Old 12-05-2009, 07:21 PM   #1
khyree05
Member#: 220877
03 20g hybrid wrx
I like that color
Default 2003 td05 20g hybrid wrx
EDIT: dynograph now included.
DYNO: Mustang
SHOP: PIA, Tacoma WA
FUEL: 92 octane
MAX whp: [email protected]
Max tq: [email protected]
Target Boost: 20.5psi
Min. engine whp: 55
Average whp:221
Min. engine tq: 142
Average engine tq: 254
Average AFR: 12
Average boost: 15.6
conservative tune, worried about tranny.
MODS:
Blouch PnP 20g td05 8cm turbo
New EJ257 Shortblock
Invidia catless up/downpipe
Greddy EVO2 catback exhaust
Grimmspeed EBCS
Deatshwerks 750cc injectors
Walbro 255 fuel pump
APS 70mm CAI
TurboXs Big TMIC
Accesport V2
Protune
I have dynograph on adobe pdf file, just not sure how to attach it...help wanted.
Since this dyno i have had the midrange increased through a road protune, havent dyno'd it since then.
Last edited by khyree05; 12-12-2009 at 11:44 AM. Reason: forgot the turbo on mod list, fuel, and dynograph
khyree05 is offline   Reply With Quote
Old 12-05-2009, 07:22 PM   #2
khyree05
Member#: 220877
03 20g hybrid wrx
I like that color
feedback wanted
Old 12-05-2009, 07:45 PM   #3
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Sounds good, Graph needed
TDagen is offline   Reply With Quote
Old 12-05-2009, 07:52 PM   #4
khyree05
Member#: 220877
03 20g hybrid wrx
I like that color
Tell me how to post a graph and i will include it. i have it just dont know how to post it. Pdf file. Sorry I'm a noob.
Old 12-05-2009, 07:59 PM   #5
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
photobucket maybe?
Old 12-05-2009, 08:55 PM   #6
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
Since you are running pump gas I would fatten it up a little to 11.3 afr if you were one my customers,it should make about the same power but with less chance of det and cooler in cylinder temps.
john 1badSTI is offline   Reply With Quote
Old 12-05-2009, 11:38 PM   #7
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
read closer: average afr is an average......most likely between closed loop (14.7) and enrichment on boost both included in the pull.
bren wrx is offline   Reply With Quote
Old 12-12-2009, 11:42 AM   #8
khyree05
Member#: 220877
03 20g hybrid wrx
I like that color
Hear is my dynograph.
Old 12-13-2009, 03:40 PM   #9
khyree05
Member#: 220877
03 20g hybrid wrx
I like that color
With a safe tune, stock block, heads, and tranny at 20.5 psi, does anyone see room for improvement???
Feed back wanted.
Thanks.
Old 12-14-2009, 07:35 PM   #10
04psm
Member#: 153551
2004 WRX
psm
i have the same setup but without the accessport tune, I have an opensource tune.. tuned by cleo at precision tuning I made 335awhp and 339 tq
***you running the stock 2 liter heads?
04psm is offline   Reply With Quote
Old 12-15-2009, 08:31 PM   #11
khyree05
Member#: 220877
03 20g hybrid wrx
I like that color
Yes, stock 2.0l heads.
Is your car a hybrid or straight 2.0l?
What dyno was yours tuned on?
Old 12-19-2009, 12:50 PM   #12
04psm
Member#: 153551
2004 WRX
psm
hybrid 2.5l with 2.0l heads
dyno jet dyno...
Old 12-19-2009, 01:12 PM   #13
khyree05
Member#: 220877
03 20g hybrid wrx
I like that color
I have stock heads no cams, but the shop said the heads were refreshed during the hybrid build whatever that means.
Old 12-20-2009, 12:04 PM   #14
turbowgnWHAT
Member#: 163362
'97 Battlewagon II
Flat black and low-n-slow
Feed back wanted.
Thanks.
by stock tranny i assume u mean the 5spd correct? As far as im concerned, you and your guys did a great job! Speaking from expierience(3 engines *cough cough*) conservative is always the way to go!
turbowgnWHAT is offline   Reply With Quote
td05 18g vs. td05 20g? stg2wgn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 46 04-14-2009 10:00 PM
TD05-16G and TD05-20G Marnix Normally Aspirated with bolt-on Forced Induction Powertrain 8 06-10-2004 09:45 PM
