Old 06-11-2003, 01:12 PM   #1
PeterJ
Member#: 14727
2002 impreza RS
Default Small tranny leak at shifter linkage
I have noticed an oil stain on the left side of the transmission case, around where the shifter linkage enters... Does anyone else have this?
PeterJ is offline   Reply With Quote
Old 02-15-2010, 11:33 PM   #2
WpgUberu
Member#: 163619
I have this issue too, I'm doing a clutch kit install and there's a bit of fluid leaking.
WpgUberu is offline   Reply With Quote
Old 02-16-2010, 12:44 AM   #3
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
I've actually seen this in almost every 5MT I've worked on. It's pretty common, but varies in severity.
It's a pain in the butt to fix though. You need to completely remove the linkage and the attachment point on the gear selector shaft. Then you need to pull the driveshaft, pull the crossmember, lean the box back and remove the tailstock portion with the center diff. once removed, the seal can be removed and replaced fairly easily.
kpluiten is online now   Reply With Quote
Old 04-29-2010, 12:03 AM   #4
shogunmy04
Member#: 61484
2004 wrx sedan
wrb
would you happen to have the service manual on that? i have this issue too
shogunmy04 is offline   Reply With Quote
Old 04-29-2010, 01:01 AM   #5
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Count me in as well. Pretty significant amount of oil sloshes out of there and has since about 20k miles.
Old 04-29-2010, 12:17 PM   #6
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
basically same procedure to remove the center diff. Its a tedious process, but very doable with simple hand tools
scoobdude is offline   Reply With Quote
Old 04-30-2010, 12:24 AM   #7
shogunmy04
Member#: 61484
2004 wrx sedan
wrb
thanks
Old 06-03-2010, 11:38 PM   #8
azscooby
Member#: 115297
2002 ej207 vf34
Can someone point me in the right direction on the FSM for this?
I've got the tranny out and I need to what's involved in getting the new seal in there.
It looks like you've got to undo the "tail cap" and take off the linkage pieces, but I can't figure out how to remove the linkage piece.
thanks.
azscooby is offline   Reply With Quote
Old 06-04-2010, 11:59 AM   #9
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
can you post a pic of where you are on the replacement. Will help a bunch
Old 06-04-2010, 09:41 PM   #10
azscooby
Member#: 115297
2002 ej207 vf34
[IMG] Uploaded with ImageShack.us[/IMG]
This is where I'm at.
Do I have to take the "tail-cap" off the center diff?
I punched out the roll pin that holds the linkage in, but can't get anything else to budge.
How do I get that last piece of linkage off?
Old 06-04-2010, 09:42 PM   #11
azscooby
Member#: 115297
2002 ej207 vf34
Can you see that almost silver colored piece that goes vertically through the linkage?
That's the piece I can't get to move.
Does it punch through like the roll-pin?
Old 06-04-2010, 11:48 PM   #12
kpluiten
Member#: 120273
06 WRBWRXWGN
Dude, give me a call. I'll PM you my number.
It is actually one roll pin inside another. You need to punch out the inside roll pin and then the outer. They can be it there very tight at time. A proper sized punch helps a lot.
Old 06-05-2010, 12:01 AM   #13
king03
Member#: 248067
+1 had the same probalem and got it fixed
king03 is offline   Reply With Quote
Old 06-05-2010, 01:22 AM   #14
WRxplayer
Member#: 231774
Check the shifter linkage seal it is a small on and can leak like the fifth gear seal.
WRxplayer is offline   Reply With Quote
Old 10-23-2010, 05:23 PM   #15
weasel
Member#: 20794
2002 WRX Sedan
WR Blue Perl
It appears that I have this leak as well. Have a bit of a cash flow crunch right now though - how important is it to get this quickly fixed (versus waiting a while), as long as I make sure the transmission fluid stays at an appropriate level?
weasel is online now   Reply With Quote
Old 10-24-2010, 01:03 PM   #16
burtonboy759
Member#: 178707
2002 BUGEYE HYBRID
MBP- NO ITS NOT BLUE
I have the same leak on mine right now too. Not looking forward to fixing this but its a must, just keeping an eye on my fluid level for now. Been driving for about 4k miles now on new fluid and doesnt seem to be a huge problem... yet. How much u think a shop would charge for this fix, it seems awfully labor intensive.
burtonboy759 is offline   Reply With Quote
Old 10-27-2010, 07:39 PM   #17
ragejed
Member#: 76817
2005 WRX
Can we get a part number on this ASAP? I searched all over. I am replacing transfer case bearings this weekend and need to replace this as well.
ragejed is offline   Reply With Quote
Old 03-30-2011, 07:42 PM   #18
Darren Alaniz
Member#: 176725
2003 WRX
did anyone ever get a part number for the gasket?
Darren Alaniz is offline   Reply With Quote
Old 11-16-2012, 07:38 PM   #19
zman519
Member#: 118086
2003 WRX
I guess not, i'm also looking for it
zman519 is offline   Reply With Quote
FS: (NY) oem tranny mount and shifter linkage mikecsti Drivetrain 5 05-18-2010 11:35 AM
Tranny leaking at axle recruitX Transmission (AT/MT) & Driveline 8 09-17-2007 11:35 AM
Q: Is there a seal where the shifter linkage enters the tranny case? mpaone Transmission (AT/MT) & Driveline 2 01-15-2007 07:45 PM
Shifter linkage tranny leak ryguy Transmission (AT/MT) & Driveline 4 07-19-2006 09:17 AM
RS shifter linkage on a FWD tranny? ^jynx^ Transmission (AT/MT) & Driveline 2 09-14-2003 07:05 AM
Message Board Statistics All times are GMT -4. The time now is 04:29 PM.
