Old 02-16-2010, 09:19 AM   #1
aboogabooga
Member#: 181127
1999 Civic
Rust
Default 6 speed swap into 08 WRX help.
What other than the tranny and drive-shaft do I need? Axles? Comin from a 05 STI.
Thanks.
aboogabooga is offline   Reply With Quote
Old 02-16-2010, 07:11 PM   #2
aboogabooga
Member#: 181127
1999 Civic
Rust
Bump! Need help asap!
Old 02-17-2010, 06:33 AM   #3
aboogabooga
Member#: 181127
1999 Civic
Rust
ttmft
Old 02-17-2010, 07:33 AM   #4
carlitos_s203
Member#: 233254
Chapter/Region: PRSIC
2005 Impreza WRX STI
WR blue
carlitos_s203 is offline   Reply With Quote
Old 02-17-2010, 10:15 AM   #5
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
I DO NOT KNOW FOR SURE, BUT IF I HAD TO GUESS I WOULD SAY:
Transmission (you said 2005 STI?)
Rear Diff (you need a 3.90 final drive for the 2005 box, but your car should already have this )
Driveshaft (see if an auto DS will work for you)
STi Shift linkage (I think the 2008+ chassis requires longer linkage I heard?)
"Pull style" slave cylinder
"Pull style" clutch kit for STi
STi Clutch fork
Other than that, your axles should be just fine.
But as I said, I'm only speculating. Make sure when you complete the swap you post up what was required so we can all learn!
Old 02-17-2010, 10:30 AM   #6
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
I think the swap is not going to work. You are going to run into issues with the speed sensor.
If I'm right you need a different front bell housing for your speed sensor.
CoolRex is offline   Reply With Quote
Old 02-17-2010, 10:40 AM   #7
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
Something interesting just popped into my mind. OP do you want to swap to 5x114 during this ordeal?
Anyway, for those who do not know, on the GH/GE/GR, all 4 corners are hub unit bearings like the front was on the 05+ STI where the bearing and hub and a 'knuckle snout' is sold to you as one item and it just bolts onto the knuckle....no pressing bearings etc. What I'm wondering is if the GE/GH knuckles are identical to the GR knuckles such that all you'd have to do is buy 2 GR front hub unit bearings and 2 GR rear hub unit bearings and they'll just bolt onto your stock knuckles. Then you'd need to do the brakes of course (might need a bracket), but this will eliminate the need for new knuckles and popping 6 ball joints apart.
Just a thought.
09rexwagon is offline   Reply With Quote
Old 02-17-2010, 12:35 PM   #8
kpluiten
Member#: 120273
06 WRBWRXWGN
I don't know about this. His speed sensor comes from the ABS right? I'm relatively certain the 08+ cars do not have a VSS in the trans. So he should be able to just leave the 05 STi VSS in the trans to plug the hole and the car will run normally. This is the case with the 08+ sti's at least... where do the 08+ WRX 5MT's get their speed readings, that's the question. If it's from somewhere not involving the transmission, he's good to go then.
Old 02-17-2010, 12:52 PM   #9
09rexwagon
Member#: 216135
2011 Civic SI
You got it, there is no VSS in the tranny on the 08+ 5MT. There is a big plug in that hole that does nothing now .
Old 02-17-2010, 12:54 PM   #10
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Cool. I was going from the Legacy Spec B tranny swap into a 04 and they had to swap the housings. So if it's the other way around just cap hole and move on. Sweet! So ignore my statement!
Old 02-17-2010, 02:21 PM   #11
aboogabooga
Member#: 181127
1999 Civic
Rust
Yep...got everything but the clutch. Axles went in fine.
Old 02-17-2010, 02:30 PM   #12
kpluiten
Member#: 120273
06 WRBWRXWGN
Enjoy the 6MT dude! My 6MT is still one of my favorite mods on my car... and I have a lot of mods at this point.
Old 02-18-2010, 11:17 AM   #13
Sk8er
Member#: 129045
2004 Subaru WRX Sti
Wow dude i hope it works but for the money you paid for your wrx i would have saved up and got an new sti....no swaps needed there.
Sk8er is offline   Reply With Quote
Old 02-18-2010, 12:12 PM   #14
kpluiten
Member#: 120273
06 WRBWRXWGN
Wow! You're the first guy with an STi to ever say that!
Remember, with many of us, the thrill is not in what you can buy, but rather in the build process. Customizing these cars to be unique to your style and needs is what it's all about. He wanted a 6MT in his WRX... so what?
Old 02-18-2010, 12:21 PM   #15
iht
Member#: 196742
2000 Impreza 2.5rs
Unless you have a car that never had an STi version that hit these shores
iht is offline   Reply With Quote
Old 02-18-2010, 05:11 PM   #16
aboogabooga
Member#: 181127
1999 Civic
Rust
Heh...lets say I had all the fun I want in the snow. Other than that this car is my daily...daily beaten.
I know, it's a waste of money, but I couldn't afford the monthly payments and insurance.
Old 02-18-2010, 05:33 PM   #17
DCCDPro
Member#: 227549
I agree, the 6mt is one of the most underrated mods.
It makes the car so much nicer to drive as a daily driver.
DCCDPro is offline   Reply With Quote
Old 02-19-2010, 10:06 PM   #18
aboogabooga
Member#: 181127
1999 Civic
Rust
K, I need help...STI Drive shaft is to short and the stock is to long. FML!
Old 02-20-2010, 06:53 AM   #19
DCCDPro
Member#: 227549
Get a local machine shop to shorten it. (Lengthening is usually more difficult but it is possible.)
There are usually places that do custom work for example for the musclecar crowd but you may have to do a bit of digging in the yellowpages or make a few phonecalls.
Old 02-21-2010, 08:11 AM   #20
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
I have found a few drive shaft shops wont touch the subaru part due to the universal joints being non replacable. however, at some point Im sure it would be worth upgrading to a larger u joint and going completely custom. Just my .02..
Dubstar112 is offline   Reply With Quote
Old 02-15-2013, 02:26 AM   #21
Blue12WRXhatch
Member#: 324995
WR Blue
I've been wanting to do this on my 2012 wrx, I don't trust the duel trans case the wrx's have because you can still shred the synchros, so I want to do a sti swap. what's all the stuff I need exactly, and which year sti trans would you guys recommend? I was thinking the 07, my car is going to end up as a track only car once it's done
Blue12WRXhatch is offline   Reply With Quote
Old 02-15-2013, 08:17 AM   #22
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Try this thread (on the first page) instead of bumping one that's 3 years old:
http://forums.nasioc.com/forums/show....php?t=2466977
6 speed swap into 09 WRX Darkmatter1986 Transmission (AT/MT) & Driveline 20 02-06-2013 03:51 PM
little trouble with 6 speed swap into 04 wrx tylerrusso Transmission (AT/MT) & Driveline 7 06-05-2009 08:18 PM
04 6 speed swap into 02 Wrx with Sti swap drftwell Transmission (AT/MT) & Driveline 28 09-10-2008 09:22 PM
I'm doing a 6 speed swap into my wrx and I need some advice! snowcrzy Transmission (AT/MT) & Driveline 1 10-16-2006 01:54 PM
STI engine 6 speed swap into WRX? please help Rustyr6 Transmission (AT/MT) & Driveline 2 06-15-2005 05:24 PM
