Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Old 02-28-2010, 05:08 PM   #1
shikataganai
Member#: 92634
'07 LC, '12 RAV4 EV
'13 LEAF, for now
OMGHi2U Car weight and MPG over the years
I whipped together some data about automobile curb weight and MPG over the years, as I wanted to see for myself whether the perception that cars have become thirstier and larger is true. It turns out that the latter is most definitely true but not necessarily the former, at least for the hopefully-representative few models that I picked.
Data were sourced from Edmunds and Fueleconomy.gov. Charts are original content by this author, shikataganai, not stolen from some other site.
shikataganai is offline   Reply With Quote
Old 02-28-2010, 05:14 PM   #2
thestig2284
Member#: 200517
09 Subaru WRX
Interesting, but just imagine the fuel economy if the weights would go down.
thestig2284 is offline   Reply With Quote
Old 02-28-2010, 05:16 PM   #3
Kubek
Member#: 53222
'10 Genesis Coupe
'99 Miata
Was the mpg measured using the same test procedures and standards?
Kubek is online now   Reply With Quote
Old 02-28-2010, 05:19 PM   #4
shikataganai
Member#: 92634
'07 LC, '12 RAV4 EV
'13 LEAF, for now
Yep, all are reported under the revised 2008 EPA testing standards, data straight from the horse's mouth (EPA via fueleconomy.gov).
Old 02-28-2010, 05:29 PM   #5
Indocti Discant
Member#: 138000
L Bo Hope you meet
the spirit in the sky
im actually surprised at some of the weight data. I can tell you that the 2003 accord data looks to be shy by about 300lbs.
Indocti Discant is offline   Reply With Quote
Old 02-28-2010, 05:36 PM   #6
shikataganai
Member#: 92634
'07 LC, '12 RAV4 EV
'13 LEAF, for now
http://www.edmunds.com/used/2003/hon...093/specs.html
Old 02-28-2010, 05:52 PM   #7
gagliano
Member#: 39541
2002 WRX & 2004 STI
WR Blue
How does this correlate to anything? Engines are not the same over the years for a specific model, neither is the body style. When aerodynamics and engine efficiency are not constants how does this tell us anything? It would be interesting to see the numbers by swapping engines from the 90 and 08 Accords or the the same for any of the other models listed.
gagliano is offline   Reply With Quote
Old 02-28-2010, 06:08 PM   #8
shikataganai
Member#: 92634
'07 LC, '12 RAV4 EV
'13 LEAF, for now
Weight is a proxy for physical size and density of required and simply tacked-on extra equipment such as emissions controls, powered seats, airbags up the wazoo, strong A-pillars and the like. What my admittedly very rudimentary graphs show, and which surprised me, is that improvements in all the other factors (efficiency of the engine, more speeds on transmissions, better aerodynamics, etc.) basically have compensated for the increased girth in nominally equivalent models over the years.
Old 02-28-2010, 06:51 PM   #9
aferrari88
Member#: 174581
2010 Ferrari 458
Red
good data, but for comparing data over a period of time, line graphs ftw
aferrari88 is offline   Reply With Quote
Old 02-28-2010, 07:05 PM   #10
shikataganai
Member#: 92634
'07 LC, '12 RAV4 EV
'13 LEAF, for now
I agree, but at first glance I couldn't figure out how to use two different y-axes for line graphs in my old version of Excel.
Old 02-28-2010, 07:08 PM   #11
Abismo
Member#: 99707
Dont knock airbags up the wazoo till you have to use them...
You will be rather thankful for them saving your wazoo.
Abismo is offline   Reply With Quote
Old 02-28-2010, 07:34 PM   #12
shikataganai
Member#: 92634
'07 LC, '12 RAV4 EV
'13 LEAF, for now
My mention of their inclusion is not knocking them! I'm a big fan of tighter emissions controls and additional safety equipment, and am glad that there still exist options out there like my wife's Fit that let one get a safe, economical package without the truly extraneous fluff. Airbags aren't fluff, as I can personally attest:
Old 02-28-2010, 07:59 PM   #13
quentinberg007
Member#: 7887
It'd be interesting to see the performance as well. My 1.8L 1993 Impreza AWD was downright dangerous when trying to merge onto WV's 70mph interstates when things were a little crowded. I'm willing to bet that the 0-60 performance is significantly better than 20 years ago, even on the 4cyl models.
quentinberg007 is offline   Reply With Quote
Old 02-28-2010, 08:31 PM   #14
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
shikataganai, good work! A couple of things don't jive though. First, you're mixing engines in almost all vehicles (i.e. Mustang engine switched from 5.0L to 4.6L in 1995, Camry motor switched from 2.0L to 2.2L to 2.4L to 2.5L in 2010). Also, for even more interesting data, compare the ratings on the automatics. Almost 100% across the board the economy has improved, very drastically in some cases.
BOY is offline   Reply With Quote
Old 02-28-2010, 09:59 PM   #15
shikataganai
Member#: 92634
'07 LC, '12 RAV4 EV
'13 LEAF, for now
Yeah, things did change. All but the Mustang were base models, manual transmission, smallest engine offered.
Old 02-28-2010, 10:15 PM   #16
shikataganai
Member#: 92634
'07 LC, '12 RAV4 EV
'13 LEAF, for now
Not as easy to read but workable. Note the big step backwards of the 4.6L 1994 Mustang GT . Whoops, Fordů
Old 02-28-2010, 10:57 PM   #17
Tim-H
Member#: 65751
'10 VULVA
I think I could have used that power to weight chart in an argument a while ago. Thanks for putting them together. I don't know why some people have such a negative attitude about them, you can pick apart any set of data if you don't like it.
Arguments like "well they use different engines now than before" No ****, that's kind of the point. Although the cars have gotten heavier/bigger, it seems like some of the manufacturers have been able to keep the same efficiency by using different engine technologies and increasing aerodynamic efficiency.
Tim-H is offline   Reply With Quote
Old 02-28-2010, 11:04 PM   #18
SLegacy99
Member#: 117504
2015 WRX Limited
Lighting Red
Yeah, engines sizes could go down as well.
SLegacy99 is offline   Reply With Quote
Old 02-28-2010, 11:12 PM   #19
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
If you're going to compare data, the data must be comparable.
Old 02-28-2010, 11:38 PM   #20
4wdwrx
Member#: 72042
2002 WRX impreza
WRB "Blue Mammoth" Return
Nice data. It shows how technology has come a long way. Even though weight has gone up, due to safety and more equipment, fuel consumption has maintained and even decreased.
Yes a car would have even better gas mileage if it is made lighter, but in reality, no one is going to buy a 2010 Civic that has the features and safety of a 93 Civic. If you want a lighter civic, strip it out, or buy a old car, simple as that
4wdwrx is offline   Reply With Quote
Old 02-28-2010, 11:42 PM   #21
xHairyBuffalo
Member#: 239576
2010 463WHP
Stock 5-speed
Actually, the 4.6 modular came in 1996. '94 was still the 5.0
xHairyBuffalo is offline   Reply With Quote
Old 02-28-2010, 11:52 PM   #22
Tim-H
Member#: 65751
'10 VULVA
depends on what you're comparing. If you're comparing how car manufacturers have adapted to the added weight of their vehicles(which is what that chart does) it's just fine.
Old 03-01-2010, 12:52 AM   #23
SLegacy99
Member#: 117504
2015 WRX Limited
Lighting Red
Mmmmm, but we have also come to expect more out of our cars. 20 years ago the standard was to have your bread and butter 4 cylinder sedan hit 60 MPH in 9 to 10 seconds. Today we balk at the sedans that do it in more than 8 seconds. I can't believe the Impreza is only offered with the 2.5L. I like the option of the 170 model, however I think a 150 HP 2.2L geared toward efficiency would do well in today's market. And Im not sure why it was ever taken away from the Impreza.
And now we have cars like the Camry and Accord with 270 HP V6 options. Ok I understand the appeal of the V6, but these aren't supposed to be sports cars and I don't understand the need for that kind of power. However, the market has taken us there. No automaker is going to soley go backwards and sacrafice the competitive advantage. Will we have a 300 HP Camry in the next 5 years? God, I hope not.
Old 03-01-2010, 12:53 AM   #24
gagliano
Member#: 39541
2002 WRX & 2004 STI
WR Blue
All you can do with the data is what the OP originally stated about mpg increasing/maintaining while vehicle weight increased. Other's have posted wondering how they've adapted. For instance what makes the biggest difference? Is it engine efficiency or aerodynamics.
You can't compare how the manufacturers adapted because there are too many variables, which was BOY's point as well.
shikataganai, do you have data that covers a single model that kept the same size engine over several years? That would be an interesting one....
Old 03-01-2010, 12:56 AM   #25
SLegacy99
Member#: 117504
2015 WRX Limited
Lighting Red
The Subaru Legacy has been using the EJ25 for four generations now....
Finalists for the 2009 North American Car of the Year and Truck of the Year awards an AVANTI R5 Non-Subaru News & Rumors 1 12-20-2008 11:30 PM
What have been the best car names over the years? snvin Off-Topic 83 02-23-2007 10:52 PM
The de-musclification of muscle cars over the years SinisterMinister Off-Topic 42 09-26-2005 10:20 AM
North American Car and Truck of the Year Winners Announced Janq Off-Topic 5 01-19-2004 01:21 AM
Ugh.... Car and Truck of the year... SalKhan General Forum Archive 21 01-10-2001 09:50 AM
