Old 12-10-2009, 10:26 PM   #1
subypal
Member#: 218185
2002 SubyPAL.com WRX
Question FMIC piping made from silicone only
Is it possible to run a FMIC system with silicone only? Of course I'll use some metal to connect the silicone straights, bends, etc together.. But I like the light weight properties & thermal resistance silicone offers.. just curious if anyone has done this and if there is any negatives I'm overlooking.
thanks!
subypal is offline   Reply With Quote
Old 12-10-2009, 10:32 PM   #2
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
Never heard of that, but it would probably be super expensive. One way of getting better cooling than silicone is to get the pipes ceramic coated. Bet that would work better.
The silicone under high boost would probably expand too much
Brother EddieJ. is offline   Reply With Quote
Old 12-10-2009, 10:34 PM   #3
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
Shiny metals (i.e. polished and smooth) are pretty good at reflecting heat. The differences would be negligible. Most of the piping isn't going near that hot of stuff, at least when you compare the rest of the engine bay to the turbo.
chazly413 is offline   Reply With Quote
Old 12-10-2009, 10:52 PM   #4
toconn
Member#: 166656
2002 WRX Wagon
I actually doubt that a switch to silicone is going to save you much in the way of heat or weight. And the fact that it's not nearly as rigid as metal could mean trouble when you're running high pressure through the tubing...
toconn is offline   Reply With Quote
Old 12-10-2009, 11:28 PM   #5
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
The hose will probably expand and collapse with boost and vacuum. If you really, really want to do it then be sure to use reinforced hoses.
There are reasons people and manufacturers use hard pipes.
Old 12-10-2009, 11:34 PM   #6
subypal
Member#: 218185
Interesting, I was thinking about the expansion and collapsing myself. I like the idea of silicone though, it will be easier to work with and probably cheaper than having custom FMIC piping welded up. I'm going with reversed manifold fyi. I will do some pricing and see what I can come up with, and post it here
Old 12-10-2009, 11:41 PM   #7
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
Uhhh... aluminum piping is cheap and mandrel bending is too. For elbows I agree a strong reinforced silicone hose will be ok. But my buddy popped his hose at 25psi, after we used t-type hose clamps to keep it from popping off
Old 12-10-2009, 11:48 PM   #8
subypal
Member#: 218185
Well I added up the parts needed, and this is the manifest to complete silicone FMIC piping for reversed manifold
type qty cost
90 = 7 = $118.93
45 = 4 = $67.88
straight = 1 = $49.99
joiner = 12 = $95.88
TOTAL= $332.68
Didn't bother to figure in the clamps.. it's already too much.. and that's with out shipping.
I think I might just piece it together myself, and do like imma_stocker says and just buy aluminum piping and have it mandrel bent to my spec, then have it welded instead of silicone coupled together.
Old 12-10-2009, 11:51 PM   #9
Chi_San
Member#: 53558
2002 WRX Wagon
I loled at the idea.
you'd probably lose a few PSI just to the silicone expanding slightly.
Chi_San is offline   Reply With Quote
Old 12-10-2009, 11:54 PM   #10
chazly413
Member#: 151079
2005 2.5RS RBP
^ He wouldn't lose total PSI once it's done expanding (no leaks hopefully), but the period of time from the silicon pipes at their initial state to full expansion would definitely create some lag, just not sure how noticeable that would be.
Old 12-11-2009, 12:33 AM   #11
Chi_San
Member#: 53558
2002 WRX Wagon
True. It may eventually blow out the silicone as well, that is a lot of surface area. Any imperfection in the silicone would be stressed a lot...
This is the reason that people use aluminum with silicone connectors.
Old 12-11-2009, 01:20 AM   #12
e-zee
Member#: 150212
2006 STI
You were going to use seven 90's?
e-zee is offline   Reply With Quote
Old 12-11-2009, 01:56 AM   #13
06WHTWRX
Member#: 173690
2005 Ferd
F-TeenThousand
You'd basically be spending way more money for a far inferior setup...
06WHTWRX is offline   Reply With Quote
Old 12-11-2009, 02:15 AM   #14
subarulz!
Member#: 99061
16 WRX
CWP
Post #13712 of the GC thread in the gallery looks like silicone inter cooler piping by APS. Could PM him.
subarulz! is offline   Reply With Quote
Old 12-11-2009, 02:43 AM   #15
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Some stock cars come with sylicon piping from the factory (DSMs). Theres a reason people pay to upgrade to metal. Alluminum isn't very heavy, and as previously stated, if you're overly concerned about heat, why not get them ceramic coated, or heat wrap your piping?
tenchu is offline   Reply With Quote
New e-bay FMIC...not made from Burmese Soda cans. WRX-ERROR Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4273 11-16-2012 06:26 PM
FMIC Piping 3" Blue silicone hose couplers - $70 Demian_w Engine/Power/Exhaust 0 01-19-2007 10:06 AM
Were to get custom fmic pipes made Shabib67 Mid Atlantic Impreza Club -- MAIC 11 06-10-2006 03:22 PM
HR: i need fmic piping made.. Dizzuque Mid Atlantic Impreza Club -- MAIC 8 04-09-2006 09:05 PM
New e-bay FMIC...not made from Burmese Soda cans. Optimus Prime Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 546 12-16-2005 10:36 AM
