#1 |
Member#: 115240
SCIC
Vehicle:2006 WRX Wagon Aspen White |
So I got my first check engine light since i've owned my 06 WRX Wagon. Cruise light flashing.
My friend's ScanGauge read only one OBD II Code: P2444 - the Secondary Air Pump 1 Stuck On B1 We cleared the code just for kicks to see if it would appear again. It did immediately. From what I've read from other posts (which I don't remember right now), the Secondary Air Pump is merely an emissions part that functions for only 90 seconds at startup. "The turbocharged and intercooled WRX engine nudges from 227 to 230 horsepower, and torque climbs dramatically from 217 lb-ft to 235 lb-ft. This was accomplished by increased displacement, increased compression ratio, redesigned combustion chambers, redesigned intake manifold and deleted pre-catalyst (replaced in function by a secondary air pump). The increase in compression ratio and the combustion-chamber redesign also contribute to improved emissions, with the turbo engine meeting Low Emissions Vehicle II (LEV II) regulations." See SOURCE. I've also read that it is not a critical component and has been removed with block plates installed without any severe repercussions (aside from codes reappearing). Which is somewhat a relief, in that the part is $600+ (If this is the secondary air pump, there is a main air pump, I don't know which one this is, See price HERE). Even then, I want to get some peace of mind and get to the bottom of this, rather than discount it as trivial. Picture's not that great, but here is the location of secondary air pump (F127), and relay (F129): ![]() That being said, what's your experience/theories on this if any. Some things that have been going through my mind:
If I do have to take the air pump out, doesn't seem that difficult, it may be similar to STI, see HERE. Thanks, Al
#2 |
Member#: 132244
NWIC
Vehicle:2006 OBP WRX 2006 BMW 325i |
I cant see it being a blown fuse since that would eliminate the power going to the relay. It could very well be a relay that is stuck closed. Is there a fuse that controls the air pump? If so, you could alway pull the fuse, clear the code and see if the CEL comes back. As far as the block off plates go, I noticed that your in Cali, is this code something that a tuner can turn off?
#3 |
Member#: 115240
SCIC
I'm with you on the blown fuse. Couldn't hurt to check it anyway, if there is a fuse to it. I don't know if there is.
The brown clouds (which aren't as brown nowadays) in LA might indicate that the block-off plates are not kosher in California. But i wasn't planning to go that way...I want to keep it the way it was designed... |
#4 |
Member#: 132244
NWIC
I would just swap relays with someone for troubleshooting.
#5 |
Member#: 109259
Vehicle:2004 WRX |
Not much info on my computer but I have this if it helps any. seems like the relay is the place to start.
P2444 Secondary AIR System Pump Stuck On Possible Causes * Check the operation of the secondary AIR pump relay * Check the secondary AIR pump relay for a short to ground condition * AIR combination valve has failed * PCM has failed Setting Conditions Engine running; Secondary AIR system active, and the PCM detected a problem in the operation of the Secondary AIR Pump (it may be stuck "on"). This code sets in 1 Trip(s). This code will turn on the MIL (Malfunction Indicator Lamp) |
#6 |
Member#: 197418
NESIC
Vehicle:07 WRX Ltd The Mighty Evo |
heres another picture of the valves.
number 12 and 13. ![]() 12 & 13 are both on the driver side except 13 is under the intake manifold and harder to change. pull the rubber hose out and stick your finger inside the valve hole to check for water. if theres water in there then theres your failed valve. you can change it or just get cobb access tuner race to disable the codes. its only there for emissions. it wont affect drivability. With the cel on, you're probably on limp mode. Also stick a rag inside the hole to absorb the water out if you decide to just delete the cel. these valves mostly likely failed because water gets inside the valve, causing it to rust and get stuck. One of the valve sits under the intake manifold ,and its right under the hood vent. When it rains or when you wash your car, the water goes down the hood vent. I think this is how the water gets in through condensation.Just speculating. ![]() see those holes on the 2 valves after you remove the black y-hose coming from the air pump? Test for water by sticking your finger or a rag deep inside the hole. ![]() Last edited by Ysidro; 01-29-2010 at 03:29 PM. |
#7 |
Member#: 103068
SCIC
Vehicle:11 STI sedan SWP |
How many miles are on your car? Is it stock? Since we are in CA, we have a special emissions warranty. Take it back to the dealer, they have to fix it for free since the car will fail a smog check.
#8 |
Member#: 115240
SCIC
I have close to 70K miles on it. How long does the special emissions warranty go for?
#9 |
Member#: 103068
SCIC
80k iirc. It's in the owners manual package.
#10 |
Member#: 115240
SCIC
You're right! Service person at the dealer said I may be covered. Do you think I should remove my K&N filter element (it's the one that fits in place of the plain one, not CAI) and Paranoid Fab. Grounding wires before I take it in?
#11 |
Member#: 102871
SWIC
Vehicle:2006 wrx Black |
i took my car to the dealership and they said it wasn't cover. My car has 64k miles and its bone stock. I need to find a way to fix this without dishing out $1300 that the dealer wants so i can sell my car.
#12 |
Member#: 103068
SCIC
Why did they say it wasn't covered? The car can't pass an emissions check with a MIL. I would contact SOA.
#13 |
Member#: 102871
SWIC
#14 |
Member#: 103068
SCIC
Call SOA. Get the dealer response in writing.
#15 | |
Member#: 102871
SWIC
here's the response from SOA
#16 |
Member#: 103068
SCIC
Straight wrong. Even the turbo is covered under the warranty for up to 80k (might be 70k, don't remember. I don't have access to my book right now, look in your warranty book and find the list of covered components. There are some covered to 50k, then some to 80k or something like that.
#17 |
Member#: 146763
Vehicle:2009 wrx 300/331 blk |
u need to replace the recirc valves they get corroded and stick open replace both of them youll be all set
#18 |
Member#: 103068
SCIC
#19 |
Member#: 197418
NESIC
yep, time to get your hands dirty.
The only pita part in this is having to remove the intake manifold to get to one of the valves.Other than that, its a really easy swap job. even if the dealer covers it under warranty, it will break down again. Mine did. When it does, your warranty may run out and you're smack with a $1300 bill to replace it. Best thing to do is to disabled the code or start learning how to remove the intake manifold yourself, and do your own labor. It may not be a bad thing to remove the manifold. Atleast you can clean out the carbon that has accumulated inside and give it a nice fresh coat of paint. ![]() |
#20 |
Member#: 103068
SCIC
Id take the grounding leads off.
#21 |
Member#: 230161
Vehicle:2007 WRX Wagon Silver |
I have a 2007 WRX which I bought used with 30k (now ~34k) that began throwing the CEL with code P2444 3 weeks ago. Even thought it was not covered under the extended warranty I bought, I dutifully took it into the local dealership for evaluation. Similar to others' stories, they wanted over $1600 to replace the air pump and both valves. The service advisor claimed there was no way to more specifically diagnose the fault, and all 3 components needed to be replaced.
I called Subaru America, who were *very* interested in this situation. I had a call from the dealership's Service Manager the same day, asking if I would give them another chance to look at the car. In the end, they discovered the pump was fine, and that both valves were filled with water. They replaced both valves for $250 with a notation on the invoice "goodwill warranty." My guess is that Subaru know they have a problem, and are willing to address the issue if you complain enough. |
#22 |
Member#: 103068
SCIC
Filled with water? I've got 105k on my 06 now and haven't had a single problem with the emissions system yet. How do those valves fill with water? Don't they have air rushing through them which would clear them? Do you wash your engine often?
#23 |
Member#: 54826
SCIC
Vehicle:2006 WFC #420 SGM, Church tuned |
Okay I had the same issue last night. Except, in addition to the pump being stuck on, the plastic tube on my was melted. I have no clue what would cause it to heat up like that since nothing in its environment would cause it except for the unit itself. Any suggestions? Here's a picture of where it was melted.
#24 |
Member#: 230161
The technician thinks it's very climate-dependent: he sees this when the real humdity sets in here in NC. Searching some other sites yields similar findings of moisture accumulating in the valves. I suspect SoCal is a far friendlier climate. If it happens again I'll probably just pull all the plumbing and have the CEL cancelled.
#25 |
Member#: 94408
E. Canada
Vehicle:2006 WRX Stg. 2+ World Rally Blue |
06 wrx here and i had the same problem last year. The pump, and both valves all had to be replaced. I got the P2444 code, and eventually the "valve stuck open" code which i can't remember. Luckily, it was replaced under warranty for me.
The next time it will fail, and i'm sure it will, i'll just get the block-off plates and have those codes supressed by my tuner... i doubt i'll be so luckly for another free replacement. If you can't get it covered and want to save money, i sugges the block-off plates too. Also if you're worried about emissions, its true, that whole system is just for cold-start emissions so testing shouldn't be a problem. |
| Thread Tools | |
| Display Modes | |
| Plugging Secondary Air Pump | BlueSubeDude | Factory 2.5L Turbo Powertrain | 14 | 12-26-2012 04:46 AM |
| CEL p2444 secondary air pump?? | tcr04 | Factory 2.5L Turbo Powertrain | 2 | 02-07-2010 04:14 PM |
| WTB: Secondary air pump baro sensor 07 WRX | ronzogonzo | Private 'Wanted' Classifieds | 0 | 11-25-2009 05:37 PM |
| Secondary Air Pump Solutions? | JonJ | Service & Maintenance | 7 | 09-29-2009 10:13 AM |
