Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 01-30-2010, 03:20 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default How to install Grimmspeed AOS (air oil separator) on WRX
Spent 30 min installing Grimmspeed air oil separator on my WRX today.
1. Disconnect this hose which is connected to TMIC hard pipe.
2. Position the disconnected hose facing toward oil cap as shown here. Connect supplied plastic connector:
3. Remove oil cap
4. Cap the nipple off of turbo inlet close to turbo by using supplied rubber cap.
Old 01-30-2010, 03:20 PM   #2
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
5. Install AOS into oil inlet.
6. Using ~9" of supplied hose, connect upper port of AOS (middle one) to turbo inlet return line.
7. Using supplied hose, connect left bottom port with "T" from crankcase.
8. Using supplied hose, connect right bottom port with TMIC hard pipe.
Old 01-30-2010, 03:27 PM   #3
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
9. Go for a test drive
Old 01-30-2010, 03:28 PM   #4
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Old 01-30-2010, 03:28 PM   #5
Longshot55
Member#: 164121
2005 WRX EvoIII 16G
EFI Logics Tuned
great writeup bro, it was colder today than yesterday lol. Hopefully you had a heated garage or some nice gloves.
Longshot55 is offline   Reply With Quote
Old 01-30-2010, 04:03 PM   #6
wantsti
Member#: 134764
04 sti
java black pearl
Its kinda dumb it covers the dip stick so you cant check your oil.
wantsti is offline   Reply With Quote
Old 01-30-2010, 04:52 PM   #7
djoye
Member#: 50072
[email protected] 20psi
That really explains a lot, I was wondering what the hell the oil dumped into but I guess it goes on back around. If it weren't so pricey I'd dump my junk catch can.
djoye is offline   Reply With Quote
Old 01-30-2010, 05:06 PM   #8
Digitalfiend
Member#: 54823
2008 STI
It won't affect all cars the same way. For instance, on my '08 the dipstick and oil filler neck are very far apart:
Digitalfiend is offline   Reply With Quote
Old 01-30-2010, 05:15 PM   #9
BadTrainDriver
Member#: 201416
1998 Impreza L
Nice Sweater...now turn your Dipstick the correct way...)
BTD.
BadTrainDriver is offline   Reply With Quote
Old 01-30-2010, 05:21 PM   #10
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
n/m I answered my own questions.
Helps when you read =P
Old 01-30-2010, 07:26 PM   #11
WRX Loki
Member#: 208332
06 Hawkeye Wagon
Red
Nice Write Up
WRX Loki is offline   Reply With Quote
Old 01-30-2010, 10:29 PM   #12
jokers
Member#: 136839
u might wanna reroute that hose, may slide and obstruct the throttle linkage
or the end of the throttle linkage could pierce a hole in the hose
jokers is offline   Reply With Quote
Old 01-30-2010, 10:35 PM   #13
jokers
Member#: 136839
heres my setup 02 wrx
and doesnt obstruct my dip stick either cool
im goin to redo my intake line, gonna get some clear tygon line, so i can see if there any oil going to the intake, just a precaution
Old 01-30-2010, 10:42 PM   #14
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Hose is really tight in there, so it won't move to obstruct throttle linkage. Also, I think end of throttle linkage is not sharp enough to pierce the hose.
Surprised you were able to turn it that much though as I can no longer turn more than the current setting.
Old 01-30-2010, 11:50 PM   #15
jokers
Member#: 136839
lossen the middle turn the outer where u want it tighten the middle down
Old 01-31-2010, 01:35 AM   #16
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Here is the final version. I plan to re-route them so oil dip stick can be more accessible.
Jokers, that's another good way to route the hoses. It's just annoying that you have to remove the TMIC.
Old 01-31-2010, 09:41 AM   #17
thrasher
Member#: 40579
2002 WRX Stage 2+
Tuned by IA Performance
This is how I'm going to do it too. Blocking the dipstick = FTL!
Thanks guys!!
thrasher is offline   Reply With Quote
Old 01-31-2010, 09:51 AM   #18
jokers
Member#: 136839
hey get it done the first time
Old 01-31-2010, 03:58 PM   #19
gtboost
Member#: 87716
2005 FXT
thanks for taking the time to do a writeup.
gtboost is offline   Reply With Quote
Old 01-31-2010, 04:36 PM   #20
bigolrig
Member#: 185347
2002 EVO3 bugeye wag
EG33 Swapped 2 dr RS
do you have to use the GS cap?
i have a cobb oil cap and was wondering if the A/O was threaded like stock
bigolrig is offline   Reply With Quote
Old 01-31-2010, 04:57 PM   #21
jokers
Member#: 136839
ur gonna have to sell it
Old 01-31-2010, 05:15 PM   #22
XmikeX
Member#: 184768
05 WRX
toasted white
feel any difference? i wouldnt expect you would but justwondering
XmikeX is offline   Reply With Quote
Old 01-31-2010, 07:02 PM   #23
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
jokers,
where does that driver side breather line route to??
scoobystas is offline   Reply With Quote
Old 01-31-2010, 07:14 PM   #24
passion4JC
Member#: 46389
2003 WRX Stg 2.5
^^^that?
passion4JC is offline   Reply With Quote
Old 01-31-2010, 07:23 PM   #25
jokers
Member#: 136839
Originally Posted by scoobystas View Post
jokers,
its routes to the T of the crankcase and pcv
How To Install: Perrin Cold Air Intake for 09 WRX Agile32wrx Interior & Exterior Modification 8 02-14-2010 01:12 PM
any reviews on the PROVA AOS air oil seperators? 949 Built Motor Discussion 0 07-26-2009 12:10 PM
How to install Tribeca (25mm) front sway bar on an 96 impreza brighton - pictures Ninja007 Brakes, Steering & Suspension 3 11-15-2008 09:37 AM
How to install SPT cold air intake??? Hybridz4eva Southern California Impreza Club Forum -- SCIC 20 05-11-2007 03:01 PM
