Welcome to the North American Subaru Impreza Owners Club Saturday February 13, 2016
Old 02-15-2010, 01:45 AM   #276
wantsti
Member#: 134764
04 sti
java black pearl
How would wrx koni's with rce yellows compare or rank to some of the set ups you drove?
wantsti is offline   Reply With Quote
Old 02-15-2010, 01:45 AM   #277
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
what spring rates? what damper settings? Testing on the street and testing on the track is apples and orangutans. comparing 4k springs to 10k springs is even worse. give me a break
rjrutzky is offline   Reply With Quote
Old 02-15-2010, 01:50 AM   #278
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The Koni dampers are very good. The Yellows are fairly good as well. They're just a skosh lower than I fancy, as you can definitely start to feel that you're slamming into the limit of travel on some of the rougher stuff. The rates are *slightly* higher than is really necessary for street tires. For that reason, I think the Blacks (marginally softer, marginally higher) is a better spring for most people. Still good with the Konis.
Old 02-15-2010, 01:52 AM   #279
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Originally Posted by rjrutzky View Post
Why does Phil from Element do so well on crappy BCs?
Have you seen him drive? He would be fast on anything.
I would also guess that he got the BC's either cheap or free. The $2K+ coilover places don't have as much to prove.
Butt Dyno is offline   Reply With Quote
Old 02-15-2010, 01:53 AM   #280
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
With 10k, they'd be even worse on the street. 10k is honestly stupid on the street. There's no streetable tire on earth that needs 10k rates. You should ALWAYS pick your spring rates based on what your tires need, not what you fancy.
Old 02-15-2010, 01:56 AM   #281
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Bingo. You can make mistakes in your setup and still be fast. Hell, you can be fast enough to win at the level of competition we're talking about and being doing *most* things wrong in terms of setup. It's not until you're at LMP/F1/WRC level that you not only have to be a fast driver, you also have to not have made any mistakes in your setup, engineering, strategy, etc.
You can put fast drivers like Tony W (or Phil, from what people say but I don't know him personally) in a damned Ford Pinto and they'll go out there and win.
Old 02-15-2010, 02:14 AM   #282
joltdudeuc
Member#: 6119
1999 GM6
RBP
Originally Posted by Turn in Concepts View Post
I have droop similar to your your car Tony
But that road is not smooth!
I'm on Koni 8610s and Swift springs +helpers on ground controls
joltdudeuc is offline   Reply With Quote
Old 02-15-2010, 02:17 AM   #283
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
It's my car/video. Actually, not even my grandma thinks that road is rough.
Old 02-15-2010, 02:26 AM   #284
joltdudeuc
Member#: 6119
1999 GM6
RBP
It mat not be rough, but it sure isn't smooth. I mean, it rolls, has dips, small potholes, etc. you went over a small curb or something at the end there, and had as much droop happen as in 2 or 3 parts of that road.
I was watching several cars on the hwy here the other day thinking about this thread, and noticed their wheels hardly move at all. and our roads aren't the smoothest.
Old 02-15-2010, 02:27 AM   #285
joltdudeuc
Member#: 6119
1999 GM6
RBP
is that your wagon? What's the spring/shock setup?
Old 02-15-2010, 02:40 AM   #286
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Ah, somewhere in this thread, I list exactly what's going on where. That last bit right at the end is me driving slowly into a gas station.
D-Specs and STi springs.
Old 02-15-2010, 05:58 AM   #287
STi-MAN
Member#: 70252
05 STI
blue
I'm sorry there are streetable tires on earth that will benefit from having 10 k springs, depending on the rest of their setup. Example if it was soley based on a tire why run differnt spring rates front to back. There are many other factors that I know u are experienced to know, which come into play when choosing spring rates.
Btw I'm talking about a streetable tire that is on more track focused car.
STi-MAN is offline   Reply With Quote
Old 02-15-2010, 10:07 AM   #288
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
10k springs on the street are pointless, but for a car on the track with street tires they aren't too high at all as long as you have the valving to support them. It's pretty amazing how compliant a car can be with great dampers, even on high spring rates. Especially once you throw a cage into the equation.
boost junkie is offline   Reply With Quote
Old 02-15-2010, 10:32 AM   #289
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
When do I drive my car on the street? Almost never. You stick to tuning for your neighborhood toe ghey, and I'll stick to the track
Old 02-15-2010, 05:17 PM   #290
Daishi00
Member#: 78952
2005 WRX
CGM
Please do. Because you keep arguing that what's good for the track is good for the street.
Daishi00 is offline   Reply With Quote
Old 02-15-2010, 05:57 PM   #291
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
go ahead and quote where i said that
Old 02-15-2010, 06:18 PM   #292
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
The whole spring rate vs tire type isn't quite as cut an dry as one thinks. Yes, for a road course, ideally you choose spring rate and roll bar size depending on the level of lateral grip your tires provide and the balance you seek. However, for example, in autox some of those rules get tossed out the window. Mainly due to the type of driving that particular motorsport requires (i.e. violent transitions when compared to the more smooth steady state stuff on a road course). Folks racing on a road course have to incorporate tire performance longevity into the equation and higher spring rates put a larger load and more heat on tires, reducing their grip levels sooner. On shorter autox courses, tires going off after an hour on course is not as much a concern. So they tend to run much higher spring rates (to control the car in the transitions) than one would normally choose on the tires they would run.
Our problem is emulating what the "racers" are doing and attempting to apply that to our street driven cars. Its, once again, an amazing testament to the power of marketing when we see who the fast guys are, and want to run what they run...on the street! Because, um, its a faster setup...for going on the togue run to starbucks.
In the end, ideally we should pick the right tool for the job. But its rarely that simple when we incorporate our egos and fantasies.
Arnie is offline   Reply With Quote
Old 02-15-2010, 06:32 PM   #293
Daishi00
Member#: 78952
2005 WRX
CGM
You keep making references to your track setup and others track setups in a discussion which has for the most part tried to stay centered around street applications.
Old 02-15-2010, 07:36 PM   #294
antonch
Member#: 170384
2006 Sti
Discomfort does not necessarily have to come with high spring rates.
I've been able to tune my BC's w/ 12/10k spring to as comfortable as stock.
antonch is offline   Reply With Quote
Old 02-15-2010, 07:38 PM   #295
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Dude, riding a stage coach is as comfortable as a stock STi
Old 02-15-2010, 08:01 PM   #296
antonch
Member#: 170384
2006 Sti
Lol, not quite.
Old 02-15-2010, 08:50 PM   #297
Daishi00
Member#: 78952
2005 WRX
CGM
Pretty damn close. Stock dampers are not matched to a correct spring. Bobblehead FTL
Old 02-15-2010, 08:54 PM   #298
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
Good post Arnie, and I agree. But you didn't insult anyone in your post, maybe you forgot to throw a jab in or two?
Seriously, thanks for keeping it civil and productive. It gets out of control in here way too much.
- drew
AndyRoo is offline   Reply With Quote
Old 02-15-2010, 09:41 PM   #299
antonch
Member#: 170384
2006 Sti
Wrong. Bobblehead is a result of the seats.
Old 02-15-2010, 10:29 PM   #300
Daishi00
Member#: 78952
2005 WRX
CGM
No, seats are a part of the issue, but not it entirely
GC Kit and droop jeisen Brakes, Steering & Suspension 7 02-15-2010 09:18 AM
back to stock sale coilovers and other parts cheap mrguppy MAIC Private Classifieds 14 10-13-2008 03:46 PM
Springing options for coilovers - attacking stroke and droop travel Scooby921 Brakes, Steering & Suspension 7 05-10-2007 12:41 PM
FS: Brand New Coilovers and Shocks Cheap! wildchild Private 'For Sale' Classifieds 2 08-01-2004 08:46 PM
Cheap coilover kits on eBay B-Kerr Brakes, Steering & Suspension 11 05-31-2003 01:40 AM
