Old 12-02-2009, 07:24 PM   #26
2gnt2wrx
Member#: 123625
2002 wrx
vf34 Tuned at Cobb
Originally Posted by juanmedina View Post
19.5psi on ATP35R is ludicrous
I want my 10+k investment to last more than a month, I'll save ludicrous speed for my q16 tune
2gnt2wrx is offline   Reply With Quote
Old 12-02-2009, 07:45 PM   #27
Thran
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
Originally Posted by DarkKnightBaku View Post
looks like no one is running the 2.5xtr been hoping to see a graph for one of those to make my choice between that or the 3.0xtr
i am in the same boat, only because i am running a 2.1
not sure if i should go with 3.0xtr, 2.5xtr or wait to see what FP releases instead of the HTA green
Thran is offline   Reply With Quote
Old 12-02-2009, 07:49 PM   #28
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
Originally Posted by STi Mikey View Post
I completely understand that (though I am surprised I hit and Hold 23.08psi to 7300). What I find surprising is:
My car will trap 120-121 on 93 pump.
Most of Juniors 35R pump cars trap 123-125
The last time I was on a mustang, the Stg 2 STi before me made 262whp. I made 304 on RG and trapped 114.
This 4.0RXT should be a 124-126 car on pump, in the stock location. Thats just nuts.
A 430whp full weight EVO IX on CBRD's dyno in which you have to shift into 5th sometimes will trap 125-127mph.
I wonder what will the DOM3.0 RX-T make on the same dyno with the same boost and gas?
I agree but u will have problems on the street with well setup cars . You should be able to run 21psi really and will still be really safe and conservative
Old 12-02-2009, 07:50 PM   #29
juanmedina
Member#: 133146
07 FPgreen 7.37@95
I think you should wait, ATP is supposed to release a TS setup as well
Old 12-02-2009, 08:21 PM   #30
2gnt2wrx
Member#: 123625
2002 wrx
vf34 Tuned at Cobb
The thing is.... Am I even going to notice the difference? This is where I'm stuck. I don't thing the 20whp is going to be noticable.
Old 12-02-2009, 08:28 PM   #31
Astartes
Member#: 183813
2006 WRX TR OBP
WRX STi SGM
When do we get to see some 2.5XT-R numbers?
Astartes is offline   Reply With Quote
Old 12-02-2009, 10:09 PM   #32
juanmedina
Member#: 133146
07 FPgreen 7.37@95
I think you will....your torque is supper low for some reason
Old 12-03-2009, 01:31 AM   #33
Spoolin415
Member#: 164074
Do these XT-R's fit as they should due to the revised castings?
Spoolin415 is offline   Reply With Quote
Old 12-03-2009, 02:59 AM   #34
rexblake
Member#: 178426
2010 Evo X MRt
PWN3D
I called Blouch this afternoon and they said it would be a couple more weeks. Still finishing up testing. I'm really curious what the 2.5xt-r will do on a 2.0, especially on E85 or race gas.
Old 12-03-2009, 06:40 AM   #35
DarkKnightBaku
Member#: 199536
04 STi WRBlueDevil
87 Camaro Iroc Z28
I'm more curious as to spool time on the 2.5xtr the 3 and 4 do pretty good so the 2.5 should be outstanding
DarkKnightBaku is offline   Reply With Quote
Old 12-03-2009, 03:34 PM   #36
Thran
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
OOOO waiting ; )
Old 12-03-2009, 04:59 PM   #37
chongl
Member#: 187694
2009 WRX Sedan
WRB Mica
Are you serious? I just got my ATP3076 a month ago...
chongl is offline   Reply With Quote
Old 12-03-2009, 05:07 PM   #38
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
First off....the stock location twin scroll is a good thing....but really not the way to go. Full Race Has TS kits for $4200. The ATP TS turbo is probably gonna be $2200 like the mitsu one is. Then you're gonna have to buy a $700-$1500 TS header......and a 3" turbo inlet, and TGV deletes. After all is said and done you've spent very close to the $4200 for a rotated TS kit.....and your intake is smaller. Rotated is simply the way to go. Having said that i'll probably be going the stock location TS route cause i have to pass visual smog.
heres my email from ATP from November 5th
Hello Ron,
We're definitely moving along and making progress. We hope to have an update on release right at the end of the year.
Thank you!
> Are you guys developing any twinscroll applications for subarus?
> Thanks
> Ron
Old 12-03-2009, 05:38 PM   #39
DarkKnightBaku
Member#: 199536
04 STi WRBlueDevil
87 Camaro Iroc Z28
id agree if your going to go twin scroll rotated is the way to go
Old 12-03-2009, 06:18 PM   #40
Thran
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
Hello Ron,
Thank you!
> Thanks
> Ron
I agree with you, other then a twinscroll applicaiton would be great for someone wanting something like 350-400whp and if someone already has everything other then the headers of course
Old 12-09-2009, 09:33 PM   #41
juanmedina
Member#: 133146
07 FPgreen 7.37@95
Originally Posted by Blouchturbo View Post
Car: 06 STI
Tuner: Chad Block
Dyno Info: Mustang
Baseline: Stage 2 (264/252)
Target Boost: 26
Fuel: 93
Dom 4.0XT-R with 10cm turbine housings
06 Sti
Perrin FMIC
Perrin 3inch inlet
Perrin Big MAF
Drop in CP pistons
DW 850cc injectors
TBE
TGV deletes
GTSpec Header
38mm external gate
AEM Tru Boost
Post up your results
This post just blows my mind..... a full weight car with 430whp on CBRDs dyno will run 11.0-10.7 with a decent driver .
Blouch! I would love to see a comparison of the DOM3.0 XT-R and the DOM4.0 XT-R on CBRDs dyno on pump gas and on race gas
Old 12-09-2009, 10:16 PM   #42
Spoolin415
Member#: 164074
Can anyone comment on the fitment of these new turbos?
Old 12-10-2009, 08:42 AM   #43
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
no fitment issues w/ the 3.0xtr i just wish it would have came w/ studs on the hot side it was hard for me to find some around town. i had the 2.4 in inlet tgv deletes and aps inlet.
krambte79 is offline   Reply With Quote
Old 12-10-2009, 09:18 AM   #44
Special
Member#: 145585
2002 S202
Yellow
No fitment issues at all putting on the 3.0xtr with the 2.4 inlet.
Special is offline   Reply With Quote
Old 12-10-2009, 06:48 PM   #45
fourmicah
Member#: 128760
2012 Ruckus/WRX
Red&White/Gray
I disagree on the rotated part, if anyone is planning on running no more than 35R .63/.82 AR POWER this is the perfect turbo IMO. The DOM 3.0XT-R 2.4" inlet is putting down about the same whp and at about the same boost level with the same gas as IAG's rotated 35R.
True, but IAG was only running a little under 22 psi on that 35R set up, if I remember right, the psi set on these Dom 3.0XT-R was in the neighborhood of 26. There is a big difference there. Physically, you can't tell me that a 2.4 inch inlet will perform that same as a 3.0 inch inlet if all things were equal. Change the wheel out on the 35R and you have something like the HTA 35R that will outperform that all day long.
Don't get me wrong, I really like blouch turbos, I had one on my last car and would consider another one on my car now. It's a great stock location turbo! Something that the subie community has been waiting for! But if you take the same turbo set up and rotate it, it's going to perform better 90% of the time.
fourmicah is offline   Reply With Quote
Old 12-10-2009, 06:51 PM   #46
fourmicah
Member#: 128760
2012 Ruckus/WRX
Red&White/Gray
Blouch turbos fit really well. The only thing we had to do on my car was grind down the transmission a little because the cold side was hitting it.
Old 12-10-2009, 07:05 PM   #47
STi Mikey
Member#: 114631
2007 11.5 @ 118
Stock Turbo Record Holder
Juan, thats a REAL mustang dyno for you. Crazy right. Thats the same mustang dyno I made 304 on and went 12.0
Another 130whp, there's your 10.70 (obviously in theory).
325-335 tops is what you will see on pump for the 3.0
345-355 tops for the 4.0
(sea level, decent conditions)
STi Mikey is offline   Reply With Quote
Old 12-10-2009, 07:12 PM   #48
juanmedina
Member#: 133146
07 FPgreen 7.37@95
No the DOM3.0 was at 24psi, I agree with everything else.
Mikey the DOM4.0 is on pump not race gas. CBRD's dyno read about the same as Buschur's dyno thats how I came up with the 11.0-10.70
Was the 304 on pump gas? I really think on race gas a well tune VF39/43/48 should 330whp on BRs or CBRDs dyno. If I remember correctly Buschur made 300whp on 93oct with his WRX and run 12.2 or something on stock RE92 tires
Old 12-10-2009, 07:20 PM   #49
fourmicah
Member#: 128760
2012 Ruckus/WRX
Red&White/Gray
[quote=juanmedina;29065601]No the DOM3.0 was at 24psi, I agree with everything else.[quote]
Good to know, thanks for he clarification. Either way, those are impressive numbers for a turbo that size!
Old 12-16-2009, 09:23 AM   #50
Special
Member#: 145585
2002 S202
Yellow
Hi, I have an S202 (which is the 2002 JDM STi LE) with the Dom 3XTR and it is a great turbo...it is not laggy at all, and am very impressed even though we only have 90 pump. I can say I was not that impressed with the Dom 3 8cm but converting it to the XTR made all the difference. The car should fly on race gas...I'm sure we can get deep into the 11's when we do the VP C16 tune along with the drag radials. We don't have a 4WD dyno here so don't know the numbers.
2.0 + Dom 3.0XT-R + E85 makes 392whp rexblake Proven Power Bragging 36 07-20-2010 10:58 PM
370WHP alternative to Dom 3.0XT-R turboICE Factory 2.5L Turbo Powertrain 29 06-07-2010 12:04 AM
Dom 3.0XT-R and Dom 4.0XT-R Now Available Blouchturbo Engine/Power/Exhaust 17 02-04-2010 02:01 AM
Good News for those who like the Dual (3,3.5,DTM) and single 4" style exhausts GTBGUY Normally Aspirated Powertrain 85 05-24-2001 07:33 AM
Message Board Statistics All times are GMT -4. The time now is 01:06 AM.
