Old 12-21-2009, 01:23 PM   #1
wrx03.4wz
Member#: 122375
03.7 I own 2 of them
White & Black
Default What are the signs of a bad Alternator?
OK I have been having starter trouble for the past 4 months now, the battery is a year old and has never died (yet).
Symptoms:
repetitive clutch depressions until start (like 7-10)
license plate lights & dome light flicker @ idle
also the car does have 130,XXX miles on it could it be time to have the alt. switched out?
wrx03.4wz is offline   Reply With Quote
Old 12-21-2009, 03:30 PM   #2
wrx03.4wz
Member#: 122375
White & Black
bump status
Old 12-21-2009, 06:47 PM   #3
the battery light will be on and the battery will die
____________________________
you almost certainly have a bad alternator....but you likely have a bad clutch saftey switch and a bad battery connection and/or terminals and/or bad grounds and/or some other electrical issue
but the alternator isnt likely it
Old 12-21-2009, 08:03 PM   #4
Pinned
Member#: 152707
Could he use a multimeter to check the voltages that the alternator is putting out?
If an accessory drive belt/alternator belt was slipping it could cause symptoms like what the OP is experiencing, couldn't it?
Pinned is offline   Reply With Quote
Old 12-21-2009, 08:18 PM   #5
wrx03.4wz
Member#: 122375
White & Black
No battery light, and I just replaced the belts 2 weeks ago any tighter I think they would kill somebody.
Old 12-21-2009, 08:20 PM   #6
wrx03.4wz
Member#: 122375
White & Black
also I just wanted to know what does "OP" stand for?
Old 12-21-2009, 08:21 PM   #7
Pinned
Member#: 152707
Original Post or Original Poster.
Old 12-21-2009, 09:35 PM   #8
wrx03.4wz
Member#: 122375
White & Black
I see thanks
Old 12-21-2009, 10:12 PM   #9
and this is a bad idea as it kills bearings
you should be able to twist the belts 90 in the middle of their longest run between pulleys
too tight is madness
Old 12-21-2009, 11:14 PM   #10
wrx03.4wz
Member#: 122375
White & Black
got it
Old 12-22-2009, 11:06 AM   #11
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The flickering lights could mean the battery is low on charge or some diodes are bad in the alternator which causes ripple voltage. That is what makes the lights flicker.
Cougar4 is offline   Reply With Quote
Old 12-22-2009, 02:49 PM   #12
or all the grounds are bad and the terminals are lose and corroded
Old 12-23-2009, 11:42 AM   #13
Cougar4
Member#: 53443
Winestone
When grounding is bad it usually causes the lights to just be dim or can cause other strange things to happen when the return side finds a better path back to the battery. If the battery has a low charge due to bad connection to the alternator I could see that causing flickering on the lights. The battery helps absorb the small amount of DC ripple (when the diodes are in good shape) coming from the alternator.
Old 12-23-2009, 09:34 PM   #14
and the 'dimming' may just be the ac compressor coming on at idle and isnt considered by the complaintant because he doesnt have the AC 'ON'
and I am all too well aware of the components of the system and their functions...apparent and otherwise
and ripple is one of the often overlooked diagnostics...............that I dont
What are the symptoms of a bad injector timeless Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 06-14-2016 01:43 PM
What are the signs that point to a bad flywheel? azn_outlaw Transmission (AT/MT) & Driveline 3 05-16-2010 03:14 AM
What are the signs your Struts/ Springs are wearing out? snow111 Brakes, Steering & Suspension 9 02-12-2007 04:54 PM
What are the signs of a motor that is about ready to let go? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 03-19-2004 10:11 AM
what are the symptoms of a bad clutch? Keith Technical Forum Archive 6 09-18-2000 10:12 PM
