Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 12-22-2009, 08:57 PM   #1
gootkimchi
Member#: 215281
2005 WRX
Default Squealing when wheel is turned all the way
When I turn the wheel all the way it starts squelling when I start cold. Once is start running 15 mph+ the squeel goes away. I replenished the power steering fluid, but I dont know what is giong on! any ideas?
gootkimchi is offline   Reply With Quote
Old 12-22-2009, 09:01 PM   #2
gopsu
Member#: 96448
02 WRX VF34
I would recommend that you lift both wheels off ground and try turning steering wheel all the way to left and then to right 4-5 times with PS cap open.
There could be air trapped in the line that's causing the issue.
gopsu is offline   Reply With Quote
Old 12-22-2009, 10:10 PM   #3
gootkimchi
Member#: 215281
2005 WRX
hmz... how would i lift the car??
Old 12-22-2009, 10:13 PM   #4
RyanG
Member#: 229851
With a jack. Then use jack stands to keep the car from falling and squishing your melon.
RyanG is offline   Reply With Quote
Old 12-22-2009, 10:15 PM   #5
jamal
Member#: 71875
98 2.5GT
my wheels fit
it's bad for the p/s pump to hold the wheel at full lock.
jamal is offline   Reply With Quote
Old 12-22-2009, 10:15 PM   #6
GripS
Member#: 229152
2007 WRX TR
Try not to hit the lock point when turning. Your power steering pump will thank you for it.
Could just be a loose belt.
GripS is offline   Reply With Quote
Old 12-22-2009, 10:56 PM   #7
Jinx Barker
Member#: 233221
2003 Impreza TS/2.5L
Savanna Green
This is EASY - had this happen on my foresters - POWER STEERING BELT.
Exactly the same situation, especially when cold. Get it replaced ASAP, otherwise when the belt goes, and you are on a highway - oy vay!
Jinx Barker is offline   Reply With Quote
Old 12-22-2009, 11:31 PM   #8
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Belt slipping when you hold the car at full lock (and the belt is at its maximum load). Don't do that.
Also, check the P/S belt for wear.
sniper1rfa is offline   Reply With Quote
Old 12-23-2009, 08:19 AM   #9
quazimoto
Member#: 70395
Yup,and this is with any car. Sounds like OP's first car...............
Old 12-23-2009, 09:48 AM   #10
nairbmik
Member#: 220259
09 2.5i
SSM
It's your power steering pump crying at you to stop holding the wheel at full lock.
nairbmik is offline   Reply With Quote
Old 12-23-2009, 05:34 PM   #11
themicrohawk
Member#: 224754
2009 WRX 4DR Prem
Dark Gray Metallic
Indeed.
themicrohawk is offline   Reply With Quote
Old 12-23-2009, 06:03 PM   #12
Badler
Member#: 133597
This.
This too.
Old 12-23-2009, 07:36 PM   #13
gootkimchi
Member#: 215281
2005 WRX
hmz. I have been noticing now that even if I do not have the wheel all the way to the side, the squeeling is happening when im just accelerating. Im am guessing that the wear from having the wheel on the side numerous times is taking it's tole?
Old 12-23-2009, 10:35 PM   #14
Jinx Barker
Member#: 233221
Savanna Green
Its more than just "having a wheel to the side" - so far in my family we have 3 Foresters and previously had 1 Legacy. Two older Foresters, and now defunct Legacy - very sad but she had to go after almost 17 years - eventually developed the issue with the Power Steering belt/pulley, it is normal wear and tear.
They have to be replaced on a regular basis. When this happened to Legacy I let it go for too long and the belt snapped while I was driving down RT1 in NJ, and it was pretty darn horrible. So, now I just make sure that I replace the belts according to the SOA model/schedule. Hence I have some experience with the sound and situation you are describing.
In order for your scooby to run almost forever - regular maintenance needs to be performed religiously, and she would last for a very long time.
Old 12-24-2009, 05:00 PM   #15
gootkimchi
Member#: 215281
2005 WRX
Yes! I will go ahead and shange the pully stuff.
Old 12-24-2009, 11:00 PM   #16
needsboost
Member#: 229038
2005 FXT, Evo8, 3KGT
yep, just had the same exact problem OP, dont worry, its a quick and relatively inexpensive job (compared to a PS pump!). if you are really interested in SEEING it for yourself, start your car up, have someone turn the wheel slightly and watch the belt stop as the pulley continues to spin, thats how i found out what it was!
needsboost is offline   Reply With Quote
Old 12-25-2009, 12:43 AM   #17
lanycel
Member#: 125913
2002 ECS Built WRX
check the belts for wear and tear, how many miles is on the car?
lanycel is offline   Reply With Quote
Old 12-25-2009, 03:02 AM   #18
under0athh51189
Member#: 193959
2001 Lexus IS300
05 Wrx AW 18x9.5 WFC#295
recently had this happen to my car thought it was the belt had it adjusted because it did it when fully locked turn and when ac was on. this fixed it for about an hour then it came back. it ended up being the power steering pump.
under0athh51189 is offline   Reply With Quote
Old 12-25-2009, 09:12 AM   #19
gootkimchi
Member#: 215281
2005 WRX
I will go ahead and try that!
It's 69k Im guessing this is when it needs to be changed.
Squeal When The Wheel Is Turned? ZOMBIEWAGON02 Brakes, Steering & Suspension 6 04-06-2009 11:56 PM
hear a knocking noise when wheel is turned all the way Ender81 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 06-04-2008 01:19 PM
front passenger noise when turning steering wheel almost all the way? ASpec818 Brakes, Steering & Suspension 1 01-13-2008 12:28 AM
Weird noise when I cut the wheel all the way kevind1226 Service & Maintenance 8 07-14-2005 06:41 PM
Steering? makes crackling sound when gased and turned all the way STi-Nismo Dood Newbies & FAQs 7 10-14-2001 09:42 PM
