#2501 |
Member#: 228860
did aquamist design the coolingmist gauge? they look strikingly similar.
#2502 |
Member#: 96204
W. Canada
Vehicle:2005 Legacy GT Atlantic Blue |
If they did, they sure fight a lot about it.
#2503 |
NASIOC Manufacturer
Member#: 110029
Vehicle:2004 Citroen Picasso Silver |
It does look similar, but we didn't designed it.
#2504 |
Member#: 143225
JDM )04 Sti Version 8 - do you have the wiring for the Pinout for HSf5???
thanks! |
#2505 |
NASIOC Manufacturer
Member#: 110029
I will check - is it the same as the european version?
#2506 |
Member#: 143225
im honestly not too certin, but they are both right hand drive twin scroll engines.
#2507 |
NASIOC Manufacturer
Member#: 110029
The injectors wires normally has a pink based colour.
#2508 |
NASIOC Manufacturer
Member#: 110029
Please take a picture of the ECU back with all the wires. I will try to match it with my collections.
Here is a generic diagram that may be useful as reference: ![]() Last edited by Aquamist; 11-14-2009 at 02:10 PM. |
#2509 |
Member#: 221364
MAIC
Vehicle:2002 Wrx EJ207 nside Wrb now with 100% more V7 |
On a 2d is it necessary to have 4mm hose and 6mm
#2510 |
NASIOC Manufacturer
Member#: 110029
Yes, the 2d uses metric size hoses - you can get them from Mc Master-Carr
#2511 |
Member#: 15822
Vehicle:1999 WRB GM6 V9 Spec C RA, recce car |
might sound as a silly question, but I don't feel like rebuilding the pump again so better ask
![]() 2D system Can I leave my pump installed (under fender) and connected to everything during the cold season of winter, if I don't intend to run it? temps can drop to -25* celsius |
#2512 |
Member#: 125450
VIC
Vehicle:Dom Built 07 Ltd DirtyWhiteGirlWhite |
Hi how do I tell if I'm having issues with the solenoid or flow sensor... I have pressure up to the solenoid but then no pressure before the injector.
#2513 | |
NASIOC Manufacturer
Member#: 110029
1. Drain the lines and pump and leave it for the winter. You can do it by empty the tank by running the system until dry. 2. Put M50:W50 mix in the system. (good for approximately -40C) |
#2514 | |
NASIOC Manufacturer
Member#: 110029
Ground the brown wire, the valve should open Flow sensor: Disconnect both end and blow through it, the gauge should register full-scale. You might need a large mirror on the car seat. |
#2515 |
Member#: 96204
W. Canada
I have looked over the vs#10 DDS3, and I am still unclear.
Is it configurable so that there will be one pin that only goes go to ground on fail-safe activation? To be more clear, I only want the failsafe active when the unit should be flowing, but the system detects it is not flowing enough (or at all). If this exists, then it would be as simple as one wire from the DDS3 to the test-connectors, and of course the appropriate tuning. If this doesn't yet exist, I STRONGLY suggest you make it happen. This would make a failsafe a piece of cake to wire up, no cutting wires to get the EBCS, just one wire to the test-connectors. |
#2516 | |
NASIOC Manufacturer
Member#: 110029
I would still advice you to go for the relay due to danger of spike and clean switching (voltage free). ![]() |
#2517 | |
Member#: 96204
W. Canada
From HFS-1 manual
Then when a fault occurs it will provide 0V output. Will that now 0V output be a negative feed to switch the relay? I know how relays work, but I always just use then as + & -. It is the whole 5V thing that has me confused. BTW the advanced system configuration in the HFS1 manual says 8v, not 5v. Also: The HFS-6 has a pot for failsafe sensitivity, I don't see such a thing in the HFS-1. Is it just set to 0.3 ms? |
