Welcome to the North American Subaru Impreza Owners Club Thursday September 3, 2015
Old 12-01-2009, 08:38 AM   #1
Blouchturbo
Member#: 119764
2006 STi
Default Dom 3.0XT-R and Dom 4.0XT-R Dyno Charts
Car: 06 STI
Tuner: Chad Block
Dyno Info: Mustang
Baseline: Stage 2 (264/252)
Target Boost: 26
Fuel: 93
Dom 4.0XT-R with 10cm turbine housings
06 Sti
Perrin FMIC
Perrin 3inch inlet
Perrin Big MAF
Drop in CP pistons
DW 850cc injectors
TBE
TGV deletes
GTSpec Header
38mm external gate
AEM Tru Boost
Post up your results
Blouchturbo is offline   Reply With Quote
Old 12-01-2009, 08:52 AM   #2
JAKbauer24
Member#: 137904
Default 22B + SC 2.3L + Blouch Dom4 XT-R = 576bhp
Event: dyno pull
Ambient Temp: 50
Elevation: 670 ft
Car: 22b
Tuner: Pat, Scoobyclinic
Dyno Info: Dyno Dynamics
Peak HP at RPM: 576bhp@6000
Peak Torque at RPM: 560@4700rpm
Baseline hp/tq for a stock on same dyno: 2.5 STI 275-280bhp
Target Boost: 27psi
Target AFR: 11.6
Fuel: Pump + meth
Engine/Power Modifications:
Scoobyclinic 2.3L engine, 22b/STI 4 Heads with DH22 cams, Solaris
ecu, new Blouch Dom4 XT-R billet turbo, Hyperflow FMIC, CAI
Driveline Modifications: PPG 5 speed syncro box, stock dccd centre
diff, ACT clutch.
Pump gas power & torque
boost & AFR
Pump gas + meth power & torque
boost & AFR
JAKbauer24 is offline   Reply With Quote
Old 12-01-2009, 11:56 AM   #3
Tay06wrx
Member#: 185673
2006 WRX
^^Damn. Those are good numbers. 576 not bad at all.
Tay06wrx is offline   Reply With Quote
Old 12-01-2009, 12:27 PM   #4
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
On the first post, are you guys running 26.6psi on pure 93oct ? no meth?
juanmedina is online now   Reply With Quote
Old 12-01-2009, 12:32 PM   #5
Blouchturbo
Member#: 119764
2006 STi
93 no meth.
Old 12-01-2009, 12:50 PM   #6
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Originally Posted by Blouchturbo View Post
93 no meth.
Wow, I'm not a doubter but your really seeing no knock voltage at that high of a boost level?
I have a 60lb/min turbo that might read 360 on real 0 correction mustang. By your stage 2 260 numbers, it shows you have not altered corrections and it is reading how it should.
400+ on 26 psi!!
2006 EVO you meant?
STi Mikey is offline   Reply With Quote
Old 12-01-2009, 01:05 PM   #7
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Originally Posted by STi Mikey View Post
I have a 60lb/min turbo.....
a 60 lb/min turbo with a 7cm turbine......the evo's 16g's have a 10.5 cm....
that t60 is a retarded turbine/compressor matchup imo
basically your turbine has to spin way faster to move the same amount of air as a 10cm turbine.....which causes it to operate less efficiently.
Old 12-01-2009, 02:05 PM   #8
Blouchturbo
Member#: 119764
2006 STi
400+ on 26 psi!!
2006 EVO you meant?
zero knock feedback correction , zero learned knock correction
Old 12-01-2009, 02:13 PM   #9
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
I completely understand that (though I am surprised I hit and Hold 23.08psi to 7300). What I find surprising is:
My car will trap 120-121 on 93 pump.
Most of Juniors 35R pump cars trap 123-125
The last time I was on a mustang, the Stg 2 STi before me made 262whp. I made 304 on RG and trapped 114.
This 4.0RXT should be a 124-126 car on pump, in the stock location. Thats just nuts.
Old 12-01-2009, 02:16 PM   #10
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
Cant wait to get mine tuned!
Dom 3.0XTR with 3" inlet here!
jnorth85 is offline   Reply With Quote
Old 12-01-2009, 03:57 PM   #11
JAKbauer24
Member#: 137904
we not tried any of the new billet range on the strip yet as they closed till the new year.
but we was trapping 128 with old dom3 (7cm) and 136 with old dom4 (8cm) both was on pump+meth in 2700lb GC8
new dom4 xtr should be 138+
just uploading a dom3 vs dom3 xtr graphs
Old 12-01-2009, 04:11 PM   #12
juanmedina
Member#: 133146
07 FPgreen 7.37@95
Mikey is talking about a full weight STi
Old 12-01-2009, 06:15 PM   #13
mywifesSTi
Member#: 142709
07 STi Limited
FP HTA Green 372whp
Ok good #'s with the 4.0 XT-R. Now where's the dyno results for the 3.0 XT-R?
mywifesSTi is offline   Reply With Quote
Old 12-01-2009, 07:07 PM   #14
IAG Performance
Member#: 158123
DOM 3.0XT-R
RF010 is on 93 Octane
Above Runs are comparing the Standard DOM 3.0R to the New DOM 3.0 XT-R with Billet Compressor Wheel and 10cm2 Turbine Housing. Both runs are on 93 octane and both cars have similar mods. Note that the with the new lightweight Compressor Wheel the XT-R spools faster!
Above Run is on VP Q16. You will note that we shut to car down early because the clutch let loose. The peak HP numbers are not quite accurate. The car however, was on point to make about 465whp.
New race gas runs should be up in the next few days!
IAG Performance is offline   Reply With Quote
Old 12-01-2009, 08:05 PM   #15
achavez
Member#: 139320
2006 RA 1-4 5mt
wrx obp needs a e85 tune
^ the dom 3.0xtr has an awesome powerband
achavez is offline   Reply With Quote
Old 12-01-2009, 10:33 PM   #16
Speed
Member#: 67371
05 BUILT 2.4L STI
Originally Posted by IAG Performance View Post
DOM 3.0XT-R
Almost 30F difference on a uncorrected chart... Also, did your atmospheric pressure sensor broke or something? 29.07 in-Hg ... that's too low. Did a hurricane went through your area? lol
Can you put the same chart... but this time add the SAE correction factor to it. Basically the 409WHP graph will come down... while the 360WHP graph goes up. 30F will do that! As far as the spool there's too many variables.
In paper what should happen between these 2 turbos is that the new xtr should make around 20-25 whp more at the same boost level (52 lb/min vs 55 lb/min). But it should spool just as fast or slower than the old DOM3 (10cm turbine, ligther but bigger compressor wheel)
Anyway these new Blouch turbos are awesome!
Speed is offline   Reply With Quote
Old 12-01-2009, 10:48 PM   #17
Special
Member#: 145585
2002 S202 11.9@120
Yellow
Do you guys think on a 2002 JDM 2.0L with AVCS, with a good tune and all the supporting mods except cams, do you think the Dom 3XTR is capable of making 450whp on VP C16? Also, on pump 95, is it capable of making 400whp? We have terrible 91 gas here but I have been thinking about mixing 100 unleaded to get the octane up to 95.
Special is offline   Reply With Quote
Old 12-01-2009, 10:59 PM   #18
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
26lbs on pump is ludicrous... But fun for how ever long it's going to last.
2gnt2wrx is offline   Reply With Quote
Old 12-02-2009, 12:48 AM   #19
Junior2JZ
Member#: 64908
10.8 XT+10.0@143 GR+
2x9.0@170mph GTRs
I ran 28-30psi on 93 for 40k on a Subaru 500+whp.. Its not out of the question. Been doing it on DSMs since back in like 2000.
As for the turbo's they look decent. I still think for all the money you spend setting up a stock location you can do a nice rotated and be done with it... also have no real limitation on turbo/back housings selection.
Old 12-02-2009, 06:22 PM   #20
DarkKnightBaku
Member#: 199536
04 STi WRBlueDevil
looks like no one is running the 2.5xtr been hoping to see a graph for one of those to make my choice between that or the 3.0xtr
DarkKnightBaku is offline   Reply With Quote
Old 12-02-2009, 06:24 PM   #21
Phatron
Member#: 36033
CEO PhatBottiTuning
im currently running 31 psi with my HTA Green on 91 octane + meth, not much more octane than 93....
Old 12-02-2009, 06:25 PM   #22
DarkKnightBaku
Member#: 199536
04 STi WRBlueDevil
now thats boost
Old 12-02-2009, 06:33 PM   #23
Phatron
Member#: 36033
CEO PhatBottiTuning
i put an extra spring in my Tial Ext wastegate last night to have 20psi spring combo on my STI with OG Green and after the install my boost is pegging at 30psi on my STRi gauge. also on 91+meth. but the logger was only peaking at 28 psi.
And my external wastegate is no longer opening......kind of concerning me......but i picked up 2psi with the mbc in the same spot.
Old 12-02-2009, 06:56 PM   #24
juanmedina
Member#: 133146
07 FPgreen 7.37@95
19.5psi on ATP35R is ludicrous
I disagree on the rotated part, if anyone is planning on running no more than 35R .63/.82 AR POWER this is the perfect turbo IMO. The DOM 3.0XT-R 2.4" inlet is putting down about the same whp and at about the same boost level with the same gas as IAG's rotated 35R.
Most of us will only need a bigger CAI and it seems that there is no need for EWG
...and how much power are you making?
Old 12-02-2009, 06:59 PM   #25
Phatron
Member#: 36033
CEO PhatBottiTuning
more than u
i think my last one was 350-360whp......and my car only weighs 2800 lbs now
2.0 + Dom 3.0XT-R + E85 makes 392whp rexblake Proven Power Bragging 36 07-20-2010 10:58 PM
370WHP alternative to Dom 3.0XT-R turboICE Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 06-07-2010 12:04 AM
Dom 3.0XT-R and Dom 4.0XT-R Now Available Blouchturbo Engine/Power/Exhaust 17 02-04-2010 02:01 AM
Good News for those who like the Dual (3,3.5,DTM) and single 4" style exhausts GTBGUY Normally Aspirated Powertrain 85 05-24-2001 07:33 AM
