Welcome to the North American Subaru Impreza Owners Club Monday December 22, 2014
Old 09-21-2009, 02:51 PM   #176
scramjett
Member#: 192526
2008 WRX FMIC/VF48
Red/Steel Grey
Originally Posted by Tuned200 View Post
This thread is for the VF48, not the VF39 or VF43.
They're all the same... Now then, if it were a VF30/40/46, then sure I can see your point.
scramjett is offline   Reply With Quote
Old 09-21-2009, 05:08 PM   #177
BVM
Member#: 41049
2010 Impreza WRX
KTM 250sx
PWN3D
Why do you think I posted my results here? Cause I have a VF48!
BVM is offline   Reply With Quote
Old 09-22-2009, 09:04 AM   #178
Tuned200
Member#: 127740
2007 FSXT-Mine
2007 F-STI-Her's
Not really the exact same. But close, hence the VF48 thread, There is a vf39 thread, so this is for those of us who use the newer turbo.
Im sorry, I saw your car was a 04 STI and could not grasp why someone would swap the 39 for the 48 when the gains are min. Again, my bad.
Back on topic.
Tuned200 is offline   Reply With Quote
Old 09-22-2009, 07:01 PM   #179
BVM
Member#: 41049
2010 Impreza WRX
KTM 250sx
Because my VF39 was cracked and I got a replacement for it (VF48) new for $600.
Old 11-02-2009, 07:14 AM   #180
shatteringstar
Member#: 149604
2006 Limited WRX
bump b/c i like this thread and it needs more posts.
shatteringstar is offline   Reply With Quote
Old 11-03-2009, 09:06 AM   #181
scramjett
Member#: 192526
2008 WRX FMIC/VF48
Red/Steel Grey
Can someone post their 3rd gear pulls to redline?
Old 11-03-2009, 03:48 PM   #182
Tuned200
Member#: 127740
2007 FSXT-Mine
2007 F-STI-Her's
I would but it would be an auto, so bump for a manual 3rd gear pull.
Old 11-06-2009, 03:02 AM   #183
shatteringstar
Member#: 149604
2006 Limited WRX
video, dyno, or what?
Old 11-06-2009, 02:45 PM   #184
Squillo
Member#: 193400
02 Subaru WRX
mbp vf48 316 whp
oops double post
Squillo is offline   Reply With Quote
Old 11-06-2009, 02:48 PM   #185
Squillo
Member#: 193400
02 Subaru WRX
mbp vf48 316 whp
hey guys im trying to do a vf48 build in my 02 wrx this spring im aiming for 280-290 whp with 20 lbs. of boost, i plan on running
vf48
08 sti 560 injectors
255 fuel pump
fmic with hks ssqv bov
gms turbo inlet and after maf hose
short ram intake
full catless exhaust
lightned crank pulley
and im thinking about tgv deletes and the intake spacer.
My question is will these injectors do the job or should i look into 650cc i dont plan on going bigger and was told the 560 are fine. Also are the tgv deletes and the intake spacer worth it? And are there any other little parts i should think about getting i have a mbc i can use and i see a lot of people using the ebcs from grimmspeed.
Old 11-07-2009, 01:20 AM   #186
shatteringstar
Member#: 149604
2006 Limited WRX
560cc injectors will work but thier duty cycles will be high. i think u'd be off with bigger injectors if u can afford'em. IMO, tgv deletes and the intake spacer go the same way... if u can afford them go for it. all that little stuff adds up
Old 11-07-2009, 01:32 AM   #187
Squillo
Member#: 193400
02 Subaru WRX
mbp vf48 316 whp
^^^ thanks and im sure the 560 would be fine but i saw a guy with a 2.0 with a vf39 set up and he had some nice numbers like 282 whp but he had 650cc at 97%. What decides what size injectors you need?
Old 01-06-2010, 02:39 PM   #188
RDD201
Member#: 171743
04 FXT Premium
JBP
Very cool thread, My 2.0 Wrx has
VF48 ( of course)
dw 650s
06 Sti ic
Cobb tbe
Perrin uppipe
Grimmspeed ebcs & Gimmick inlet hose
SPT intake
walbro 255
couldn't afford dyno tune at the time, so did a road tune @ 18psi for now. Car pulls hard as *****! Dyno tune & sheets coming soon. Dave Brown @ mSPT is the man. Great guy
RDD201 is offline   Reply With Quote
Old 01-11-2010, 02:06 AM   #189
Joshwrx04
Member#: 135429
'05 CGM STi cornfed
'82 s-10 (427'nd soon)
bump for a great thread....
Joshwrx04 is offline   Reply With Quote
Old 01-11-2010, 02:13 AM   #190
hammyt
Member#: 92585
2005 Saab 9-2x Aero
13.6@100 EJ205 VF48 93Oct
Ah Forgot to update after my tune. My Setup:
EJ205
VF48
STi TMIC
Gimmick Turbo Inlet
06 WRX Injectors
Walbro 255
GMBCS
STi UP
Invidia Catless DP wrapped
P&L HiFlo Intake
Put down 274whp/248wtq on P&L's dyno. On an 86 degree day. Which reads about 165/165 stock IIRC. Stock tranny and clutch, definitely pulls.
hammyt is offline   Reply With Quote
Old 01-17-2010, 08:01 PM   #191
bslayman
Member#: 93433
Default 2003 Wrx
I just completed this setup last summer.
VF48
AEM intake
Pink injectors
walbro 255 fuel pump
Full Prodrive exhaust system with Stromung exhaust tip
Yimi Sport tuned
274whp
254tq
It was 99 degrees outside!
Just added xS-Power TMIC. I was running the OEM TMIC when it was tuned by Yimi.
Car pulls longer with the larger TMIC
bslayman is offline   Reply With Quote
Old 01-25-2010, 06:07 PM   #192
Tuned200
Member#: 127740
2007 FSXT-Mine
2007 F-STI-Her's
Good numbers everyone!
Old 01-28-2010, 06:42 PM   #193
Squillo
Member#: 193400
02 Subaru WRX
mbp vf48 316 whp
has anyone ran this with a no name ebay tmic? i need a bigger tmic and for the price of a sti one i might get a ebay one i know the ebays suck but for 150 it will get the job done.
Old 01-29-2010, 02:20 AM   #194
shatteringstar
Member#: 149604
2006 Limited WRX
id say mine is a "no name" ebay TMIC
but then again, thats the one and only piece i regret. that one weak link cost me ~10HP b/c it would heat soak so fast. Jorge (P&L) tuner had to tune my car down alittle b/c he didnt like what he was seeing out of me "css" TMIC.
short story:
CSS started out on Ebay, then became a NASIOC vendor but couldnt cut it, and now last i heard they are out of business.
Old 01-29-2010, 02:40 AM   #195
hammyt
Member#: 92585
2005 Saab 9-2x Aero
I am also running one of Jorge's conservative tunes because of the heatsoak with my '04 STi TMIC. Wish I could afford a bigger TMIC
Old 01-29-2010, 02:44 AM   #196
Squillo
Member#: 193400
02 Subaru WRX
mbp vf48 316 whp
short story:
do you have anything to prevent heat soak? will a turbo heat shield help out at all, but other then the heat soak your css tmic is doing pretty good with the vf48?
Old 01-29-2010, 03:18 AM   #197
shatteringstar
Member#: 149604
2006 Limited WRX
i have a modified stock heat shield over my turbo
and yes besides heat soak it's fine. originally i had to clean up the ports on the TMIC. (just to level them out and clean them up alittle)
Old 01-31-2010, 01:16 AM   #198
jdm05
Member#: 180155
e85 05 wrx
Just got my vf48 tuned for e85 and love it! Go green.
jdm05 is offline   Reply With Quote
Old 01-31-2010, 04:02 AM   #199
sleeperxt06
Member#: 153715
06 fozXT, 09Tribec
,11 OutbackWag
Nice! Any dyno charts? Or was it a street tune?
sleeperxt06 is offline   Reply With Quote
Old 01-31-2010, 01:24 PM   #200
jdm05
Member#: 180155
e85 05 wrx
yea it's on the Cobb surgeline on this forum. Mine is the 05 Wrx with 92 & e85
Should I swap VF39 for the VF48 on 03? guru_method Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 07-31-2010 03:28 PM
Deleting the weapon thread.. and the whining thread about me locking it is even lamer Fish Texas Impreza Club Forum -- TXIC 14 07-01-2010 01:29 PM
What is the max boost for the VF48? Tuned200 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 02-17-2009 05:59 PM
Quest for 11's in the VF48 Saabaru (How much more can I get out of my VF48?) cireturbo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 30 09-24-2008 02:32 AM
Why did the 'Discsussion' thread for the SOA recommendation thread get closed? left footed whooten News & Rumors 6 09-05-2006 01:47 PM
