Old 12-10-2009, 10:45 PM   #1
db2integra
Member#: 114765
2005 WRX STI
Default 200 Whp
So I was playing with Dynolicious and I could only seem to turn up with 200 WHP in my stock sti. This seems a bit low to me... is it? 33% drivetrain loss? Flat ground, 3rd gear pull, air temperature about 2ºc.
db2integra is offline   Reply With Quote
Old 12-10-2009, 10:52 PM   #2
Paul
Member#: 56203
00 RSTI Coupe
did you try a 4th gear?
if you want to get a hp number and not goto a dyno, do a log and airboy it
Old 12-10-2009, 10:58 PM   #3
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Yea, people have proven that program to be very inaccurate.
EDIT: OK did some research...seems like it can be accurate in some instances. I've seen several posts like yours though, where someone got 180hp for an STi, or 350hp for a civic...?
CKxx is offline   Reply With Quote
Old 12-10-2009, 11:02 PM   #4
SoCal_Scooby
Member#: 210777
Don't worry bout' it Brah
how much is usually lost in our cars? like 20%
SoCal_Scooby is offline   Reply With Quote
Old 12-11-2009, 02:52 AM   #5
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
Yeah but the amount lost only increases as the engine revs out. There's a rule of thumb number, but it's not totally accurate.
KP is offline   Reply With Quote
Old 12-11-2009, 07:19 AM   #6
STi Mikey
Member#: 114631
2007 11.5 @ 118
Stock Turbo Record Holder
Hmm, it actually may not be all that off. A stock STi on a dynodynamics or mustnage with no correction is usually right at the 200whp mark.
My Ecutek told me my stg 2 sti made 144whp, while airboy told me 320, hahah
Just another reiteration of dyno's or dyno software being a tool and a tool only.
STi Mikey is offline   Reply With Quote
Old 12-11-2009, 06:03 PM   #7
db2integra
Member#: 114765
2005 WRX STI
See, this is something I just can't understand. Power output is one of the simplest things to measure accurately. All you need to know is force and speed, or torque and angular momentum. There is really no excuse for any dyno to be unaccurate.
Old 12-11-2009, 08:10 PM   #8
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
Who's to say what's accurate? There is no empirical evidence of ANY rating, high or low, being 'right', so how can different readings be closer to or further from the 'truth'?
zeropsi is offline   Reply With Quote
Old 12-11-2009, 08:35 PM   #9
The Beej
Member#: 99677
2004 wrx
aspen white
i believe we lose 22% through the drive train. so a stock sti should be around 230 to the wheels. although im not sure if the 22% is for a wrx specifically and the 6 speed is different or if both are 22.
The Beej is offline   Reply With Quote
Old 12-11-2009, 11:04 PM   #10
IIdiceII
Member#: 90438
you wish it was that simple!
if you really think there are only 4 factors youre dreamin!
IIdiceII is offline   Reply With Quote
Old 12-12-2009, 02:57 AM   #11
801_STi
Member#: 200756
07 yellow clearbra
swp sti "Pearl"
with dynolicious you gotta make sure its held very still and that you only go in a straight line.
also, you have to go from a stop, not from a roll....................
801_STi is offline   Reply With Quote
Old 12-12-2009, 05:39 PM   #12
CKxx
Member#: 33458
93 RX7+09 Forester
I went an bought this program, and paid to have my car weighed with me in it. So far I have tested it from a roll, but based on that my conclusion is that it isn't very accurate...
Old 12-12-2009, 09:14 PM   #13
801_STi
Member#: 200756
07 yellow clearbra
swp sti "Pearl"
thats because its only suppose to go from a stand still. face palm
Old 12-12-2009, 10:28 PM   #14
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
Dyno's will never compair apples to apples. Just look at all the different kinds of dyno's, and how each of them calculate torque. It's not that hard to realize they won't read the same.
Old 12-13-2009, 12:30 AM   #15
CKxx
Member#: 33458
93 RX7+09 Forester
Do I calibrate it and "start" while stopped, then get rolling, and pull a gear? or do I have to rip it from a stop like I'm on a drag strip?
If it I have to run a "1/4 mile" every time, then it is useless. First, I don't have any place that long and flat that isn't an actual 1/4 mile track, and second I'm not trying to go 125+ on Rt1.
Old 12-13-2009, 02:09 AM   #16
801_STi
Member#: 200756
07 yellow clearbra
swp sti "Pearl"
k well..
1. at home on a nice even surface such as a table calibrate it in the settings menu.
2. set up your car, weight, etc
3. put somewhere in your car FLAT and facing directly forward ( i use center console ) place it on one of those pads that are for putting cell phones on your dash so it doesnt move at all
4. from a stand still press start when it says go it is ready and will start whenever you go
you do have to start from a stand still every time so it can tell when you start moving. every run is recording 1/4 of a mile, you may stop before a quarter mile if you would like and it will still give you the results.
what i have found is that if its calibrated very well that it will be about + or - .3 on the times section.. and horsepower i couldnt really tell you. all depends on how much drivetrain loss you have configured in and different dynos read different etc etc etc.
Old 12-13-2009, 02:56 AM   #17
CKxx
Member#: 33458
93 RX7+09 Forester
k well..
Cool. Thanks.
I'm not too worried about 1/4 times. I want to be able to compare as I turn up the boost.
Old 12-13-2009, 11:15 AM   #18
801_STi
Member#: 200756
07 yellow clearbra
swp sti "Pearl"
idk how much i would trust it for something like that. do a couple runs before you turn up your boost and see how much the power level fluctuates.
Old 12-14-2009, 06:47 PM   #19
LateApex31
Member#: 135686
Eh a stock 04-07 STi makes between 210 and 220 wheel HP on our Dyno Dynamics machine.
LateApex31 is offline   Reply With Quote
Old 12-17-2009, 11:27 AM   #20
SMP
Member#: 206350
2004 PSM WRX
VF30
For WHP it says to use 0% drivetrain loss.
I use mine in an iPhone holder standing straight up. It has been pretty accurate in the past for my bone stock 240sx (said 130whp) and my friends 2000 Prelude SH (176whp)
How would you be able to accurately measure it if you dont do it from a standstill? Your jerking all around when moving and it only uses the accelerometer to measure the power. So any slight movements and it will throw it off
SMP is offline   Reply With Quote
Old 04-07-2010, 03:50 PM   #21
db2integra
Member#: 114765
2005 WRX STI
Well, they could use iphone GPS to record initial speed, but then those who have one know how accurate the iphone GPS is...
Old 04-07-2010, 04:12 PM   #22
JoeyOKC
Member#: 209486
dynolicious has been fairly accurate for me as far as 1/4 mile goes. In my accord, it said 15.0@95 and I ran 15.0@96 at the track
in my suby, it said 13.4@103 and I ran 13.2@102 at the track. said 231hp though...
JoeyOKC is offline   Reply With Quote
Old 04-07-2010, 05:46 PM   #23
kaptainkevlar
Member#: 80109
07 spec B
It does seem to be pretty accurate, however I've seen it be very inaccurate. My friend's phone told him he made 544whp in his mostly stock Thunderbird SC
kaptainkevlar is offline   Reply With Quote
Old 04-07-2010, 08:24 PM   #24
Digitalfiend
Member#: 54823
2008 STI
Explain why you need more for a dyno. Obviously, if we're talking road dyno, then sure, you need to take into account a LOT more parameters to have an accurate plot.
Digitalfiend is offline   Reply With Quote
Old 04-07-2010, 11:25 PM   #25
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
I love the smashing of airboy's spreadsheet. No one thought to blame the users...
907Bum is online now   Reply With Quote
ADD 200 WHP - New XO2 BOV!!! cartervt2k Private 'For Sale' Classifieds 9 04-02-2006 11:03 PM
new golf V gti 200 WHP stock! dodiox Off-Topic 128 03-19-2006 09:27 PM
hit 200 whp? 2.5wagon Newbies & FAQs 8 03-23-2005 09:31 PM
To get 200 whp? Crash477 Normally Aspirated Powertrain 31 09-24-2004 12:00 PM
Message Board Statistics All times are GMT -4. The time now is 07:09 PM.
