#26 |
Member#: 56297
Vehicle:2004 STi HTA Green 28psi, MSPT Tuned |
#27 |
Member#: 57287
Vehicle:2002 Bugeye STi MY03 Fozzy XS |
Which part, that the primaries are larger and it's aimed at being more focused towards the 2.5L or that they are a copy of Tomei Expreme TS Headers?
#28 |
Member#: 103232
Vehicle:MY05 GDA, MY04 FXTI 2.5ltr,PPG,Front LSD,4.44 |
Nice Mike! Now it just needs to have a custom 10cm turbine housing.
![]() No really though Im sure its great the way it currently is, and a great platform to built on. |
#29 |
Member#: 110783
Vehicle:2010 WRX Satin White Pearl |
#30 |
Member#: 129969
W. Canada
Vehicle:2005 Sti Silver/Black |
bump for update
#31 |
Member#: 143149
Vehicle:2006 Evo IX RS used to be 07 wrx 6speed |
#32 |
Member#: 110783
#33 |
Member#: 95840
Vehicle:sold to a good bud awaiting next car |
marketing? you be the judge:
http://www.turbobygarrett.com/turbob...1.html?#t101_5 Journal Bearings vs. Ball Bearings The journal bearing has long been the brawn of the turbocharger, however a ball-bearing cartridge is now an affordable technology advancement that provides significant performance improvements to the turbocharger. Ball bearing innovation began as a result of work with the Garrett Motorsports group for several racing series where it received the term the ‘cartridge ball bearing’. The cartridge is a single sleeve system that contains a set of angular contact ball bearings on either end, whereas the traditional bearing system contains a set of journal bearings and a thrust bearing Journal Bearings ![]() Ball Bearings Turbo Response – When driving a vehicle with the cartridge ball bearing turbocharger, you will find exceptionally crisp and strong throttle response. Garrett Ball Bearing turbochargers spool up 15% faster than traditional journal bearings. This produces an improved response that can be converted to quicker 0-60 mph speed. In fact, some professional drivers of Garrett ball-bearing turbocharged engines report that they feel like they are driving a big, normally aspirated engine. Tests run on CART turbos have shown that ball-bearings have up to half of the power consumption of traditional bearings. The result is faster time to boost which translates into better drivability and acceleration. On-engine performance is also better in the steady-state for the Garrett Cartridge Ball Bearing ![]() Reduced Oil Flow – The ball bearing design reduces the required amount of oil required to provide adequate lubrication. This lower oil volume reduces the chance for seal leakage. Also, the ball bearing is more tolerant of marginal lube conditions, and diminishes the possibility of turbocharger failure on engine shut down. Improved Rotordynamics and Durability – The ball bearing cartridge gives better damping and control over shaft motion, allowing enhanced reliability for both everyday and extreme driving conditions. In addition, the opposed angular contact bearing cartridge eliminates the need for the thrust bearing commonly a weak link in the turbo bearing system. Competitor Ball Bearing Options – Another option one will find is a hybrid ball bearing. This consists of replacing only the compressor side journal bearing with a single angular contact ball bearing. Since the single bearing can only take thrust in one direction, a thrust bearing is still necessary and drag in the turbine side journal bearing is unchanged. With the Garrett ball bearing cartridge the rotor-group is entirely supported by the ball bearings, maximizing efficiency, performance, and durability. Ball Bearings in Original Equipment – Pumping up the MAZDASPEED Protegé’s heart rate is a Garrett T25 turbocharger system. With Garrett technology on board, the vehicle gains increased acceleration without sacrificing overall efficiency and it has received many rave reviews from the world’s top automotive press for it’s unprecedented performance. Download Turbo Tech 101 |
#34 |
Member#: 110783
#35 |
Member#: 95840
#36 |
Member#: 22605
Vehicle:2002 JDM STI/WRX WRB |
Nice! I'm in for twin scroll developments. How would this compare to a VF37 converted to a PE1825?
#37 |
Member#: 26568
Vehicle:2003 Yellow Bugeye Version 8-Vf37 |
keyan mentioned it but people seem to be posting uppipe and header and are forgetting that you also need the twinscroll flange on the downpipe which gets expensive.
you either have one made by hayward and scott, militek or roger clark motorsports and shipped from the UK or have a flange welded on here in the states which in the end isn't much cheaper. 80 dollar flange 250 dollar downpipe 200 dollar labor (at least, i've been quoted 3hrs and more) that turns out to be an expensive downpipe ![]() i've seen pics of the UK pipes and the only one i would consider is the RCM unit. I don't like the welding I've seen on the other two pipes i mentioned. |
#38 | |
Member#: 79791
Vehicle:2007 STI |
#39 |
Member#: 57287
Well we might also have companies like Blouch to start offering TS Downpipes...people are going to need them. Also as Scoobystas said: when I had my flange done on my Megan Downpipe it cost $200 in Labor... a cheap downpipe becomes something that is kinda expensive. When you end up doing a JDM swap that is Twin Scroll, small little things add up quick to make it work...but it's completely worth it! ^_^
#40 |
Member#: 140444
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
I'm hoping someone makes a TS exhaust housing that mates with OEM TS up-pipes and USDM single-scroll down-pipes.
For the size of turbo I'm looking for (3076 or bigger) the OEM JDM exhaust housings are going to be too small to be useful, so it's going to take something custom - and if it's going to be custom it might as well mate up with all of the downpipes that the entire US market is using. The twin-scroll headers and up-pipes are going to be a big enough barrier to entry in the first place, it makes good business sense to let customers re-use the downpipes we have, and/or use readily available, proven, relatively inexpensive USDM-style downpipes. Pretty please? ![]() |
#41 |
Member#: 211628
Vehicle:2004 VF37 WRX MPS BUILT EJ22 |
ooooooo T/S turbo
#42 | |
Member#: 57287
#43 |
Member#: 140444
Oh... that would explain the difference in the flanges.
I guess I'll have to get a new downpipe. If someone would just hurry up and make a twin scroll exhaust housing that mates up to a GT30R center section... |
#44 |
Member#: 108163
Vehicle:2005 STI - 10.8@129 more in the works! |
http://www.atpturbo.com/mm5/merchant...egory_Code=GTH
Garret makes a few different styles for the 30R from a 1.06 a/r T4 twinscroll housing to the smaller a/r T3 twinscroll housings. |
#45 | |
Member#: 173553
International
Vehicle:2006 WRX CGM |
edited: And I should think before posting.... Any TS turbo will need a lot of other parts, so... You are right. Garrett is an option! Last edited by Ferraz; 02-24-2010 at 11:26 AM. |
#46 |
Member#: 140444
Yeah, I should have been a little more specific. Although, since going TS would require new headers, UP, and DP either way, rotated isn't that big of a deal. I guess at this point I'd be happy with anything that's been proven in a BL/BP Legacy GT. (I don't want to be a guinea pig for a brand new rotated kit.)
#47 |
Member#: 111008
Vehicle:2011 LGT SSM |
subscribed
#48 |
Member#: 216125
wow that looks beefy. do you have any HP and price est?
#49 |
Member#: 129969
W. Canada
bump for update
#50 |
Member#: 173241
TXIC
Vehicle:2002 s256 twinscroll now with one more gear |
sweet, i have been an advocate of twinscroll for around a year now, in my opinion is such a better design, and the 37 i have on my stock 2.0 makes daily driving so nice, this looks alot like the custom turbo i have drawn up except i used a TD06sl2 turbine wheel, which can fit nicely inside the stock turbine housing, and with a little work on a metal lathe so will the whole center housing from a MHI turbo, glad this is finaly being produced by someone
actually after going back over my notes, its the same exhaust wheel, and i believe the same compressor wheel, specs on the one i had are 56mm inducer/76mm exducer, Last edited by seanathanq83; 02-28-2010 at 11:21 PM. |
| Thread Tools | |
| Display Modes | |
| APS twin scroll rotated turbo kit TSR-70 who would buy it or not? | 949 | Factory 2.5L Turbo Powertrain | 237 | 02-07-2010 12:16 PM |
| my new gp moto twin scroll rotated turbo! | 06redsuby | Factory 2.5L Turbo Powertrain | 20 | 02-15-2008 12:30 AM |
| Twin Scroll BB Info needed . | discopotato03 | Factory 2.0L Turbo Powertrain | 2 | 05-10-2007 11:41 AM |
| New APS twin-scroll BB rotated turbo FOR USDM STI's!!! | keaniegenie | Factory 2.5L Turbo Powertrain | 191 | 01-10-2007 01:12 PM |
| Will the new STI use a twin-scroll IHI turbo? | bsix | STi Forum Archive | 0 | 01-09-2003 01:54 PM |
