Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 11-08-2009, 03:41 PM   #1
wtroyster
Member#: 182263
2008 WRX
Question HP Gains
Ok, its been a while since i've had a subie so i ned some input please. I want to reach at least 275 hp to the wheels on my '08 WRX. I will be going to Colordo Springs, Co to MAC Autosport where they have a Dynojet 248/224. I live in Rapid City, SD which has an elevation of about 3,200 ft, however I will be moving to Warner Robins, GA where the elevation is approx 300 ft. I usually use 90 octane but i do have access to 93, and i am def not opposed to a FMIC, whatever it takes foe me to reach my goal. I currently have a Perrin DP with a high flow cat, and a perrin light weight crank pulley. I would very much appreciate any input. Thanks in advance.
Travis
wtroyster is offline   Reply With Quote
Old 11-08-2009, 03:44 PM   #2
Byzantium
Member#: 207826
Correct Fitment Crew #034
You're gonna need a larger turbo (VF52 or larger) and you're gonna want to start using 93. Don't waste your time with a FMIC for such a minor upgrade.
Byzantium is online now   Reply With Quote
Old 11-08-2009, 03:51 PM   #3
424wrx
Member#: 171948
08 stg3 wrx
rally blue
Travis
are you tuned? what are you using? you mentioned nothing about a tune. ive never seen a map for 90 octane fuel.
Old 11-08-2009, 05:47 PM   #4
Audiosavvy
Antique Roadshow groupie
Member#: 150794
2.3 built bugeye
In it to win it
View Member's Myspace Profile
You will never see that power on the stock turbo. Also, why are you using 90 octane when you have access to 93?
Audiosavvy is offline   Reply With Quote
Old 11-09-2009, 12:00 PM   #5
wtroyster
Member#: 182263
2008 WRX
The car is not currently tuned. The person that had the car before me did have an Access Port hooked up. As far as the 93 goes, the gas station was down for pump replacment, but it will be up and running in no time. Where would reccommend I look for an upgraded turbo? Theres so many sites! Thanks all.
Old 11-09-2009, 12:01 PM   #6
Byzantium
Member#: 207826
Stay completely (100%) out of boost until you get retuned.
Old 11-09-2009, 12:12 PM   #7
ADAS1223
Member#: 159853
2005 concaved cusco
www.subieworld.com
^ or until you can get 93. search the private classifieds here for a turboz
ADAS1223 is offline   Reply With Quote
Old 11-09-2009, 03:06 PM   #8
20SubieDude05
Member#: 127380
2009 WRX Sedan
WR Blue Mica
I live in Colorado Springs, and MAC is in Littleton/Denver.
20SubieDude05 is offline   Reply With Quote
Old 11-09-2009, 03:27 PM   #9
Beaverboy
Member#: 44501
ZMax Dragway
Concord, NC. See SE Forum
The VF52 from the '09+ WRXs will bolt right up and work for your goals. Check out the classifieds for used ones.
Beaverboy is offline   Reply With Quote
Old 11-09-2009, 03:57 PM   #10
neversummer489
Member#: 153729
RIP 02 341 whp WRX
96 A4 :(
Shut up.
There is no point it trying to scare someone in the "omg I need a tune every time I loosen or tighten a bolt!!" mentality. Everyone likes to say they tune for every mod but not everyone has 350 bucks to add to every mod they do. I have seen an 04 Wrx NO TUNE run a 12.99 at PIR. So stuff it with the whole tune constant crap.
The fact is you shouldn't go smash on the car with things that change the way the car runs however you can drive it and enjoy your boost. As for your power goals. You need to decide if this will be your end goals. Or at least consider it, maybe go with a new turbo and just keep it conservative and make your 275 goals, and when you are ready for more add some bolt ons and go more aggressive
neversummer489 is offline   Reply With Quote
Old 11-09-2009, 04:06 PM   #11
Byzantium
Member#: 207826
Originally Posted by neversummer489 View Post
Shut up.
There is no point it trying to scare someone in the "omg I need a time every time I loosen or tighten a bolt!!" mentality. Everyone likes to say they tune for every mod but not everyone has 350 bucks to add to every mod they do. I have seen an 04 Wrx NO TUNE run a 12.99 at PIR. So stuff it with the whole tune constant crap.
Because preaching engine safety is a dumb amirite?
I knew someone who ran a completely untuned twin turbo 350Z (he installed his Greddy kit a week earlier) at the track as well. A month or 2 later he was without an engine and this took his car off the road for just over a year while he saved up for a near $10k engine replacement.
Old 11-09-2009, 04:12 PM   #12
woodys77
Member#: 192147
2007 STI EfiLogics
407whp 402wtq fpgreen
Shut up.
There is no point it trying to scare someone in the "omg I need a tune every time I loosen or tighten a bolt!!" mentality unless they have an 07 sti. Everyone likes to say they tune for every mod but not everyone has 350 bucks to add to every mod they do. I have seen an 04 Wrx NO TUNE run a 12.99 at PIR. So stuff it with the whole tune constant crap.
fixed
woodys77 is offline   Reply With Quote
Old 11-09-2009, 04:50 PM   #13
boostdog
Member#: 149752
07 wrx tr
rr tuned stg2 12.9@103mph
^^ this or other turbo upgrade. /thread
boostdog is offline   Reply With Quote
Old 11-09-2009, 06:24 PM   #14
neversummer489
Member#: 153729
RIP 02 341 whp WRX
96 A4 :(
That's an awesome story going from n/a to f/I and no tune yep bad idea. However he has a crank pully and a downpipe. You are comparing apples and oranges. I drove 6 months no tune 18 psi on a vf39. And I had an 02 Wrx it ran fine still does. I don't think it's a good idea to run no tune with significant upgrades main reason being you don't get nearly the result as you will with a tune.
Long story short your friend is an idiot and you don't need to tune for a dp unless you feel like spending almost 800 for a downpipe plus a tune.
Old 11-09-2009, 06:28 PM   #15
the suicidal eggroll
Member#: 51961
2005 STi
2001 Nissan Sentra
You had an 02, you can run the 02 with mods and no tune because the factory tune was very forgiving. The newer models (04+) are not nearly as forgiving, and you can cause serious damage by putting on certain mods without a tune, mostly due to unstable boost and the CL/OL Delay causing you to stay in CL (14.7 AFR) under heavy boost. The CL/OL issue is why there have been SO many 07 STis with broken ringlands, even stock.
Old 11-09-2009, 06:30 PM   #16
Byzantium
Member#: 207826
Long story short I'm an idiot
Well, that's resoundingly clear. Just because you don't go about things the correct way it doesn't mean that that's the way everyone else should do it.
Old 11-09-2009, 06:53 PM   #17
v8subie
Member#: 126374
**** apart and
install it backwards.
interwebz is serious bizness on nasioc.
v8subie is offline   Reply With Quote
Old 11-09-2009, 07:10 PM   #18
neversummer489
Member#: 153729
RIP 02 341 whp WRX
96 A4 :(
I took car of my car it never ran unsafe. I made 341 whp on a stock trans and internal 02 Wrx I think I did ok. As for the op the mods he has as of right now do not require a tune nor does it put him in a adverse situation if he makes any boost. Your original post was misguiding you have yet to give proof to your statement. Untill you do so I don't see why you continue to post in this thread... If you would like I'm sure I can get you in contact with my tuner that advised me to drive my car to the shop on a stock ecu with 820 cc inj 38mm ewg full catless exhaust hta68 turbo all fueled by e85, also with the tgv's freshly deleted. Btw his shop is 60 miles away his only advice was don't drive like an ass hat. So go ahead and run your mouth, your still wrong and wasting the op's money
Old 11-09-2009, 07:12 PM   #19
AWDBrad
Member#: 224866
2007 Subaru
Grey
Meth!!
AWDBrad is offline   Reply With Quote
Old 11-09-2009, 07:24 PM   #20
Byzantium
Member#: 207826
I highlighted the piece of advice that the tuner gave you. This same exact advice is what i gave in my 1st reply. If you don't want to take into account the long standing and well known issue that Suicidal Eggroll explained for you, I don't what else there is to say. I can explain the exact same problem in as technical or as layman's terms as you want, but you're still going to tell me I'm somehow wrong.
You are potentially wasting the OP's money and time, and a lot more of it it too considering a tune is much less expensive and time consuming than a shortblock replacement or rebuild.
Old 11-09-2009, 07:26 PM   #21
wtroyster
Member#: 182263
2008 WRX
Thanks for all the input, im def gonna look into a vf52 asap.
Old 11-19-2009, 09:15 PM   #22
SylnceR
Member#: 177308
2006 EVO IX
GUNMETAL
if u want power u shoulda got an Evo
u can get 94oct at the station next to sally o'mallys and i heard e85 over by the westside dq.(havnt chekt that out yet) for the numbers you want id get 18g, bigger tmic(or fmic), fuel sys, and of course intake/exhaust.
you should hit 300 easy.
SylnceR is offline   Reply With Quote
Old 11-19-2009, 09:27 PM   #23
spike93
Member#: 190292
2005 stage II wrx
CGM
Originally Posted by AWDBrad View Post
Meth!!
not even once
spike93 is offline   Reply With Quote
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 08:35 AM.
