Old 02-15-2010, 09:15 PM   #1
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Default Will a machine shop need my case bolts to bore/hone?
I bought a 207 SB from someone and he kept all but one case bolt for whatever reason. I'm going to reuse the ones in my current motor, but that is in the car right now (under 4ft of snow) and I want to get this show on the damn road since spring is approaching.
If I bring the machine shop my new pistons and the case halves, can they bore and hone them?
CKxx is offline   Reply With Quote
Old 02-15-2010, 09:28 PM   #2
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
It depends on the fixture setup the shop has some shops need to have the cases bolted together some don't,you will have to call the shop you use and ask them.If you need to buy case bolts,the whole set is like $50 from the dealer.
john 1badSTI is offline   Reply With Quote
Old 02-15-2010, 09:29 PM   #3
CKxx
Member#: 33458
93 RX7+09 Forester
Thank you.
I never realized the bolts were that cheap. I saw the price of the ARP set and cringed, so I figured I re-use the old ones.
Old 02-15-2010, 09:43 PM   #4
john 1badSTI
Member#: 77470
yeah I agree the ARP case bolt set is a real shocker.Ron at raw uses stock bolts unless the customer states he wants arp's.And on top of the arp's when you use them the cases have to be align honed after the stronger bolts are used to amke sure everything is still true which is another expense on top of the case bolts.
Old 02-15-2010, 10:17 PM   #5
RallyColtTurbo
Member#: 16819
Ideally, you want the case bolted together and torqued, AND have torque plates installed in place of both heads for all machining operations. This theoretically puts the block in the "as stressed" position for all the machine work.
That being said...Just do as much as your shop is capable of doing unless your looking for record breaking HP numbers.
RallyColtTurbo is offline   Reply With Quote
Need my car back to STOCK - Anyone willing to help??? Rick Dizzle Mid West Subaru Owners Club Forum -- MWSOC 13 01-31-2008 09:12 PM
Need my car back to STOCK - Anyone willing to help??? Rick Dizzle General Community 8 01-30-2008 04:48 PM
Machine shop needed for wheel offset correction. Evil STI Tri-State Area Forum 6 01-14-2008 01:47 PM
NOVA machine shop, or anyone have access to a press? psyber_0ptix Mid Atlantic Impreza Club -- MAIC 7 07-16-2005 02:10 AM
Will an Aftermarket WRX Up or downpipe bolt to EJ22 turbo? outback2.5HO Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-18-2002 10:25 PM
