Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 11-17-2009, 11:28 PM   #1
STI_KLR
Member#: 189660
'02 WRX
Element Tuning Race Team
Subaru Stars STI_KLR's Built 2.5L Hybrid
How she sits right now:
Ok, here's a quick run down to catch people up:
February 7th: Cracked a ringland in the EJ20 in cyl #4
Feb-May: Slowly build up the 2.5L Hybrid (myself) with a brand new EJ257
End of May: Motor cranks up first try; 1,xxx mile break-in begins
June: Blow 2nd gear in the 5-speed
July: Replace 5-speed with JDM 6-speed
September: Break the bell-housing on the 6-speed
November: 2 cracked pistons lead to rapid oil consumption to spin rod bearings in cyl #2
# of times WRX has been towed since February: 8 and counting.
PRESENT DAY:
The WRX is currently at IAG Performance in Westminster, MD where all of the work is being done. The rod and crank were completely toast, so here is the work that has already been done. The BOLD parts are brand new, the rest are parts I already had.
EJ257 Shortblock
EJ20 Heads
OEM STI Headgaskets
ARP studs
08/09 STI Nitride Crank
SKAT Rods (1st motor IAG is using these rods in)
Manley 99.5mm Pistons
ACL Race Main/Rod Bearings
11mm Oil Pump
Custom IAG Oil Catch Can
STI Cams
Shimless Buckets
Gates Racing Timing Belt
New Oil Cooler
New WRX Oil Pan
DW 850cc Injectors
FP 20g 8cm^2 Turbo
Invidia Catless V2 Downpipe
P&L HighFLO Intake
IAG Oil Catch Can
TGV Deletes
TiAL 38mm EWG
Exhaust Mani/UP/DP/Dump Tube all thermal coated and DEI heat wrapped
Hallman Pro-RX MBC
NGK 1-Step Colder Plugs
Grimmspeed Thermostat
Grimmspeed 3mm Phenolic Spacers
Grimmspeed 3-Port BCS
Walboro 255 Fuel Pump
APS Turbo Inlet
CXRacing Aluminum Radiator
Group-N Motor Mounts
Group-N Tranny Mount
I know I'm forgetting some things right now, but it's late, i'm tired, so i'll update this tomorrow
-Andrew
STI_KLR is offline   Reply With Quote
Old 11-17-2009, 11:36 PM   #2
STI_KLR
Member#: 189660
'02 WRX
First off, the car:
The bad:
Old 11-17-2009, 11:36 PM   #3
STI_KLR
Member#: 189660
'02 WRX
Picked up an Invidia V2 DP. I wrapped it and coated it as well.
Old 11-17-2009, 11:37 PM   #4
STI_KLR
Member#: 189660
'02 WRX
savin'
Old 11-17-2009, 11:37 PM   #5
STI_KLR
Member#: 189660
'02 WRX
might need it.
Old 11-17-2009, 11:37 PM   #6
STI_KLR
Member#: 189660
'02 WRX
just in case.
Old 11-18-2009, 02:08 AM   #7
STI_KLR
Member#: 189660
'02 WRX
ok, another.
Old 11-18-2009, 02:11 AM   #8
richy_21
Member#: 58670
2005 got muuuuu?
mine!
richy_21 is offline   Reply With Quote
Old 11-18-2009, 02:25 AM   #9
STI_KLR
Member#: 189660
'02 WRX
hahah do you ever go to sleep?
Old 11-18-2009, 03:03 AM   #10
SlverEJ20
Member#: 157158
05 WRX stage 2
Damn Andrew, do you think both motors now went because of the tune?
SlverEJ20 is offline   Reply With Quote
Old 11-18-2009, 03:38 AM   #11
STI_KLR
Member#: 189660
'02 WRX
Yes sir I do. He unfortunately is the only common denominator in both of these motor failures. Both gone due to detonation? HMMMMMM...
Old 11-18-2009, 10:32 AM   #12
wrxej205
Member#: 188454
02 ej207+6speed
psm
judas priest martha, this ones gettin outta control.
wrxej205 is offline   Reply With Quote
Old 11-18-2009, 11:09 AM   #13
SlverEJ20
Member#: 157158
05 WRX stage 2
what was the A/F ratio set at?
Thats a shame man, I was about to buy a cable and let them tune me soon also since I thought the first motor was a freak accident. BUT after seeing both of your motors go I'm just going to save up and probably go to DPS.
O and is your 16g done?, if not is it up for sale......I had to ask
Old 11-18-2009, 11:37 AM   #14
scprs
Member#: 172359
2005 STi
who did you tune with originally?
scprs is offline   Reply With Quote
Old 11-18-2009, 11:40 AM   #15
STI_KLR
Member#: 189660
'02 WRX
Wirelessly posted (STEALIN Y0 POSTZ!: Mozilla/4.1 (compatible; MSIE 6.0; ) 400x240 LGE VX10000)
i wont put the tuners name out in this thread so pm me if you still want to know. yea kahlil the 16g is up for grabs. lmk if you want it
Old 11-18-2009, 11:42 AM   #16
JWDWRX
Member#: 126942
2004 DPS Hybrid WRX
Darkness
Holy crap. Thats insane..GL to ya.
JWDWRX is offline   Reply With Quote
Old 11-18-2009, 12:40 PM   #17
STI_KLR
Member#: 189660
'02 WRX
im assuming thats a good thing
Old 11-18-2009, 12:41 PM   #18
STI_KLR
Member#: 189660
'02 WRX
what's insane? the damage or the build lol
Old 11-18-2009, 01:06 PM   #19
Maxwell Power
Member#: 190729
Are you going to have the combustion chambers in the head modified to improve power and reliability?
People try arguing with us all the time about how much better it is to fix the combustion chamber on hybrid builds. Well we proved it. 40whp more on pump gas than the previous tune on meth/water injection.
Please, do the work. Not doing it is what causes so many hybrids to fail. Even an awesome tune can't overcome the poor mechanics of the 2L chamber on a 2.5L bore.
Maxwell Power is offline   Reply With Quote
Old 11-18-2009, 01:26 PM   #20
STI_KLR
Member#: 189660
'02 WRX
Want to elaborate a little bit on how you "fix" the combustion chamber?
Old 11-18-2009, 01:28 PM   #21
wrxej205
Member#: 188454
02 ej207+6speed
psm
get it machined out alittle. i skipped this on my build and am having second guesses if i should rip it apart to redo it.
Old 11-18-2009, 01:31 PM   #22
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
inquiring minds want to know.
maxpowr is offline   Reply With Quote
Old 11-18-2009, 01:37 PM   #23
STI_KLR
Member#: 189660
'02 WRX
Maybe I need to get on the horn with IAG before they assemble the heads. I had asked when I was there yesterday if it was necessary to P&P and "fix" the chamber but we didn't talk too much about it.. so, I guess the ball is in their court.
Old 11-18-2009, 01:37 PM   #24
wrxej205
Member#: 188454
02 ej207+6speed
psm
"not getting your 2.0 heads matched to the bigger bore. leaves i believe a tiny lip hangin over into the combustion chamber. which then creates uneven detonation aka dead spot on your piston. also when combusting instead of it being dead center of the piston it will vary anywhere on the face of your piston"
so i was told by someone.
Old 11-18-2009, 04:51 PM   #25
STI_KLR
Member#: 189660
'02 WRX
I got side tracked and forgot to call IAG Guess it'll have to wait until tomorrow.
IAG Built 2.5L Hybrid Bugeye FP 20g Turbo JDM 6-Spd Jorge Tuned STI_KLR Proven Power Bragging 52 01-10-2010 09:52 PM
Reliablity Of 2.0l heads on a built 2.5l block? rsw0124 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-30-2009 05:47 PM
FS in VA: 2002 WRX with built 2.5L hybrid and GT32 Rogan MAIC Private Classifieds 31 08-11-2008 05:52 PM
Who is using AP 2.0 for a 2.5l hybrid? Acostafan AccessPort 2 06-18-2007 03:14 PM
Andrewtech built 2.5L hybrid w/ 4EAT rice wrx Proven Power Bragging 8 01-16-2007 03:32 PM
