#1 |
Member#: 119764
Vehicle:2006 STi WRB |
Car: 06 STI Tuner: Chad Block Dyno Info: Mustang Baseline: Stage 2 (264/252) Target Boost: 26 Fuel: 93 Dom 4.0XT-R with 10cm turbine housings 06 Sti Perrin FMIC Perrin 3inch inlet Perrin Big MAF Drop in CP pistons DW 850cc injectors TBE TGV deletes GTSpec Header 38mm external gate AEM Tru Boost ![]() Post up your results ![]()
#2 |
Member#: 137904
Event: dyno pull
Location: Scoobyclinic, Chesterfield, U.K. Ambient Temp: 50 Elevation: 670 ft Car: 22b Tuner: Pat, Scoobyclinic Dyno Info: Dyno Dynamics Peak HP at RPM: 576bhp@6000 Peak Torque at RPM: 560@4700rpm Baseline hp/tq for a stock on same dyno: 2.5 STI 275-280bhp Target Boost: 27psi Target AFR: 11.6 Fuel: Pump + meth Engine/Power Modifications: Scoobyclinic 2.3L engine, 22b/STI 4 Heads with DH22 cams, Solaris ecu, new Blouch Dom4 XT-R billet turbo, Hyperflow FMIC, CAI Driveline Modifications: PPG 5 speed syncro box, stock dccd centre diff, ACT clutch. Pump gas power & torque ![]() boost & AFR ![]() Pump gas + meth power & torque ![]() boost & AFR ![]() |
#3 |
Member#: 185673
Vehicle:2006 WRX NW Stance. |
^^Damn.
Those are good numbers. 576 not bad at all. |
#4 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
On the first post, are you guys running 26.6psi on pure 93oct
? no meth? |
#5 |
Member#: 119764
#6 |
Member#: 114631
Vehicle:2007 11.5 @ 118 Stock Turbo Record Holder |
Wow, I'm not a doubter but your really seeing no knock voltage at that high of a boost level?
I have a 60lb/min turbo that might read 360 on real 0 correction mustang. By your stage 2 260 numbers, it shows you have not altered corrections and it is reading how it should. 400+ on 26 psi!! 2006 EVO you meant? |
#7 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
a 60 lb/min turbo with a 7cm turbine......the evo's 16g's have a 10.5 cm....
that t60 is a retarded turbine/compressor matchup imo basically your turbine has to spin way faster to move the same amount of air as a 10cm turbine.....which causes it to operate less efficiently. |
#8 | |
Member#: 119764
#9 | |
Member#: 114631
My car will trap 120-121 on 93 pump. Most of Juniors 35R pump cars trap 123-125 The last time I was on a mustang, the Stg 2 STi before me made 262whp. I made 304 on RG and trapped 114. This 4.0RXT should be a 124-126 car on pump, in the stock location. Thats just nuts. |
#10 |
Member#: 76785
Vehicle:2000 RSTi Coupe SRP |
Cant wait to get mine tuned!
Dom 3.0XTR with 3" inlet here! |
#11 | |
Member#: 137904
but we was trapping 128 with old dom3 (7cm) and 136 with old dom4 (8cm) both was on pump+meth in 2700lb GC8 new dom4 xtr should be 138+ ![]() just uploading a dom3 vs dom3 xtr graphs |
#12 | |
Member#: 133146
#13 |
Member#: 142709
Vehicle:07 STi Limited FP HTA Green 372whp |
Ok good #'s with the 4.0 XT-R. Now where's the dyno results for the 3.0 XT-R?
#14 |
Member#: 158123
DOM 3.0XT-R
![]() RF010 is on 93 Octane ![]() Above Runs are comparing the Standard DOM 3.0R to the New DOM 3.0 XT-R with Billet Compressor Wheel and 10cm2 Turbine Housing. Both runs are on 93 octane and both cars have similar mods. Note that the with the new lightweight Compressor Wheel the XT-R spools faster! ![]() Above Run is on VP Q16. You will note that we shut to car down early because the clutch let loose. The peak HP numbers are not quite accurate. The car however, was on point to make about 465whp. New race gas runs should be up in the next few days! |
#15 |
Member#: 139320
BAIC
Vehicle:2006 RA 1-4 5mt wrx obp needs a e85 tune |
^ the dom 3.0xtr has an awesome powerband
#16 | |
Member#: 67371
Vehicle:05 BUILT 2.4L STI |
Can you put the same chart... but this time add the SAE correction factor to it. Basically the 409WHP graph will come down... while the 360WHP graph goes up. 30F will do that! As far as the spool there's too many variables. In paper what should happen between these 2 turbos is that the new xtr should make around 20-25 whp more at the same boost level (52 lb/min vs 55 lb/min). But it should spool just as fast or slower than the old DOM3 (10cm turbine, ligther but bigger compressor wheel) Anyway these new Blouch turbos are awesome! |
#17 |
Member#: 145585
Vehicle:2002 S202 Yellow |
Do you guys think on a 2002 JDM 2.0L with AVCS, with a good tune and all the supporting mods except cams, do you think the Dom 3XTR is capable of making 450whp on VP C16? Also, on pump 95, is it capable of making 400whp? We have terrible 91 gas here but I have been thinking about mixing 100 unleaded to get the octane up to 95.
#18 |
Member#: 123625
Vehicle:2002 wrx vf34 Tuned at Cobb |
26lbs on pump is ludicrous... But fun for how ever long it's going to last.
#19 |
Member#: 64908
Vehicle:10.8 XT+ Real stock turbo record holder 11.4 |
I ran 28-30psi on 93 for 40k on a Subaru 500+whp.. Its not out of the question. Been doing it on DSMs since back in like 2000.
As for the turbo's they look decent. I still think for all the money you spend setting up a stock location you can do a nice rotated and be done with it... also have no real limitation on turbo/back housings selection. |
#20 |
Member#: 199536
South East
Vehicle:04 STi WRBlueDevil 87 Camaro Iroc Z28 |
looks like no one is running the 2.5xtr been hoping to see a graph for one of those to make my choice between that or the 3.0xtr
#21 |
Member#: 36033
SCIC
#22 |
Member#: 199536
South East
#23 |
Member#: 36033
SCIC
i put an extra spring in my Tial Ext wastegate last night to have 20psi spring combo on my STI with OG Green and after the install my boost is pegging at 30psi on my STRi gauge. also on 91+meth. but the logger was only peaking at 28 psi.
And my external wastegate is no longer opening......kind of concerning me......but i picked up 2psi with the mbc in the same spot. |
#24 | |||
Member#: 133146
![]() Quote:
Most of us will only need a bigger CAI and it seems that there is no need for EWG Quote:
![]() Last edited by juanmedina; 12-02-2009 at 07:04 PM. |
#25 |
Member#: 36033
SCIC
more than u
i think my last one was 350-360whp......and my car only weighs 2800 lbs now ![]() |
| Thread Tools | |
| Display Modes | |
| 2.0 + Dom 3.0XT-R + E85 makes 392whp | rexblake | Proven Power Bragging | 36 | 07-20-2010 10:58 PM |
| 370WHP alternative to Dom 3.0XT-R | turboICE | Factory 2.5L Turbo Powertrain | 29 | 06-07-2010 12:04 AM |
| Dom 3.0XT-R and Dom 4.0XT-R Now Available | Blouchturbo | Engine/Power/Exhaust | 17 | 02-04-2010 02:01 AM |
| Good News for those who like the Dual (3,3.5,DTM) and single 4" style exhausts | GTBGUY | Normally Aspirated Powertrain | 85 | 05-24-2001 07:33 AM |
