Go Back   NASIOC > NASIOC General > Motorsports > Press Releases
Old 02-08-2010, 04:10 PM   #1
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Default Turn in Concepts 2010 Track Car Build
Seems like everyone else is doing a 2010 thread, so we figured we would as well. Many of you are familiar with our car from last year.
The car was very successful last year and allowed us to win the Redline Time Attack AWD Street Class title as well as 1st in class and 4th overall at the One Lap of America. For this year we are going to build upon the success of the setup by refining the aero, building a new engine to make more power, increasing the safety and fixing the mess (more on this).
One of the events we did last year was the 25 Hours of Thunderhill. Some of you may have seen this picture that was featured in a Japanese magazine which has become the focus for our ad campaign for this year.
A day later and into the race and we suffered a fire that took out half the engine wiring harness and caused all kinds of other issues. The race was a great learning experience for us and will prove to make the car even faster and more reliable going forward.
Couple pics of the damage. Basically, everything in the top right corner of the engine bay was toasted. We got lucky that there wasn't more damage to surrounding components.
Nice hot spot on the hood.
Fire damage seen from the inside!
Old 02-08-2010, 04:10 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
We first set off to fix the fire damage. Got the engine out of the way and started to tear into cleaning. A good pressure wash clean up most of the soot pretty well. We sanded and painted the area and it actually came out pretty well. We picked up a new wiring harness and installed it. Thought making our own since the car will be on a stand alone EMS this year, but didn't want to mess with it. Maybe next year.
While the engine was out we decided to run new fuel lines. We will be running a 3582 this year in place of the 3071 and wanted to make sure we could supply plenty of fuel to the engine. We ran new hardlines from the fuel cell all the way out to the engine bay.
Terminating fittings for the engine bay.
Bulkhead fittings. These are right next to the brake booster on the inside of the car.
Also while the dash was out we decided to get rid of the giant blower motor and box. We wanted to save the weight if possible, but still need the fan system and more importantly heat for what we do with the car. Our solution was to take some brake duct fans and put them blowing into the box where the heater core sits. We pulled the resistor pack off the stock blower motor and wired the fans such that the stock blower switch operates them. They blow differently on all four speeds and have about the same amount of airflow as the stock blower motor. We routed ducting to the normal air inlet position so that it is always pulling in fresh air.
Old 02-08-2010, 04:11 PM   #3
Turn in Concepts
Member#: 93646
Many Track Records
For braking this year we are changing from the wilwoods we had to Stoptech ST40's.
Wheels are going to be 18x10 Rota DPT's from Wheeldude.com. We are going to be running 275 35 18 RA1's most likely.
Aside from that, we still have to figure out a new fuel cell. After this one got bent we need replacement. We also need to figure out a new seat as our seats were stolen at the last race. Hope to have more updates soon.
Old 02-08-2010, 04:27 PM   #4
STi-MAN
Member#: 70252
05 STI
blue
Do you guys have a guess at what started the fire?
Looking forward to seeing the 2010 build
STi-MAN is offline   Reply With Quote
Old 02-08-2010, 04:32 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Why yes, yes we do. Oil feed fitting for the turbo came lose, and sprayed down everything with oil. Which was in turn ignited by a very hot turbo and exhaust.
Tony is working on the rest of the posts for this thread so more info coming in those (you jumped in faster than he can type).
Old 02-08-2010, 05:26 PM   #6
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Back up just one second.
What????
trhoppe is offline   Reply With Quote
Old 02-08-2010, 05:32 PM   #7
Daishi00
Member#: 78952
2005 WRX
CGM
Tom beat me to it. Who the hell steals seats at a racing event? How the hell didn't they get caught?
Some people
Daishi00 is offline   Reply With Quote
Old 02-08-2010, 06:13 PM   #8
MasterKwan
Member#: 98961
2003 WRX
Is the cage just welded to base plates welded to the floor sheet metal?
MasterKwan is offline   Reply With Quote
Old 02-08-2010, 06:19 PM   #9
Turn in Concepts
Member#: 93646
Many Track Records
There are doubler plates on the other side.
Old 02-08-2010, 06:21 PM   #10
Turn in Concepts
Member#: 93646
Many Track Records
Some people
Seats were out of the car. One of the drivers for the 25 hours race didn't want our seat in the car so it go switched. The seat was with the rest of our stuff on a trailer and was stolen. Nothing else was, just the two seats we had.
Old 02-08-2010, 06:40 PM   #11
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
You guys have a welder? I think welding the plates to the body at the bulkheads on the fuel lines would be more secure then sheet metal screws, maybe nows the time to put them inside the cage at the same time. With the wide selection of Wilwoods what made you guys switch to ST40's? Looks like alot of changes for 2010 season good luck with the rebuild you guys seem to have a good start on things.
Token-Negro is offline   Reply With Quote
Old 02-08-2010, 07:16 PM   #12
PitwrkzZ1
Member#: 94316
Have you thought about flocking the dash since its out of the car? It cuts down on glare on the windshield big time and it only takes the afternoon if you get the DIY kit.
PitwrkzZ1 is offline   Reply With Quote
Old 02-08-2010, 07:55 PM   #13
Turn in Concepts
Member#: 93646
Many Track Records
That's actually a really good idea. We've talked about suede or alcantara wrapping it, but we never got past the talking about it stage.
Old 02-08-2010, 09:28 PM   #14
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
looking foward to the rest of the build! what a bunch of low life scummers that stole your stuff. whats this world coming too
wrxtremeWGN is offline   Reply With Quote
Old 02-09-2010, 12:22 AM   #15
Kosmic
Member#: 99140
GD Racing chassis
Slowly in construction
wOOt!! another race car build thread. Watching closely.
Kosmic is offline   Reply With Quote
Old 02-09-2010, 01:40 AM   #16
jagstyle
R.I.P.
Member#: 155186
2007 STI
wouldn't a 9.5" be more appropriate for a 275?
jagstyle is offline   Reply With Quote
Old 02-09-2010, 03:02 AM   #17
Back Road Runner
Member#: 60082
2004 Forester STI
someone stole your seats?!
What I read: blah...blah...car fire...blah..."someone stole our seats"...uuuurt! What?!
That car kicks serious butt. I always enjoy you guys supporting the Subaru community and representing the Subaru brand name.
Back Road Runner is offline   Reply With Quote
Old 02-09-2010, 08:11 AM   #18
Turn in Concepts
Member#: 93646
Many Track Records
Yes, but we already have a set of those and wanted something we could comfrotably run 285's on.
Tony
Old 02-09-2010, 08:16 AM   #19
ed10
Member#: 198026
2002 Impreza WRX
Nulla Tenaci Invia EstVia
burn-in concepts?
ed10 is offline   Reply With Quote
Old 02-09-2010, 08:42 AM   #20
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Flocking is definitely a good plan, and not hard by all accounts.
sniper1rfa is offline   Reply With Quote
Old 02-09-2010, 08:54 AM   #21
loworbitSI
Member#: 60981
05 996 GT3
Looking good! All the best for '10!
loworbitSI is offline   Reply With Quote
Old 02-09-2010, 10:03 AM   #22
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Looking good...and I'm now reminded that I was supposed to send you guys my leftover 332 rotor rings and the spare set of hats
Scooby921 is offline   Reply With Quote
Old 02-09-2010, 11:22 AM   #23
skuttledude
Member#: 738
2008 Lexus IS-F
Ducati Monster 800
wish u guys well!
skuttledude is offline   Reply With Quote
Old 02-09-2010, 12:13 PM   #24
snoe19
Member#: 146045
2005 STi
Crystal Grey Metallic
Wrapping it in suede or alcantra fabric will be a huge headache if you are not skilled at automotive upholstery, ask me how I found that one out . Real genuine alcantara is very expensive and not really worth it for a race car IMO. I found the easiest, most cost effective way to do it is just by flocking the dash with fibers. I did this in my spec miata race car and had fantastic results. I am thinking about offering a service to do dashboards locally here in California because I have had so many people comment on how great/functional it is. Definitely do it if you have the dash out...
snoe19 is offline   Reply With Quote
Old 02-09-2010, 01:04 PM   #25
dunk
Member#: 15359
Where did you get those hood vents? Were you running a TMIC last year?
-Duncan
dunk is offline   Reply With Quote
My 2010 Race Car Build - From the Ground Up boost junkie Motorsports 2613 Today 09:25 AM
Make your car better thanks to Turn In Concepts Turn in Concepts MWSOC Vendor Classifieds 22 10-21-2007 09:00 AM
Turn In Concepts makes your car handle better Turn in Concepts Suspension/Brakes/Handling 20 10-04-2007 09:38 AM
Turn in concepts STI shifter kit, ssk, bushings etc. NEW IN BOX FREE SHIPPING happy187 Drivetrain 10 04-19-2007 01:32 AM
Some Whiteline bars in stock at Turn In Concepts Turn in Concepts Suspension/Brakes/Handling 5 10-24-2005 10:24 AM
