if they have any play.
Mike
Old 11-09-2009, 07:24 PM   #5
Hedbergsuby07
Member#: 160840
2007 impreza
urban gray scoooped
agreed alignment is your friend this might i have a feeling this would
Hedbergsuby07 is offline   Reply With Quote
Old 11-09-2009, 07:28 PM   #6
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
Mike
i doubt its a transmission related problem, i think it has to do with the suspension/alignment @ speeds that occur in 3rd gear during typical acceleration, or possibly something to do with the drivetrain on the output side of the trans or after.
Old 11-10-2009, 11:43 AM   #7
snoopyone8
Member#: 42970
1998 2.5RS DOHC
2000 2.5RS
When I bought my 98 it did the same thing. I didnt address for about a year(4 seasons in the North East). In dry conditions it did exactly what you said, in wet or icy/snowy conditions it was absolutley DIABOLICAL!!!
Long story short....right rear was out of alignment--too much toe-in, it effected accelleration, braking and turning, especially in slippy conditions.
It became a whole new and stable car after that was sorted!!!
-adam
snoopyone8 is offline   Reply With Quote
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 08:52 AM.
