Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 12-15-2009, 10:24 PM   #1
TheRipler
Member#: 34010
04 LandShark STi
198.1mph
Default HP of the Beast! 666HP - 2004 LandShark STi 2.5/2.0 DBW Hybrid GT40R
It's Official: 666HP The LandShark is a beast!
It's the only DBW Subaru I know of with a hybrid motor. If anyone else has one, I'm sure I'll bring them out of the woodwork here. A bunch of people said it couldn't be done, but after a lot of blood, sweat, and tears, she's alive.
I'd like to thank some folks who didn't laugh and hang up the phone when I told them what I wanted to do...
Kenny Tran @ Jotech Racing - www.jotechracing.com
He helped put the finishing touches on the tricky 2L cam sensor configuration with the AEM magic. His 1200HP Scion got me interested in running fuel, which has been an interesting adventure so far. He also got the blasted thing running, which was more than I could do in 12mo on my own. His entire race team has been extremely supportive the whole way. I've learned quite a bit from them about how much really goes into a successful race program. I cannot thank them enough.
Tony Palo @ T1 Race Development - www.t1racedevelopment.com
Most of the people who told me I was completely out of my skull were those I called about the fuel system. They said what I wanted was overkill, and that it would never work. Tony listened to what I had to say, thought about it, and came back with some fantastic product recommendations. From fuel cell to injectors, the whole system came from Tony. It all worked out just right. Heck, I still like to think he came out with the ID2000s just for me. Thanks, Tony.
Watt Bigham @ Watt's Shop - www.wattsshop.com
This guy built the heart of the beast. He makes some of the best Subaru motors in the country. He's been doing Subie motors for nearly a decade, and has experience with a variety of racing engines. Every time I talk to this guy, the gears in my head start turning with new ideas. He also pointed me to Tony when I told him about my fuel system woes. As long as there is Watt, I'll never have to spend time thinking about where to get a motor built. Thank you so much for the beautiful motor, and all the advice.
Steve @ FIS - www.fisystems.com
Steve is a fantastic mechanic, and an even better friend. He asked me to deny anything if anyone asked if he had anything to do with this crazy car, so I'm denying everything. That said, I would have given up on this thing a long time ago were it not for Steve. Plenty of ideas and innovations came out of FIS. If you need to get your stock or modified street Subaru going, I can't think of a better place to take it than FIS in Cumby, TX.
Last and definitely not least, I'd like to thank Shawn Rizzo (Squidz). He's TXIC's roving ASE Master Subaru Mechanic. He did all kinds of things to this car, from putting the monster fuel system in, to dealing with all my frustrating nit picks on the Aquamist system that we wound up not needing. He was there at the dyno sessions and at the track, making sure everything was mechanically sound. I have never seen speed and precision put together in one person like this. You're the man, Shawn. I could not have done this without you.
Now for what we've all been waiting for...
Event: dyno pull (12/3/2009)
Ambient Temp: 72.1F
Elevation: 551 FT
Weather: 29.18 in Hg, 16% RH
Tires: Kumho ECSTA SPT XL 225-40/19
Car: 2004 LandShark STi
Tuner: Kenny Tran
Dyno Info: Dynocom
Peak HP at RPM: 666.3WHP@6350
Peak Torque at RPM: 578.2WTQ @ ~5800
Baseline hp/tq for a stock on same dyno: Unknown (relatively new dyno)
Baseline hp for a stock GT-R: 390whp
Target Boost: 30psi
Target AFR: 11:1 (Gas AFR)
Fuel: VP M1
Engine/Power Modifications:
EJ257/EJ205 hybrid motor
Garrett GT4088R
Custom Jotech FMIC (850HP core)
Aquamist HSF-5 6nozzle system (not used)
TiAl 44mm BOV
Grimmspeed DBW TB
Stock intake manifold tapped for HSF-5 port injection (not used)
Grimmspeed TGV deletes
ID2000 injectors
Aeromotive fuel rails
Weldon 180gph fuel pump
Fuelab fuel filters
Fuelab FPR
2.0L cam gears
Ferrea +1mm valves
Ferrea dual valve springs, Ti retainers
Custom ground Kelford race cams
Custom cut head gasket from Watt's Shop
CP pistons (OEM Size)
Darton sleeves
Pauter rods
STi crank
Fully balanced rotating assembly
TiAl external WG
3.5" custom Jotech Racing race exhaust
AEM 1820 DBW EMS (modified)
AEM AIT sensor
AEM 5-bar MAP sensor
WRX cam sensor
Phormula KS-4 Knock Analyser + KS-PRO
Driveline Modifications:
Cusco Eng/Trans mounts
ACT sprung 6-puck XT
Gruppe-S Flywheel
Kartboy Shifter
TiC Full clicky kit
TiC Unabomber's Sexy Rear End
Suspension Modifications:
AST Raceline 3-way adj coilovers
F/R Cobb sway bars
Other Modifications:
Autopower roll bar
G-Force harness
5gal fuel cell
Hood scoop blank plate
Seibon CF trunk lid
firewall replacing back seat
This wasn't the biggest number it put down. It was just my favorite. We had turned it down a bit to get the cam sensor figured out, and I figured this one was a keeper. Now I just need to swap this little street turbo for a real one, and we can put down some respectable numbers.
TheRipler is offline   Reply With Quote
Old 12-15-2009, 10:30 PM   #2
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
no correction factor
juanmedina is online now   Reply With Quote
Old 12-15-2009, 10:32 PM   #3
jrank3792
Member#: 219756
06 WRX TR
The number of the beast
jrank3792 is offline   Reply With Quote
Old 12-15-2009, 10:39 PM   #4
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Wow that is SICK.... Thats at 30 psi?...
TDagen is offline   Reply With Quote
Old 12-15-2009, 10:47 PM   #5
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
Great numbers Scott! So I guess you'll run a little more wastegate pressure at the March Mile. I can't wait to see it run (again). I don't think I'll be able to keep up, but it will be fun trying. Congrats again.
beaviscih is offline   Reply With Quote
Old 12-16-2009, 12:47 AM   #6
TheRipler
Member#: 34010
04 LandShark STi
198.1mph
I know, right?
Yes. ..and people told me that hybrid motors couldn't make power...
Thanks, Bill. ...and yes, I think it should come up off the WG spring pressure next time.
For those who don't know, Bill ran 189mph at the Texas Mile back in October. (He had a thread in here) It was the LandShark's first trip off the rollers in anger, and he ran right over my personal best of 182mph running off the waste gate spring. (not 666hp) Every time we tried to put boost to it, we'd wind up with a hard ignition cut because of the cam sensor. It was a very frustrating weekend, and Bill won the day with a solid performance.
Bill has the fastest STi in North America. Bill is the man.
I'm going to try to catch him next March..
Old 12-16-2009, 06:09 AM   #7
Merp
Member#: 199106
PMme 4 Speed Density
Patches on OEM ECU
Great numbers. Do you think the heads are holding back the top end? Torque dropping off like that at 7k with oversize valves and cams on a 40r seems early.
Merp is offline   Reply With Quote
Old 12-16-2009, 07:58 AM   #8
Steve.804
Member#: 68647
07 STI
Rotated 35R Jorge Tuned
Geez man... I think there is more potential with the current 40R set-up. Stock intake manifold and I don't see anything listed as far as head porting. Unless your goal is like another 200whp then yeah, swap that "little" turbo lol.
Old 12-16-2009, 09:10 AM   #9
texas05sti
Member#: 126242
2005 STi/2012 GTR
TXIC's most loved
Looks great, Scott.....Can't wait till March!
texas05sti is offline   Reply With Quote
Old 12-16-2009, 09:29 AM   #10
twonb1
Member#: 129163
2011 evo x
Phantom Black
My new hero
twonb1 is offline   Reply With Quote
Old 12-16-2009, 09:57 AM   #11
DerickRyoung
Member#: 178050
02 hybrid-wrx
psm
Nice thread. If you have an STi why did you use wrx heads? I have a wrx w/ an STi SB.
DerickRyoung is offline   Reply With Quote
Old 12-16-2009, 10:06 AM   #12
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
haha that's awesome dude!
Can we see pics of the car and all the custom fab work like the intercooler, exhaust, fuel cell, etc?
D Money is offline   Reply With Quote
Old 12-16-2009, 10:23 AM   #13
TheRipler
Member#: 34010
04 LandShark STi
198.1mph
No, the heads are fantastical. They're the whole reason I've been butting my head against this cam sensor for a year. This dyno session was to work out the issues with the cam sensor. The timing up top was pretty soft.
The heads are ported, and they look great. I'm starting to see a few other things I left off the list, like the EL header, multi-angle valve job... You'll have to excuse me, since the list was off the top of my head.
An intake manifold would likely help some, but that wouldn't get the 350-450hp I'd like. There's an 1100HP EVO II out there that's taking my lunch money.
This video was the 4th pull we ever did, and you can see that it holds 700hp. The timing was fairly conservative here as well, considering the fuel. By the time we left for the mile, it was holding 700 to 8K, and we were prepared to turn it up from there.
Old 12-16-2009, 10:44 AM   #14
Merp
Member#: 199106
Patches on OEM ECU
Good to hear
If you do opt for a multi angle valve job, consider starting with a set of JDM big ports, and then have them ported.
If you want those kinds of numbers, you're gonna need some serious RPM. Any oiling modifications?
Old 12-16-2009, 11:11 AM   #15
javid
Member#: 54304
04 STi
TopSpeed-dAng!
Has anyone discuss the potential to boil fuel with that pump during street driving?
If you do get boiling, you may consider running a stock pump in parallel and keep the Weldon off until you hit low boost.
javid is offline   Reply With Quote
Old 12-16-2009, 09:07 PM   #16
ramair18954
Member#: 28308
03 td-06 wrx ra-c
Platinum
Was that tires smoke? Did you over power the dyno?
ramair18954 is offline   Reply With Quote
Old 12-16-2009, 11:22 PM   #17
TheRipler
Member#: 34010
04 LandShark STi
198.1mph
Plenty. I'm not that concerned about it. I also don't think a stock pump would last very long with this fuel.
No, that was unburned methanol. Burns your nose hairs a little. Great for clearing out a room full of people.
Old 12-17-2009, 12:17 PM   #18
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
So I'm guessing you have a 257 bottom end and 205 heads? The question was asked earlier, why? Do you think there is a benefit to this setup?
Old 12-17-2009, 01:02 PM   #19
TheRipler
Member#: 34010
04 LandShark STi
198.1mph
The two engine builders I trust most told me the same thing when I ran my story by them. If you don't have to have AVCS, well ported WRX heads will flow better than anything you can get. I hadn't seen where anyone had tried it on a DBW car (still haven't seen anyone else), and it sounded like a great opportunity / challenge.
Old 12-17-2009, 08:05 PM   #20
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
can you post pictures of your fuel setup? i would like to see what t1 had to offer.
ownnij is offline   Reply With Quote
Old 12-17-2009, 09:02 PM   #21
perrin247
Member#: 129369
2005 WRX STI
Amazing power, do you think you'll be knocking on the 200MPH door??
perrin247 is offline   Reply With Quote
Old 12-17-2009, 09:21 PM   #22
TheRipler
Member#: 34010
04 LandShark STi
198.1mph
Maybe if Santa brings me a camera. My camera crapped out this summer, and my video camera crapped out at the October Mile. Squidz actually put the fuel system together. I'll see what I can do about getting some pics.
I think so. We ran 182mph on the waste gate spring in October, and that was without a single clean pass (due to the cam sensor issue). Clean WG pass on the dyno was good for 565HP, which probably would have been in the 185-187mph range in October.
When we plugged in the boost controller, it was night and day, but a hard ignition cut at 6900 kept me under 170, which meant I was done with 6th before the 3/4mi mark. ...but that should be all fixed now.
Old 12-17-2009, 09:53 PM   #23
jasv11
Member#: 117862
2006 STi 10.85@129.4
96 impreza 9.55e.t.146mph
Awesome work.
I am very interested in your fuel set up as I will be running 100% ethanol this coming year.
jasv11 is offline   Reply With Quote
Old 12-19-2009, 07:30 PM   #24
Saabaruba
Member#: 232970
01 2.5RS
Ambient Temp: 72.1F
Elevation: 551 FT
Tuner: Kenny Tran
Dyno Info: Dynocom
Target Boost: 30psi
Fuel: VP M1
Garrett GT4088R
TiAl 44mm BOV
Grimmspeed DBW TB
ID2000 injectors
Fuelab fuel filters
Fuelab FPR
2.0L cam gears
Ferrea +1mm valves
Darton sleeves
Pauter rods
STi crank
TiAl external WG
AEM AIT sensor
WRX cam sensor
Gruppe-S Flywheel
Kartboy Shifter
TiC Full clicky kit
F/R Cobb sway bars
Autopower roll bar
G-Force harness
5gal fuel cell
Seibon CF trunk lid
Ummm...that's absolutely sickingly phenomenal numbers, but have to ask, how much money do you have in this entire build and why didn't you do a complete EJ25 Turbo engine setup or a hybrid using the venerable V7/V8 EJ207 heads?
Saabaruba is offline   Reply With Quote
Old 12-19-2009, 08:59 PM   #25
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
^ The OP is obviously doing something right so why use the 207 heads...
FS: 04 wrx 2.5/2.0 hybrid 500 miles needawrx13 NESIC Private Classifieds 2 09-27-2009 04:28 PM
FS: 04 wrx 2.5/2.0 hybrid 500 miles needawrx13 NESIC Private Classifieds 18 04-22-2009 10:33 PM
FS: 04 wrx 2.5/2.0 hybrid with 500 miles needawrx13 Private Vehicle 'For Sale' Classifieds 0 04-17-2009 08:37 PM
2.5/2.0 hybrid hypoxvi Built Motor Discussion 3 05-04-2008 12:52 AM
wrong camshaft timing or?? 2.5/2.0 hybrid Gixxer1K Built Motor Discussion 19 02-05-2008 12:14 PM
