Welcome to the North American Subaru Impreza Owners Club Wednesday May 27, 2015
Old 09-02-2009, 12:34 AM   #26
LTBlackBird
Member#: 222367
2004 Impreza WRX STi
Platinum Siver Metallic
just gotta hope he'll never test the build strength haha
LTBlackBird is offline   Reply With Quote
Old 11-20-2009, 01:50 AM   #27
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Please tell me you have before and after weights!
ciper is offline   Reply With Quote
Old 12-05-2009, 12:20 AM   #28
LENNYKIRK
Member#: 106944
1997 97GM/06STI
plum crazy purple
LENNYKIRK is offline   Reply With Quote
Old 12-05-2009, 01:00 PM   #29
DCRallyDave
Member#: 4379
DSM LanciaShelby351
MartiniWRC Codriver
Rally America is not the sanctioning body in Canada. CARS rules are here:
http://www.carsrally.ca/CARSRally/Po...RS_2009_En.pdf
DCRallyDave is offline   Reply With Quote
Old 12-05-2009, 11:12 PM   #30
DarkKnightBaku
Member#: 199536
04 STi WRBlueDevil
nice cage also curious of weight difference
DarkKnightBaku is offline   Reply With Quote
Old 12-14-2009, 11:00 PM   #31
goofball
Member#: 196660
2000 Impreza
2003 Forester
Wink It depends n the wire
Originally Posted by madmax718 View Post
if your good with a mig, it can be just as strong- Somewhere I thought that they were supposed to be tigged, or at least the root pass...
Not to call you out, but safety stuff is serious business. Most mig wire has a high silica content that can leave voids of glass depending on how weld is applied (machine settings, technique, etc). Tig leaves a more homogeneous profile that is less likely to crack due to inclusions. That's why they are no structural certifications in solid core mig. Juke'n and jive'n through through the whoops and woods at 100mph requires a cage that can hold together with a little flex. Again, I'm not trying to poke you in eye...
goofball is offline   Reply With Quote
Old 12-19-2009, 07:55 PM   #32
barkley2-6
Member#: 221961
I would have gone with black instead of the blue, but looks good.
barkley2-6 is offline   Reply With Quote
Old 12-21-2009, 07:25 AM   #33
urabus555
Member#: 102091
1994 1.8l Impreza L
Open Class Build w/110hp
Theory is fun!
But that's a safe AND legal cage.
You can quote textbooks and whatever you'd like. The truth is, a well made cage - MIG'd - will hold up just fine in a rally car. The tubes will break before the welds. Design and good welds are required, yes, but MIG is just fine for this.
urabus555 is offline   Reply With Quote
Old 12-21-2009, 07:28 AM   #34
urabus555
Member#: 102091
1994 1.8l Impreza L
If it's a CARS legal cage, that is a combination of 1.5" and 1.75" DOM (0.095 wall IIRC).
The tubing weighs 1.3lbs per foot and 1.7lbs per foot, respectively.
Old 12-21-2009, 07:30 AM   #35
urabus555
Member#: 102091
1994 1.8l Impreza L
Originally Posted by LENNYKIRK View Post
All that really shows is two doorbars (which are required) but, they can be installed in a few different configurations to be legal. NASA is the only (NA Rally) Sanctioning Body to require sil bars (IIRC).
Old 12-21-2009, 07:36 AM   #36
urabus555
Member#: 102091
1994 1.8l Impreza L
Originally Posted by wkderf View Post
im kinda curious:
what diameter piping is that?
has this cage been tested / certified?
and from what I can see, there isnt any provision for mounting the shoulder portions of a harness. how will you be handling that?
CARS (Canadian Association of Rally Sport) requires the use of 1.75" tubing for the main structure (very specific) and 1.5" for other tubes.
The cage meats the CARS (i.e. FIA article 253) requirements for cage design. FIA Article 253 can be found easily online if you're still curious.
The shoulder harnesses can be mounted on the tube between the rear shock towers. This is a less popular design lately. HANS requests that harnesses are intalled within 8" of the seats backs for optimal sfety for their product. But, if further, they ask you to cross the harnesses.
Old 12-21-2009, 07:38 AM   #37
urabus555
Member#: 102091
1994 1.8l Impreza L
Originally Posted by Darcros View Post
What class and cert is that cage?
Other than missing the required gussets in the doorbars (two per door) and one more in the main hoop "x", that cage is FIA legal.
Old 12-21-2009, 07:41 AM   #38
urabus555
Member#: 102091
1994 1.8l Impreza L
it looks nothing like a rally america cert
It may get a CARS logbook, but it is exactly what RA is looking for. Both RA and CARS use FIA Article 253.
Old 12-21-2009, 07:47 AM   #39
urabus555
Member#: 102091
1994 1.8l Impreza L
A lot of the confusion of the TIG vs. MIG thing stems from old rules. In the past, you could build cages using Chromoly Steal. Chromoly should be TIG'd.
Now, cages North America must be made of mild steal. Much easier to weld safely and consistantly.
The only real difference between a MIG'd cage and TIG'd cage is that with MIG, it is possible (for an inexperienced welder) to weld tbes together and have the weld look good, but have no penetration of the weld. Not an issue with a skilled welder!
With TIG, it's not really possible to have a good looking weld, and bad penetration. Good looking TIG welds are (99.9% of the time) good welds.
(IMHO of course!)
Old 12-21-2009, 08:34 PM   #40
goofball
Member#: 196660
2000 Impreza
2003 Forester
First of all, I apologize the op for not saying that the job was very nice and that I was not questioning anything done in the pictures. I was only trying to point out that mig welds can potentially fail due to inclusions from the silica. Like all art and most science, you have to go your own way. Suture self...
Old 12-22-2009, 11:51 AM   #41
urabus555
Member#: 102091
1994 1.8l Impreza L
I was just trying to point out that this is not 'structural' welding. even if the bead has microscopic impurities, the tubing will still fail before the weld. We are talking about material that is 0.095" thick.
MIG may not be suitable for many different applications. But it is suitable for cages. World Rally Cars (lots of engineers behind those things) have been know to sport MIG'd cages...
Suture self...
Old 12-24-2009, 04:39 PM   #42
marchetta070
Member#: 183705
2004 STi
Psm
very nice, how much would it cost for someone to bring in a car and get that done?
marchetta070 is offline   Reply With Quote
Old 12-25-2009, 01:32 PM   #43
RS22b
Member#: 5413
#15 2-Subaru
Rally Cars !!! Fiesta!
our cage held up just fine with a MIG'd cage...
5x rolled at right near 90mph...
RS22b is offline   Reply With Quote
Old 12-25-2009, 07:08 PM   #44
RedefinedTR
Member#: 149848
2011 Honda CRZ
Performance White Pearl
^ LOL the Broken Motorsports on that car says it all!
RedefinedTR is offline   Reply With Quote
Old 12-31-2009, 09:29 PM   #45
rey_vibora
Member#: 59089
2013 WRX
that is one sick roll cage. you can eat of it.
rey_vibora is offline   Reply With Quote
Old 01-15-2010, 03:11 PM   #46
dr3w
Member#: 222318
1993 RHD GC8
Very nice cage, and it coming from there I'm sure its built just as strong as it looks.
dr3w is offline   Reply With Quote
Old 01-18-2010, 03:13 AM   #47
Nate_1990
Member#: 234485
2004 STI
Rally Blue
Looks very very nice good work =]
Nate_1990 is offline   Reply With Quote
Old 01-20-2010, 04:24 PM   #48
JDMspecC
Vendor
Member#: 106277
This is one of our car, It was a mig welded roll cage.
JDMspecC is offline   Reply With Quote
Old 01-21-2010, 12:12 AM   #49
i<3mylegacy
Member#: 215206
woahh not cool
i<3mylegacy is offline   Reply With Quote
Old 01-24-2010, 06:41 PM   #50
EJ22T303
Member#: 236254
the cage looks good on the first page
EJ22T303 is offline   Reply With Quote
FS Tein HG Coilovers 2002 + WRX / 2004 STI Rally Suspension banilla SCIC Private Classifieds 3 03-23-2011 06:18 PM
Bugeye WRB STI Complete 2002 WRX => 2004 STI Conversion car, L@@K! Royal Motors Private Vehicle 'For Sale' Classifieds 33 07-15-2008 12:48 PM
FS: 2004 Sti Rally Blue Doors Tigre Tuning Exterior/Styling 4 06-19-2008 10:39 AM
Papi Fart Poo Racing 2004 Sti Race Car Project American / Puerto Rican Biturbo Sti Subaru Junkie Off-Topic 18 03-27-2006 03:14 PM
I JUST saw the WRC STI rally car in Ann Arbor!! sweetsuby Mid West Subaru Owners Club Forum -- MWSOC 7 01-20-2003 12:45 PM
