Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 11-03-2009, 01:56 PM   #1
g_man80
Member#: 93466
'99 Forester
Default '99 2.5L 4eat, 150k - Hesitation/Misfire/Stumbling
I've been searching here, subaruforester.org, and scoobymods the past few days, but haven't gotten far. The car is a '99 Forester auto with 150k miles.
Going from closed throttle to 1/4 or more open the engine will hesitate and stumble for 5 seconds or so and then will accelerate normally. It does this hot or cold and from a stop or coasting (at speed I let off the gas for a few moments and when I get back on it the jerkyness occurs). Constant cruising is fine and it will run up to redline ok. Gas mileage is pretty bad and it doesn't have a ton of power (it hasen't been great at either the past few years).
Pulling out into traffic is a little sketchy as you can't give it too much gas or it hesitates. If you accelerate VERY gently it's smooth.
Idles fine (cold or hot). Ran a few tanks of gas (different stations and grades), so it's not bad gas. Misted the coil pack in the dark last night to check for sparks and nothing was seen. No cel. Replaced knock sensor last year.
I was thinking front O2 sensor, although it happens hot or cold. Maybe fuel filter? I the fuel pump failing? MAF sensor (no cel though)? Bad wires/plugs (can I check these before replacing)?
Any suggestions? TIA
g_man80 is offline   Reply With Quote
Old 11-03-2009, 02:46 PM   #2
Panops145
Member#: 200310
1999 Impreza 2.2l
do u think it could be a tranny problem? or possibly a misfire in possibly two of the cylinders because it lags that bad...is ur check engine light on?
my engine was misfiring with 2 cyl
Panops145 is offline   Reply With Quote
Old 11-03-2009, 03:40 PM   #3
Checkers
Member#: 188440
LOL must
die
Replace the plugs first, check for fouling or gaps that are out of spec. Then get new plug wires. Then coil pack, go up the ignition system.
I would bet on one of the above being the problem. Get new plugs, go from there.
It might be something more complicated, but I've had similar issues with my RS that were nothing more than either plugs or wires. Costs $40 and an hour to change both.
Checkers is offline   Reply With Quote
Old 11-03-2009, 03:55 PM   #4
mlangejan
Member#: 205567
2000 impreza rs 2.5
pearl blue
if its not your ignition system it very well could be a fuel filter that is restricting flow or your fuel pump.
i had the same problem in my rs and it was finally cured after i put a 255lph fuel pump in the stock pump was no longer keeping up with the volume required to supply the system I've seen it happen in a couple of other subies as well
mlangejan is offline   Reply With Quote
Old 11-04-2009, 12:20 PM   #5
g_man80
Member#: 93466
'99 Forester
Thanks for the input everyone. I was hoping to avoid replacing random parts, but it sounds like that's the only way to narrow it down. I'm going to start with plugs and fuel filter.
Also, it started about a week ago and seems to be getting worse each day or two.
Old 11-04-2009, 12:47 PM   #6
01LGT
Member#: 224816
2001 Legacy GT
I had a similar problem although it did it the worst when it was hot... Upstream O2. But when was the filter changed last? same for the plugs? upstream o2 is about $63 at napa. my experience it would lurch and sputter, it would hold at low rpm then take off. compare the costs with the problem if it doesnt fix it then u have to pay more, if it does fix it u will be paying less.
01LGT is offline   Reply With Quote
Old 11-04-2009, 09:30 PM   #7
g_man80
Member#: 93466
'99 Forester
Maybe fixed. Changed the fuel filter and plugs this afternoon. Changed the fuel filter first and it did nothing. Next were the plugs and I think they did the trick. Acceleration seems smooth and consistant, although it's only been about 6 miles. Time will tell, but for now I'm going to say the new plugs fixed the problem. I'll update the thread if the hesitation returns.
Old 11-19-2009, 08:42 PM   #8
g_man80
Member#: 93466
'99 Forester
The problem still exists. Plugs and fuel filter did nothing. No fault codes. I think I heard a few backfires if I let off the gas for a few seconds and got back on it hard. Gave up and took it to a garage. I don't want to keep replacing components and chasing the problem. They checked the easy stuff this afternoon (scan, O2 sensors, etc) and found nothing. Tomorrow they are going to do more testing. I'll keep the thread updated.
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 07:49 PM.
