Old 11-07-2009, 07:51 PM   #151
nightcrawler60
Member#: 126438
2004 Impreza
#Winning
Originally Posted by nightcrawler60 View Post
Fender Cowls
22mm front sway, 22-24 rear sway
Front/Rear Strut Towers.
17x8.5 +45 Wheels
245/40/17 Hankook Evos
Currently running 3 turns from full soft. Going to play with it more after alignment next Friday. As of right now I can't tell the diffrence in feeling from my last set up...AGX USDM Pinks. Guess once they settle and Im aligned the fun stuff will happen.
Anyone?
nightcrawler60 is offline   Reply With Quote
Old 11-09-2009, 01:22 PM   #152
vien
Member#: 221538
2003 wrx/ylw wheels
darkness.................
subscribed
vien is offline   Reply With Quote
Old 11-20-2009, 02:29 AM   #153
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
subscribed also!!!
murrdogg24 is offline   Reply With Quote
Old 11-25-2009, 08:17 PM   #154
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
2004 WRX sedan 81k miles
5 front/ 5 1/2 rear (still on break in period)
02-03 Swift Sport springs 185f/151r
Group N tophats front and rear(02-03)
14mm camber bolts front and rear
Whiteline adjustable rear strut tower brace
Paranoid Fabrications front fender braces
Every Kartboy bushing known to man
05 STi control arms with poly bushings
Whiteline adjustable sways front and rear
Kartboy end links
17x7.5 JDM v7's with Bridgestone RE-01R 225/45/17
Alignment spec's: -2.0 f -2.0 r 0 toe
Car feels nice and stable turn in more crisp. Will probably loosen the struts up some more after a couple hundred more miles. No clunking yet. Just got alignment done today will observe and report back if any problem arise. I'm starting to think I should have gone with a spring with higher rates but wanted to retain daily drivablility. I commute 60 miles a day right now and road seem to be getting crappier here in Cali
Old 11-26-2009, 01:01 PM   #155
SVT_WRX
Member#: 164830
G61 III OVE 58e
So is the consensus the stiffer the spring rate, the more turns FFS? I know my rock hard Nexen 3000's aren't helping much. They suck!
SVT_WRX is offline   Reply With Quote
Old 11-26-2009, 01:11 PM   #156
SVT_WRX
Member#: 164830
G61 III OVE 58e
2002 WRX sedan 127,000k miles
3 FFS front/ 3 FFS rear (already broken in)
02 Tanabe GF210's 167f/157r
Front lower H brace
17x7.5 HP Racing Blitz (identical to Tenzo type M) Rock hard Nexen 3000000000 215/45/17
Alignment spec's: -2.0 F -2.0 R 0 toe
I got my eye on 235/40/17 ContiSportContact 3's.
Old 11-26-2009, 01:38 PM   #157
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
No it's the stiffer the springs the less turns from full stiff. (FFS)
Old 11-26-2009, 01:44 PM   #158
SVT_WRX
Member#: 164830
G61 III OVE 58e
So you are saying the stiffer the springs, the stiffer the strut needs to be?
Old 11-26-2009, 02:27 PM   #159
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
Yes that is correct
Old 12-03-2009, 08:54 PM   #160
03SubyWRX
Member#: 200767
2007 OBS 5MT
03 WRX built
2003 WRX w/ 104,000 miles
12 turns front/8 turns rear
Swift R-Spec STi springs, around 295F/285R
Group N top hats, 02-03 Fronts 04-07 Rears
Whiteline RCA kit, Whiteline steering rack bushings
2009 Legacy wheels with 225/45/17 BFG gForce Super Sport A/S's
-1.2 camber front with 0 toe all around
I'm fairly certain I got a set of blown struts from Tokico. Out of the box the car rode like a leaf sprung 70's pickup at the recommended starting point. After 500 miles I had to adjust them to above the settings to make it barely bearable for a DD. The car loses traction if I hit a bump/pothole too fast, it feels likes I have no travel. I'm working with TiC right now to get the struts warrantied, hopefully they get here soon because my car sucks to ride in.
If anyone has any other ideas of what might be the cause of the severe harshness with this setup, please chime in!
03SubyWRX is offline   Reply With Quote
Old 12-03-2009, 09:05 PM   #161
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Well, first off: 12 turns and 8 turns are both invalid settings. The adjuster will do nothing after 7.5 turns from full stiff (all the way in). With those spring rates you should be at something like 5 turns rear, 3 turns front.
If you want, i could take a look at it for you. I'm fairly close by (plymouth, MA).
sniper1rfa is offline   Reply With Quote
Old 12-03-2009, 09:08 PM   #162
03SubyWRX
Member#: 200767
2007 OBS 5MT
03 WRX built
Yeah my thoughts exactly. I kept making incremental turns until I just gave up pretty much. Glad to know it doesn't go past 7.5 haha.
I'd definitely appreciate it if you could take a look. The car got only marginally better after I maxed out the turns.
Old 12-03-2009, 09:28 PM   #163
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Sure. PM sent. If you're around tomorrow, that would be perfect, if not let me know when you're around.
BTW, i'm guessing you're on the bumpstops. Don't know, though.
Old 12-03-2009, 10:28 PM   #164
SubySal
Member#: 43011
2004 Impreza RS
PacificaBlue/BlackTarmacs
The struts will go past 7.5 TFFS from the way I understand it. There is no stop. I read in the instructions that going past the 7.5 TFFS can damage the struts though.
SubySal is offline   Reply With Quote
Old 12-03-2009, 10:30 PM   #165
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
doesn't do damage, just doesn't continue adjusting anything. You can pull the screws right out if you want (this info direct from tokico).
Old 12-03-2009, 10:58 PM   #166
SubySal
Member#: 43011
2004 Impreza RS
OK yea I just checked the manual. It just says...
.................CAUTION
Do not unscrew the adjuster too far.
If you are uncertain about the current
adjustment go back to full hard and start over.
I guess I just took that to mean damage may occur.
Old 12-04-2009, 07:33 AM   #167
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Well, it might break something if you pull the adjuster out and then drive on it, but it won't with the car just sitting there.
The adjuster is a setscrew that pushes on a rod which travels down the shock shaft into the valving. The two bits are not connected.
Old 12-04-2009, 10:44 AM   #168
SubySal
Member#: 43011
2004 Impreza RS
OK, good to know
Old 02-13-2010, 02:29 AM   #169
RiceRooster
Member#: 127550
2004 WRB STi
2004 ZX10R
2004 STi 129,500 miles
Espiler GT springs 280f/230r
3.50f TFFS/3.75r TFFS
Oswald Performance light weight bumper beam
stock top hats
F/R strut barce
Kartboy, Whiteline bushings upgrade
Kartboy subframe lock bolt
-1.6 camber front/-1.6 right rear,-1.9 left rear camber. 0 toe all around
H-Brace
Fender brace
Started out with 5 TFFS for the break in period, very comfy but car felt unstable. After the break in went with 4 tffs front/4.50 tffs rear, car was still comfy to ride but felt woooly.... I tried a couple of more turns and was finally satisfied with 3.50 tffs front/3.75 tffs rear for daily driving. Future upgrade are groupe n top hats and swaybars/endlinks....
RiceRooster is offline   Reply With Quote
Old 02-18-2010, 03:06 PM   #170
bzbuzz
Member#: 116052
2011 STI ( Sold )
enigma is that...
how come handling feel is different almost everyday?
sometimes it feels really good very stable turning, sometimes i feel more body roll stuff...
maybe due to the weight difference from amount of gas....or.. the ambient temperature changes the performance of the strut?\
you guys feel consistant handling everyday?
by the way, got tokico d-spec with rce yellow set that 4f and 4 1/4 r.
with sways 24 f 24 r and lots of other bushings etc..
bzbuzz is offline   Reply With Quote
Old 02-18-2010, 04:06 PM   #171
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
stock top hats
F/R strut barce
H-Brace
Fender brace
I'm starting to get concerned that people are setting their struts way too stiff. You shouldn't be fixing body roll with strut settings. You leave that job to springs and anti-sway bars. Too stiff struts means less grip because your limiting suspension travel. Now I'm really not saying your car is on the wrong settings at all, but at the same time you want to let those springs do as much work as possible, by which I mean compress and decompress. Personally I hate the car hopping over bumps and inconsistencies because that means I'm losing grip.
Then again, the only real way to tell if they're at the right settings is on a shock dyno.
formula91 is offline   Reply With Quote
Old 02-18-2010, 04:08 PM   #172
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Dude, I've been concerned about that since this thread first got going.
Old 02-18-2010, 11:48 PM   #173
SubySal
Member#: 43011
2004 Impreza RS
Thumbs up
I think I found my sweet spot...
I've had my struts in a while now. To refresh...
Dspecs/RCE black springs, Whiteline bars: 22mmFSB, 22-24-26mmRSB.
I have different settings for street and autocross, but the car seems great both ways as well as extremely consistent and forgiving. I use 5.5TFFS F&R for street and 3.5 TFFS FR, 4-4.5 TFFS RR for autocross. The car had been awesome. Last event I had my best finish ever. It was cold and the lot was uneven so the stiff suspended R comp cars were having issues, but I pulled off my best run ever finishing first in STX and 7th overall out of 80 drivers, not to mention a girl I had co-driving with me finished first in her class and she had never driven or even rode in the car before. BTW the rest of STX was on coilovers.
I really love these struts! After I got them I was able to install the stiffer RCE Blacks. A phenomenal upgrade from the Prodrives I was using before and almost magically the whole suspension, the whole car just came together! My points jumped from high 800's very low 900's to well into the 900's and my last points score was 974! Plus the car is just way easier to drive... no more bouncing off bumpstops during high-G turns with sticky tires. HOORAY!!
Old 02-19-2010, 12:29 AM   #174
trick3d
Member#: 202146
2010 evoru
GG
Default Re: Compiling Tokico D-Specs settings
Also rolling on tokicos with rce black ,FTW!!!!! I have mine set to 4.0 tffs F and 4.5 tffs R. Going great so far can't wait till I save up for some group n hats.
trick3d is offline   Reply With Quote
Old 02-19-2010, 12:39 AM   #175
SubySal
Member#: 43011
2004 Impreza RS
Sweet! yea I'm running Group N's out back and Cusco camber plates up front.
Gauging interest: Tokico D-spec + new Swift R-spec springs Turn in Concepts Vendor 'Group Buy' Classifieds 45 03-09-2008 10:55 PM
ONE SET Tokico D Spec IN STOCK ON SALE. + Koni inserts & Crucial Springs in stock! Crucial Racing Suspension/Brakes/Handling 7 10-26-2007 02:07 PM
what are your tokico d-spec settings? ASpec818 Brakes, Steering & Suspension 7 07-30-2006 06:26 PM
Tokico D-Specs? BAC5.2 Brakes, Steering & Suspension 2 11-02-2004 06:28 PM
Tokico d-spec struts pyropretz Brakes, Steering & Suspension 12 09-22-2004 03:32 PM
