Old 09-11-2009, 01:55 PM   #426
AcquaCow
Member#: 36838
2000 RS Sedan
2004 STi w/RS body swap
Originally Posted by mav1c View Post
After 3 more track weekends, mine are still fine. And not a hint of rust.
You didn't drive your car all winter
VA road salt is ridiculously corrosive
That said, my stainless coilover bodies are still shiny-new, so the road salt doesn't seem to plague stainless...
AcquaCow is offline   Reply With Quote
Old 09-11-2009, 02:29 PM   #427
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
what coils AcquaCow?
djerickd is offline   Reply With Quote
Old 09-11-2009, 03:02 PM   #428
AcquaCow
Member#: 36838
2000 RS Sedan
Cusco Zero 2E
All stainless.
Old 10-29-2009, 05:15 PM   #429
sigurd
Member#: 128721
2002 impreza WRX
psm
just installed mine finally after having the kit for 4 months. Was doing wheel bearings so it was the perfect time to do it. I also canted my camber plates and got a full degree of caster. Between the both of them I am a happy camper. This is not a mod that goes un-noticed thats for sure.
sigurd is offline   Reply With Quote
Old 10-31-2009, 07:06 PM   #430
MonsterGC
Member#: 184090
2000 Subaru Impreza
BRP
Aquacow mine are the same passenger side is 1mm off and driver side is flush
MonsterGC is offline   Reply With Quote
Old 10-31-2009, 08:12 PM   #431
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
Over 17k miles, still no issues.
UFOpilot is offline   Reply With Quote
Old 10-31-2009, 08:16 PM   #432
STiRA-435
Member#: 191564
1999 WRX STi RA V-L
Installed mine last week.
My car is near stock height so the difference wasn't drastic but definitely an improvement.
STiRA-435 is offline   Reply With Quote
Old 11-04-2009, 12:28 PM   #433
todeswalzer
Member#: 191495
'05 WRB GTX3071R
JDM V8 EJ207 USDM 6MT
hey guys, when trying to remove that bolt holding the knuckle together i ended up snapping off the head (yes i had pb blasted t for a week or so, was using a torch, still snapped it) anyways, does anyone know if the ENTIRE bolt is threaded? like can i drive around and not worry about it or is only half the bolt threaded and a possibility of the ball joint falling out if i dont fix this issue before just saying f it and driving it as is. also what are my options now when i do end up removing this bolt? drill it out and tap? what can i do that will not **** up my knuckle. thanks
todeswalzer is offline   Reply With Quote
Old 11-04-2009, 01:04 PM   #434
AcquaCow
Member#: 36838
2000 RS Sedan
By design, the front bit of the knuckle where the bolt goes through should not be threaded... if it were threaded on both sides, you wouldn't be able to use the bolt to squeeze it together...
-- Dave
Old 11-04-2009, 02:24 PM   #435
todeswalzer
Member#: 191495
'05 WRB GTX3071R
good point, tat makes complete sense and thats what i thought but i wasnt sure.
would it be safe to drive around as is? or should i take action immediately. i only have today and tomorrow off then its back to work for a week and id have no time to mess with it
Old 11-04-2009, 02:29 PM   #436
AcquaCow
Member#: 36838
2000 RS Sedan
Well, you can be rest assured that the bolt itself won't be coming out, so the ball joint shouldn't just fall out on it's own, but it might losen up and possibly deform the socket it's installed in ala previous balljoint spacers that didn't fit tightly...
-- Dave
Old 11-12-2009, 11:58 AM   #437
DZnutz
Member#: 91837
dont be stupid and dont drive around... losing one of those is not fun
DZnutz is offline   Reply With Quote
Old 01-07-2010, 07:38 AM   #438
stevenkelby
Member#: 207569
MY04 Forester XT
Red
Hi All,
I have a new KCA313 that I've had for a while. Ready to install now, but is this the very latest design? Can I swap for the newest version if not?
Also Jim, when will the new ADJUSTABLE WHITELINE SWAY BAR BALL LINKS (BL-252) be available in Aus?
Thanks,
Steve
stevenkelby is offline   Reply With Quote
Old 01-07-2010, 08:31 AM   #439
03SubyWRX
Member#: 200767
2003 WRX 2.5 Hybrid
97 Impreza pimp wagon
That looks like the newer version of the kit. I believe the ones that had problems had tealish colored clamps on the boots.
03SubyWRX is offline   Reply With Quote
Old 01-07-2010, 08:34 AM   #440
stevenkelby
Member#: 207569
MY04 Forester XT
Red
Awesome thanks
Old 01-16-2010, 05:28 PM   #441
TXwrxWagon
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
WOW... 18 pages of posts... read probably 93-95%
willaty (sp sorry)... there was a mention of a specific ball joint too you recommended. Can you repost that? I looked 3-4 pages back from where it was mentioned & must have missed it.
Aquacow... I know what you mean about the Va salt... they put something something in that mix that i like acid on Japanese coated parts. NJ uses the same stuff.. eats everything...
One final thought, after reading all the posts after te V2 hit I think a few things come to my mind:
1.) each car will be a lil different. There maybe a slight gap (1mm or less) or one side or the other. Mark it or measure it. then check it occasionally.
2.) I think any movement people maybe seeing, post V2, is install related errors. Now now... don't everyone get your panties in a bunch. Its just like camber bolts, there are elements of this install that are easy to overlook.
3.) those who have been most vocal in this thread have all contributed immensely, & have all stated that V2 has solved the issue.
4.) It is a worth while upgrade, even for moderate to mild applications. I think Aquacow said it perfectly: no bump steer, no dartiness, no loose feeling, not vague (paraphrased) after a familiar & spirited mountain road cruise. Those were the things I was expecting to hear, especially since my Wagon will prob never see auto-x & rarely an open-track event.
5.) Bravo to Whiteline for stepping up, grabbing the Bull by the short-bits, & getting a solution engineered & on the shelves in record time.
oh.. PS those lazy one who don't read the entire thread.... :rant:
Rob
TXwrxWagon is offline   Reply With Quote
Old 01-16-2010, 05:40 PM   #442
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Comes from Napa.
Old 01-16-2010, 06:03 PM   #443
AcquaCow
Member#: 36838
2000 RS Sedan
Originally Posted by AcquaCow View Post
I loosened the bolt on the passenger one that was showing the gap (above) and popped it back in to place this weekend.
Re-torqued to 45ftlbs, will see how long it stays that way.
I need to grab an alignment before driving the car out, but after that, I'll drive it daily till winter and see if it moves at all...
-- Dave
Wanted to update... ~4000 mi down since I re-torqued to 45ftlbs... nothing has moved.
-- Dave
Old 01-16-2010, 06:41 PM   #444
STi-MAN
Member#: 70252
05 STI
blue
Many track events.. ball joints and tie rods seem up to the task as well.
STi-MAN is offline   Reply With Quote
Old 01-16-2010, 11:14 PM   #445
Whiteline Jim
Member#: 212668
2008 Sti
G’day everyone,
Good news it seems, thanks for the feedback.
Stevenkelby, sorry for delay in getting back to you but we’ve got our summer holidays over here. 03SubyWRX is right, that is current version of the kit so it should be fine. Would love to hear you're feedback once you've installed it and had a good drive.
TXwrxWagon, great summary, we'd obviously agree that it's a worthwhile upgrade for any performance enthusiast and not just a racers option.
AquaCow, very pleased to see its working out for you.
Cheers
Whiteline Jim
Whiteline Jim is offline   Reply With Quote
Old 01-16-2010, 11:21 PM   #446
stevenkelby
Member#: 207569
MY04 Forester XT
Red
Great thanks Jim, hope you had a good break Will forward you a link once installed and reviewed.
Also, when will the new ADJUSTABLE WHITELINE SWAY BAR BALL LINKS (BL-252) be available in Aus?
Old 01-17-2010, 02:26 AM   #447
chimchimm5
Member#: 88501
2006 WRX Wagon
CGM
Originally Posted by Whiteline Jim View Post
G’day everyone,
Cheers
Whiteline Jim
If someone used stock springs, would there be any reason to use the RCA kit?
If not, at how much lower would it begin to be useful to use the RCA kit? (ie mildly lowered cars)
chimchimm5 is offline   Reply With Quote
Old 01-17-2010, 12:21 PM   #448
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Yes. Improved bump steer. Improved roll control. Improved location of roll center. Improved camber curve.
Old 01-17-2010, 12:43 PM   #449
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
I agree with Ty. I had my stock struts and springs on for a bit while rebuilding my coilovers and they helped tremendously. Very noticeable with stock springs and struts. My friend had a set on his stock Evo IX, his only suspension mod and he was absolutely floored by the difference just this small geometric change made to the handling of his car (less front roll, more front end grip). Same results for me on the stock struts/springs.
Arnie is offline   Reply With Quote
Old 01-17-2010, 11:07 PM   #450
chimchimm5
Member#: 88501
2006 WRX Wagon
CGM
Hmmm. Intriguing. May then add this to the list.
Did Subaru add a "RCA" to the new GR impreza? If not, I wonder why?
FS: Whiteline Roll Center Adjustment kit - KCA 313 UM-WRXer Suspension/Brakes/Handling 4 12-03-2009 09:34 AM
FS: Whiteline Roll Center Adjustment kit - KCA 313 UM-WRXer Tri-State Area Private Classifieds 3 12-03-2009 09:34 AM
Brand new in Box - Whiteline Roll-Center Adjusting Kit & Kartboy Pitch Stop Mount! CALIBAN Suspension/Brakes/Handling 6 03-06-2009 05:33 PM
fs: 169 BRAND NEW Whiteline Roll Center adjuster kit fastwrx25 Suspension/Brakes/Handling 3 07-29-2007 03:53 PM
Message Board Statistics All times are GMT -4. The time now is 08:00 PM.
