Old 12-16-2009, 03:30 PM   #51
EFI Logics
Vendor
Member#: 193180
We had the opportunity to run a Dom 3 XTR here on a car that had a few of Blouch's turbo chargers installed previously. All these charts are run on an 06 STi with absolutely no changes to the car other than the turbo itself.
We are in the process of installing a Blouch 2.4" 3.0XTR on another vehicle as well, so the results will be posted in this thread shortly. We will also be tuning a 2.5R (Non-XTR) with the new 10cm hotside change.
Car: 06 STI
Tuner: EFI Logics
Dyno Info: Mustang 500SE
Baseline: None
Target Boost: 26
Fuel: 93 + 75/25 Methanol (Aquamist HFS-1)
Basic Modification list:
Dom 3.0XTR with 10cm housing
APS 725
APS 3" Inlet
APS 70mm Intake
Stock Engine
DW 850cc Injectors
APS 3.5" TBE
TGV deletes
Stock Manifolds
38mm EWG routed back in to exhaust
ProDrive Boost control solenoid
Aquamist HFS-1 (Single nozzle)
Cobb AP V2
Charts:
Blue Graph - Blouch Dom3 XTR 3" inlet 10cm - 93 Octane + Meth - 408hp 388ft/lb @ 26psi
Red Graph - Blouch Dom3 XTR 3" inlet 10cm - 93 Octane + Meth - 408hp 388ft/lb @ 26psi
Blue Graph - Blouch Dom3 3" 8cm - 93 Octane + Meth - 383hp 389ft/llb @ 26psi
Blue Graph - Blouch Dom4 3" 8cm - 93 Octane + Meth - 391hp 365ft/llb @ 26psi
Below are some pictures we took, from left to right you are looking at the following:
Dominator 3 XTR with 3" Inlet
Dominator 3 XTR with 2.4" Inlet
Old Dominator 3 with 2.4" Inlet
Thanks,
EFI Logics.com
EFI Logics.com / Myspace / Facebook /"New" Interactive Dyno Database
Subaru / Porsche / Mitsubishi / Ford / GM
Mustang AWD500SE - 60mph wind Dyno cell
8 Sympaug Park Road : Bethel, CT 06801
Phone: 203.748.1115
EFI Logics is offline   Reply With Quote
Old 12-16-2009, 03:41 PM   #52
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Is funny comparing your graphs to IAGs.
On your charts you clearly see that the old DOM 3 52lb spools faster than the newer DOM 3 XT-R 55lb; but on IAGs the newer version kill the old turbo on spool and power .
I would like to see the old DOM 3 with the big 10cm2 back housing, I am starting to think that the stupid wheel does nothing. I remember a long time ago that I asked someone knowledgeable if the weight of billet wheel had anything to do with the spool up time, the answer was NO, I wish I could find it.
Old 12-16-2009, 06:13 PM   #53
LittleBlueGT
Member#: 96204
2013 STI GR
Just like BB the actual weight of the wheel should not noticeably affect steady acceleration runs, like a dyno run or a street 3rd or 4th gear 2000-7000 rpm run.
What it will do is help with response, and boost recovery after a gear change (assuming not FFS).
Think about it, it is science, and all makes sense.
LittleBlueGT is offline   Reply With Quote
Old 12-16-2009, 07:54 PM   #54
Equilibrium Tuning
Member#: 26933
2006 STI
So the DOM 3 XTR spools slower than the old DOM 4?
-- Ed
Old 12-16-2009, 07:58 PM   #55
juanmedina
Member#: 133146
-- Ed
It looks like it spools a tad slower
Old 12-17-2009, 11:45 AM   #56
Equilibrium Tuning
Member#: 26933
2006 STI
Seems to make sense with the significantly larger exhaust housing. Any possibility this car had a pre-turbo exhaust leak or a boost leak?
-- Ed
Old 12-17-2009, 12:45 PM   #57
LittleBlueGT
Member#: 96204
2013 STI GR
-- Ed
It does. Makes me wonder if the 10 cm housing is really the way to go for the smaller DOM2.5xtr.
Old 12-17-2009, 02:15 PM   #58
stidoc
Member#: 147579
Yeah. I'm thinking I'll just go with old 2.5 or 3.0 with the 8 cm.
stidoc is offline   Reply With Quote
Old 12-17-2009, 02:24 PM   #59
LittleBlueGT
Member#: 96204
2013 STI GR
I wonder if one could get a new DOM 2.5xtr with 8 cm housing?
In other words, an old DOM 2.5 with new billet wheel.
Old 12-17-2009, 02:26 PM   #60
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
Im sure tuning has a lot to do with the results on these turbos. just because X vendor shows X gains and X spool doesn't mean the turbo isnt functioning properly.
it is possible Jorge had a slightly better approach to tuning the turbo at IAG
jnorth85 is offline   Reply With Quote
Old 12-17-2009, 06:10 PM   #61
Thran
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
i asked when i was trying to get the dom 3 xtr with a 8cm housing and they said no ; (
i was thinking logically this will technically get the turbo to spool faster with a smaller housing?
Thran is offline   Reply With Quote
Old 12-17-2009, 06:16 PM   #62
Equilibrium Tuning
Member#: 26933
2006 STI
Tuning can certainly have an effect on spool, but not in the range of 1000RPM. The interesting part is not the absolute spool they're showing but rather the relative. IAG shows the XTR turbo severely outspooling the original DOM3 while EFI is showing it to be significantly laggier than the original DOM3. Both cars in each comparison are tuned by the same tuner as far as I can tell.
To be honest, the IAG comparison seemed way too good to be true and made me wonder if it was done in the same gear or even the same platform (04-06 STI or 07+). People always want the magical turbo that will spool faster AND make more power. Sadly that almost never happens. Physics tends to win over in the end
-- Ed
Old 12-17-2009, 07:05 PM   #63
LittleBlueGT
Member#: 96204
2013 STI GR
-- Ed
SO true. I am starting to hate physics.
Old 12-17-2009, 07:58 PM   #64
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
yeah, its tough to push air through the same size hole faster while still being able to flow more air overall.
our subaru community seems to focus more on the compressor than the turbine cause we've been stuck with 7 and 8 cm for so long. the turbine is the true shaper of your powerband. you cant use the compressor to its potential if the turbine wont let it.
Old 12-18-2009, 09:54 AM   #65
Special
Member#: 145585
2002 S202 [email protected]
Yellow
Hey, I just tuned my DOM 3XTR for pump gas and the car is running great with no det. I noticed that the Defi EGT Gauge is climbing up to 9 though. Is 9 too high?
Special is offline   Reply With Quote
Old 12-18-2009, 10:04 AM   #66
Pops
Member#: 80412
that is true
Pops is offline   Reply With Quote
Old 12-18-2009, 06:08 PM   #67
Wrx_Fan_0717
Member#: 152080
6266 Precision'd Big
Cam'd 2.55l 6spd Bugeye
Damn right when i'm about to go rotated. Blouch why do you always do this.
Now i have to rethink what i want.
Originally Posted by Phatron View Post
i put an extra spring in my Tial Ext wastegate last night to have 20psi spring combo on my STI with OG Green and after the install my boost is pegging at 30psi on my STRi gauge. also on 91+meth. but the logger was only peaking at 28 psi.
And my external wastegate is no longer opening......kind of concerning me......but i picked up 2psi with the mbc in the same spot.
I would trust the map sensor....which one you running? Anytime i ran more than 27psi the EWG was almost silenced.
I had a hose pop of the compressor side of the turbo one time and ran the 20g unrestricted to 32-33psi doing a 70-130 pull an empty interstate. Thank god i run stupid amounts of meth (900cc of 100%) probably saved the motor. I pulled the log and only got -2* pulled from 5500 on.
Morale of the story, no fuel cut past 24psi....just be careful duder.
Wrx_Fan_0717 is offline   Reply With Quote
Old 12-18-2009, 08:06 PM   #68
mywifesSTi
Member#: 142709
07 STi Limited
FP HTA Green 372whp
I can't wait to get my car down to you for the install Chris. Still waiting on the stupid fmic. I hope to have it by the middle of next week. Getting parts has been such a pita since aps stopped shipping.
Bruce
mywifesSTi is offline   Reply With Quote
Old 12-21-2009, 04:49 AM   #69
GDAryder
Member#: 184753
2005 WRX
even for the half-rpm lag, thats still damn good IMO. 25whp extra at the same boost? yes plz!
GDAryder is offline   Reply With Quote
Old 12-21-2009, 10:22 PM   #70
mywifesSTi
Member#: 142709
07 STi Limited
FP HTA Green 372whp
^^^ I'm sure the large 725 fmic didn't help with the lagg.
Old 12-22-2009, 04:36 AM   #71
GDAryder
Member#: 184753
2005 WRX
it'll be worth it once the thing hits, trust me lol
Old 12-29-2009, 09:49 AM   #72
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
Any news on these installs?
Tnx,
Walter
Beetspeed is offline   Reply With Quote
Old 12-29-2009, 10:40 AM   #73
EFI Logics
Vendor
Member#: 193180
Unfortunately the car with the regular 2.5R with the 10cm hotside was an engine job, so we're awaiting his break-in. We'll be tuning this car on Monday.
The first car we installed a 2.4" 3.0XTR on is just about read after doing pistons and a FMIC as well, so that car will hopefully get tuned tomorrow.
We'll be doing another 2.4" 3.0XTR in a few weeks as well.
- [email protected]
Old 12-29-2009, 12:34 PM   #74
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
Thanks for the quick respons!
Good to hear more cars getting done with these XTR's. No holidays for you guys than huh?
Keep us in the loop on he results pls.
Old 12-30-2009, 08:28 PM   #75
mywifesSTi
Member#: 142709
07 STi Limited
FP HTA Green 372whp
- [email protected]
Please post the dyno chart as soon as Chris is done working his magic. Please list mods too. Hopefully it will be close to my mod list.
2.0 + Dom 3.0XT-R + E85 makes 392whp rexblake Proven Power Bragging 36 07-20-2010 10:58 PM
370WHP alternative to Dom 3.0XT-R turboICE Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 06-07-2010 12:04 AM
Dom 3.0XT-R and Dom 4.0XT-R Now Available Blouchturbo Engine/Power/Exhaust 17 02-04-2010 02:01 AM
Good News for those who like the Dual (3,3.5,DTM) and single 4" style exhausts GTBGUY Normally Aspirated Powertrain 85 05-24-2001 07:33 AM
