Welcome to the North American Subaru Impreza Owners Club Saturday January 24, 2015
Go Back   NASIOC > NASIOC General > Warranty Issues & SOA Problems
Old 06-10-2002, 02:58 AM   #276
jputnam
Member#: 7348
2002 WRX Wagon
Default CEL P0301 P0303
My 02 WRX Wagon 5sp has 15k on it. History is as follows:
4100 Miles: P0303 & P0301 - Car idles rough hesitates at 2500prm
-ECU Sent to SOA for Reprogram
-CEL's go away, idling persists
7300 Miles P0301 Car still idling Rough
-Reset ECU
-Problem persists with idle
9840 Miles - Bank 1 too lean (i Forget the CEL Code)
-Replace 02 Sensor
-Idling improves, hesistation remains
14850 - P0301
-Idling still rough, car stalls occasionally at idle when A/C gets turned OFF.
Dealer schedule appt, going to check plugs in 1 & 3 for wear.
jputnam is offline   Reply With Quote
Old 06-14-2002, 10:42 PM   #277
wrxsvt
Member#: 2981
Trans: 5mt
Miles: 9,703
Date: 6/14/02
Codes: P0301, P0302, P0303 (Misfire in all but cylinder 4)
I let Auto Zone pull the codes for me and clear them since they do it for free.
It was about 60 degrees and fairly humid early in the morning when it went on. The car displayed no unusual behavior; just the slight hesitation on boost like it always does when it's cold. Got it cleared after work and drove 20 miles home and it hasn't recurred.
My only engine mods are the intake silencer removal and the 3/16" mod.
wrxsvt is offline   Reply With Quote
Old 06-16-2002, 05:58 PM   #278
gusman21
Member#: 13767
2k5 MCS
Jet Black
my cel blinks every couple of days. it has been on for 3 months now. keep dropping the car off at the dealer and they keep telling me to pay.
starting to get real pissed.
from what i remember, the code was a misfire in 1, 2, 3 and 4 all at different times:
0MPH
9MPH
45mph
EACH ONE DIFFERENT FROM THE NEXT.
i have the GND mod and the SPT muffler. my warranty is void.
***...i hate subaru.
-=GuS=-
gusman21 is offline   Reply With Quote
Old 06-21-2002, 05:53 PM   #279
mantis
Member#: 7667
2002 WRX Wagon
0MPH
9MPH
45mph
-=GuS=-
mantis is offline   Reply With Quote
Old 06-22-2002, 01:27 AM   #280
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
WR Blue. Cobb Stage 2
Default gusman21
I don't understand why your warranty would be void. Did your dealer give you a reason?
sajohnson is offline   Reply With Quote
Old 06-22-2002, 10:44 AM   #281
mantis
Member#: 7667
2002 WRX Wagon
I meant to ask that sajo.
Old 06-23-2002, 05:42 AM   #282
imprez_kyoso
Member#: 2369
2003 Cooper S
Chilli Red
transmission manual (GC8)
mileage 4700+ what code was retrieved by the dealer P1445
name of dealer MACK MASSEY
what action the dealer took...ECU was sent out to get reprog..
imprez_kyoso is offline   Reply With Quote
Old 06-23-2002, 04:28 PM   #283
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
Default Mantis
Gusman21: Please ask the dealer, and let us know the answer. I realize this may be more appropriate to the "Warranty Issues & Problems" forum, but either way it is very important that people know.
Old 06-24-2002, 01:44 PM   #284
rwroth
Member#: 6431
Midnight Black Pearl
Default CEL - multiple times
Car: WRX 2002
Transmission: Manual
VIN: (need to look up)
CEL Code - P1904 (not a valid code).
Taking to dealer to check on this - has done it a few times (every 500-600 miles, but now it does it almost every other time I start the car).
Note: also, the car appears to go into limp mode when this cel is received, but runs perfectly fine after resetting the code.
rwroth is offline   Reply With Quote
Old 08-07-2002, 04:13 PM   #285
Valien
Member#: 8584
2002 WRB WRX.
04 Honda Odyssey!
Of and on for the last 9000 miles or so (roughly).
P0340 - Camshaft Position Sensor. Dealer replaced under warranty.
About a month later, same thing. Dealer said everything is ok. Cleared code.
Then over the last 2 months..on and off..bucking..hesitation..on and off..blah blah blah. Dealer said everything is ok. Remove your BOV, that's causing it <--riiiiight! So i did it anyways...200 miles later.. on again.
Finally got it back to the dealer this week..car is back to stock except for uppipe (it was happening way before i had my uppipe). Dealer called SOA and they said to ship the ECU back for a reprogram.
hopefully this will cure it. right now that corolla they gave me is gutless! hehehe
Only other code i got was a Cat Inefficiency code. Had AutoZone clear it for me for free.
Valien is offline   Reply With Quote
Old 08-12-2002, 02:58 AM   #286
rexdaddy
Member#: 8657
2004 WRX STI
The first 4 cel's I reset myself until I got smart about this. The first ones were due to fueling up w/ car running, loose gas cap, poor gas ...ect.
WRX 02 Sedan
* transmission : Manual
* what date/mileage : 21,000 and 24,500 (1.5months apart)
* what code was retrieved by the dealer: P0325 and P0302
* name of dealer: Luther Subaru/Acura
* what action the dealer took: Sent ecu out for reprogram, Found #2 fuel injector to be failing and replaced it.
I placed the dealship on notice in writing that I plan on invoking the MN Lemon Law if I experience further problems with the car. Oh and I am on windshield #2.
rexdaddy is offline   Reply With Quote
Old 08-12-2002, 08:39 AM   #287
gusman21
Member#: 13767
2k5 MCS
Jet Black
i had a BOV and took my car to Lynnes Subaru. that is why they voided it.
i got a p0546 (low EGT input)
i replaced my EGT sensor a while back because ANOTHER dealer said that it failed. hmmm...looks like i have a wiring short.
-=GuS=-
Old 08-12-2002, 01:24 PM   #288
cierex
Member#: 9760
1995 Supra 6sp T88
WRX '02
Manual Tranny
~9500 & ~9550
CODE P0546
The code occured twice on 08/10/2002, both while I was cruising ~65-75MPH. I pulled the codes with my obd2 reader. I have an uppipe, turboback, and unichip so I can't bring it to the dealership anymore. Did a search and found out that this was a common problem. I will do the 2.2 kohm resistor mod to eliminate the CEL. I do have an EGT & A/F gauge and everything read fine when the CEL came on.
cierex is offline   Reply With Quote
Old 08-14-2002, 02:49 AM   #289
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
Default gusman21
Your warranty is void??! Why? Just the BOV?
Old 08-14-2002, 09:09 AM   #290
gusman21
Member#: 13767
2k5 MCS
Jet Black
uh huh.
-=GuS=-
Old 08-14-2002, 02:43 PM   #291
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
Default gusman21
I'd remove it and go to another dealer. Or have they made some permanent note in your file?
Old 08-14-2002, 06:47 PM   #292
gusman21
Member#: 13767
2k5 MCS
Jet Black
permanant.
-=GuS=-
Old 09-09-2002, 04:21 PM   #293
big reach
Member#: 17388
Default P0301
* WRX '02 Sedan
* MT
* ~9000 miles
* 09/08/02
* CEL P0301 - Misfire in Cyl 1
* ECU pulled and shipped for a reflash
Was sitting at idle with car warm when the CEL came on. RPM's were 807 and speed was 0 mph. The only thing of note was filling up at a diff. gas station the day before (Shell 93oct.) and cycling the air on and off at idle....(was drying my hands with the A/C).
Does anyone know what Subaru does when they reflash the ECU? Do they change the tolerances for the code?
big reach is offline   Reply With Quote
Old 11-26-2002, 06:25 PM   #294
MMastro
Member#: 18230
1993 EG Civic/ITR
WRX 02 Sedan received May 2001
* what date/mileage : ~4,000 (8/01) and ~24,000 (11/02)
* what code was retrieved by the dealer: P1443 (2nd time I pulled it myself with Delta Dash)
* name of dealer: Incidence 1 Middlesex Foreign Cars
Incidence 2 talked to Flemington Subaru and they said I will need a reprogram done by SOA hq taking 3 days
* what action the dealer took: incidence 1 replaced solenoid valve
incidence 2, I 'm yet to get the reprogram but they informed me of what will be done when I bring it in
MMastro is offline   Reply With Quote
Old 11-27-2002, 12:27 AM   #295
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
* manual
* went on around 2900 miles
* CEL P0303 - Misfire in Cyl 3
* dealer: Mile One (MD)
* mechanic reset ECU, test-drove car
Mike Wevrick is offline   Reply With Quote
Old 12-22-2002, 01:43 PM   #296
Scottie
Member#: 2080
06 Impreza Wagon
Red
'02 WRX Sport Wagon 5MT
36,800 miles
Code: P0303
Freeze frame data:
Eng. Coolant Temp- 194F
Fuel System Status-Open loop
Load-2%
Long term fuel trim-4.7%
MAP-13.3 in.hg
RPM-717
Short term fuel trim-.78%
Vehicle Speed-0.0 mph
Haven't brought it to a dealer yet. Will likely clear this first one myself and see if it happens again.
Scottie is offline   Reply With Quote
Old 01-03-2003, 11:37 PM   #297
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
* manual WRX sedan (WRX #2")
* 18,800 ish
* P0301/P0303 at same time. Freeze frame data on 0301 similar to post above
* Chaplins Subaru
* not taken in yet.
Symptoms: trouble starting and rough idle today.
Also: detonation and ignition/boost retard at ~5200 RPM (though it has been ok this week).
ANZAC_1915 is offline   Reply With Quote
Old 01-14-2003, 10:49 PM   #298
eyehate
Member#: 10223
* manual
* 34000
* P0453 The PCM has determined that the voltage signal from the pressure sensor in the evaporative emission control system is too high for the current engine operating conditions.
* autozone
* i have yet to take it to the dealer.
i have searched for this error, but there isnt really any info on it... and i have no idea what anything in that sentance means.... maybe an o2 sensor?
eyehate is offline   Reply With Quote
Old 01-14-2003, 11:48 PM   #299
Jon [in CT]
Member#: 2992
02 WRX Sedan
Originally posted by eyehate
[B* P9453 The PCM has determined that the voltage signal from the pressure sensor in the evaporative emission control system is too high for the current engine operating conditions. [/b]
You must have meant P0453- Evaporative emission control system pressure sensor range/performance problem.
Th factory service manual recommends you check that the fuel filler cap is tightened securely and the pressure/vacuum lines between the fuel tank and its pressure sensor. Also check for leakage/disconnection/clogging of the air ventilation hoses and pipes between the fuel filler pipe and the fuel tank.
Jon [in CT] is offline   Reply With Quote
Old 01-15-2003, 03:24 PM   #300
jetsiphon
Member#: 31070
2002 WRX Sedan
W.R. Blue
manual
code: PO303 (MISFIRE #3)
purchased car with 13000 mi.
on and off about every 3 - 4 days
took to shortline subaru
shortline said they were flying someone in form SOA to remap my ecu, yet to be seen.
jetsiphon is offline   Reply With Quote
Little Help please stock 06 WRX Check engine light Jkmaynard Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 06-08-2008 11:33 PM
2004 wrx check engine light fix kbcr3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 02-21-2005 06:29 AM
o4 wrx check engine light came on? shaka17yeah Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-18-2004 05:00 PM
WRX Check Engine light log albunny88 New England Impreza Club Forum -- NESIC 1 05-18-2001 12:45 PM
