Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Go Back   NASIOC > NASIOC Technical > Factory 2.0L Turbo Powertrain
Old 11-06-2009, 03:26 AM   #1
xxej20xx
Member#: 192918
2002 wrx
platinum silver
View Member's Myspace Profile
Default Please Help: Another Stuttering Problem
I have a 2002 wrx with about 95k miles on the ticker. I bought the car about a year ago and it had a problem where it would stutter at about 4500 rpms, more or less. It will not go past 4500 rpms. It just keeps making a da da da da da da da da sound. Its completely stock with only a cobb uppipe. At 1/2 throttle it may get to about 6000rpm in nuetral, but wot just fails at 4500 rpms no matter how long I hold it. The car used to have this problem and I put a different bov and a short ram intake. This solved the problem and the car ran fine until a cracked piston 3 months down the line. The engine was just rebuilt, and with the rebuild the problem returned. I pulled a tgv stuck shut code but just cleared it and got new tgvs. I also have a heater sensor circuit code as the hole is plugged due to the uppipe. The only other thing I may add is I don't know what the guy who had the car before me did to the car as far as tune, but then again I don't know how an intake and bov remedied the problem before. Maybe the car is tuned stage 2 or something? Also the car is looking to run about 14 to 15 psi. Idk if that helps. Any help would be greatly appreciated.
-Thank you in advance
Eric
xxej20xx is offline   Reply With Quote
Old 11-06-2009, 12:17 PM   #2
blakkboxer
Member#: 167244
03 WRX MBP
almost18g'd CFC#029!
blakkboxer is offline   Reply With Quote
Old 11-06-2009, 01:29 PM   #3
xxej20xx
Member#: 192918
2002 wrx
platinum silver
Default ^^^^^
Thanks for the link. But I don't see how cleaning my IAC would help me. The car has a healthy idle, and it seems the IAC only adresses idle problems....
Old 11-06-2009, 04:40 PM   #4
xxej20xx
Member#: 192918
2002 wrx
platinum silver
Default Um help
Come on. Nobody knows? I'm sure there's a lot of gurus and specialists out there who can chime in on this. Also may post a video later.
Old 11-06-2009, 07:38 PM   #5
spinningcain
Member#: 176490
2004 WRX VF39
Could be the Tune How much boost are you hitting when it cuts out? You could be hitting the boost cut. Give the maf a good cleaning and reset
spinningcain is offline   Reply With Quote
Old 11-06-2009, 07:45 PM   #6
xxej20xx
Member#: 192918
2002 wrx
platinum silver
Old 11-06-2009, 07:54 PM   #7
xxej20xx
Member#: 192918
2002 wrx
platinum silver
Default ....
Old 11-06-2009, 07:57 PM   #8
xxej20xx
Member#: 192918
2002 wrx
platinum silver
I have cleaned the maf before but will clean again for good measure. I am getting boost for 10 psi in first. To around 14 in second. Maybe a bad boost solenoid? Should I put on my manual boost controller and go from there?
Old 11-06-2009, 07:58 PM   #9
tpendergraft85
Member#: 83198
2002 WRX Wagon
spark plugs?
tpendergraft85 is offline   Reply With Quote
Old 11-06-2009, 08:07 PM   #10
xxej20xx
Member#: 192918
2002 wrx
platinum silver
Originally Posted by tpendergraft85 View Post
spark plugs?
Maybe. Ill swap those out when I do my oil change today. But I'm running the same plugs I did when my car was running normal. ????
Old 11-06-2009, 09:42 PM   #11
fastwrx25
Member#: 126441
02 bugeye
spark plugs +12345
I had the same prob, stuttering ~4k+ rpm in boost. Turned out to be the plugs since I was long overdue in replacing them.
changing plugs isn't that hard at all took me around less than 1 hr first time doing it. Don't overtorque them.
plugs are a wear item. read the spark plug faq to figure out what brand, type to use. Use NGK
could also be fuel filter also.
how good have you been with maintaining the car? follow the maintenance schedule to avoid probs like this. Also have you been throwing and misfire CELs?
Old 11-07-2009, 12:29 AM   #12
02blueru
Member#: 80012
02 WRB Bugeye
Ducati Monster 620 Dark
Could also be a fueling issue. I had the same problem and turned out to be a bad fuel pump.
02blueru is offline   Reply With Quote
Old 11-07-2009, 03:05 AM   #13
xxej20xx
Member#: 192918
2002 wrx
platinum silver
I don't know if this helps but when the cars nearly empty. The car pulls like a bat out of hell. So I'm thinking bad tune? When the cars out of gas it leans enough to run right?
Old 11-07-2009, 02:25 PM   #14
xxej20xx
Member#: 192918
2002 wrx
platinum silver
Default bump
Bumppp.....any more suggestions?
Old 11-07-2009, 08:47 PM   #15
metric
Member#: 216064
02 wrx
wrb
sounds to me theres a timing issue,set the crank on tdc and make sure all the cams are timed correctly. also,verify the tgv's are staying open and not opening and slamming shut on a run,which could be the case.
metric is offline   Reply With Quote
Old 11-07-2009, 08:49 PM   #16
Haelan
Member#: 151045
2004 JBP WRX
Stage II - Monster TD04
A faulty crank position sensor has been known to cause hesitation on or after 4.5k rpm. You may want to swap with a known good sensor and see if it clears up. It's very simple to change out.
Haelan is offline   Reply With Quote
Old 11-07-2009, 09:17 PM   #17
soob noob
Member#: 220158
02 bugeye
murdered out
i changed my plugs and cleaned my maf with the maf cleaner from autozone and my stutter went away
soob noob is offline   Reply With Quote
Old 11-08-2009, 12:48 AM   #18
blakkboxer
Member#: 167244
03 WRX MBP
glad to hear problem solved, cheers!
Old 11-20-2009, 08:02 PM   #19
xxej20xx
Member#: 192918
2002 wrx
platinum silver
Bummmppp any more suggestions?
Old 11-20-2009, 08:43 PM   #20
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
^ I'll suggest some more ideas when you post what you've done to try and fix it. - j/k
Did it JUST start to happen, or has it been a problem that slowly came and went and progressively got worse? DId you make any changes lately that caused it to start?
It LOOKS like a fuel cut issue (Kind of like 02blu said above). It could be a clogged FUEL FILTER so at higher boost (Higher fuel demand) the failing pump OR clogged filter is restricting the flow of fuel... Just some thoughts.
paintbing is offline   Reply With Quote
Old 11-20-2009, 10:08 PM   #21
xxej20xx
Member#: 192918
2002 wrx
platinum silver
I've always had ths problem. Then it went away. Rebuilt engine. Same problem came back. So it must be a sensor or something that went bad then got knocked around and started to work again? Maybe? The first time the problem fixed when I hooked up a sri. Maybe it moved the maf around just enough? Could it be a bad maf? And how would I tell?
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 06:48 AM.
