Old 02-28-2010, 11:35 PM   #51
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
Originally Posted by LIQUIDSK8S View Post
Nice! I'm in for twin scroll developments. How would this compare to a VF37 converted to a PE1825?
the compressor wheel on the PE1825 flows to much air for the turbine wheel, there for choking off rather quickly
i ran a vf37 with a 20g wheel for a while, it had the same effect
seanathanq83 is offline   Reply With Quote
Old 03-03-2010, 08:16 PM   #52
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
But how does this turbo compare in power and response etc.
LIQUIDSK8S is online now   Reply With Quote
Old 03-03-2010, 08:22 PM   #53
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
on the subject of TS downpipes - AVO has a setup that's a cast upper section and a tube lower section. This way they can simply have the cast section in whatever country uses whatever pipe.
If you ask REALLY nice you can get them to bring in the cast upper sections to go with the pipe section. I did this a long long time ago for my TS setup, and they were very nice to work with on it.
-Clint
I'm on a horse.
Old 03-03-2010, 09:13 PM   #54
DigitalPunk
Member#: 124236
2006 WRX Built EJ257
Version 8 Twinscroll
-Clint
I'm on a horse.
i purchased such a unit from TiC. very nice piece an fits my usdm length catback. hot stuff.
DigitalPunk is offline   Reply With Quote
Old 03-04-2010, 02:30 PM   #55
mikeesingh
Member#: 30183
1996 GC8 STI
9.40@152mph, GT30 Billet
Default Blouch BB Twin scroll
Results in of new Blouch BB Twin scroll with Billet compressor wheel
465bhp and 450 ft lb torque on a Stock 2.0 Engine !!!!!
flywheel Bhp and Torque
peak boost was 25psi tailing to 23psi at top, WHP is arround 375bhp
mod list: Stock JDM 2.0 STI engine, Stock Twin scroll headers, Stock STI Top
Mount intercooler, CAI with intake pipe, modified injectors, exaust and E85 pump fuel
mikeesingh is offline   Reply With Quote
Old 03-04-2010, 02:35 PM   #56
mikeesingh
Member#: 30183
1996 GC8 STI
just to compare this what the Standard VF37 Twin Scroll turbo did also on Pump E85 fuel
flywheel BHP and Torque
WHP was 296bhp and it ran a 11.63 @ 115mph 1/4 mile on the stock vf37, cant wait to see what another 90bhp will do on strip
Old 03-04-2010, 02:37 PM   #57
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
Is this on your car? Where was this done at? Very interested
kayen is offline   Reply With Quote
Old 03-04-2010, 02:38 PM   #58
unclemat
Member#: 114530
2005 LGT 6MT wagon
Nuts. I am getting one.
unclemat is offline   Reply With Quote
Old 03-04-2010, 02:41 PM   #59
DigitalPunk
Member#: 124236
great numbers! this turbo is looking pretty hot
Old 03-04-2010, 02:42 PM   #60
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
looks like the Blouch actually makes more power quicker than the standard VF37 according to those graphs hmmm... So what are these going to cost?
Old 03-04-2010, 02:54 PM   #61
mikeesingh
Member#: 30183
1996 GC8 STI
This is my road car and was done at Scoobyclinic in the UK, who are the UK distributor for Blouch Turbo.
it doesnt look like its lost anything to the standard VF37 low down, being road tested tomorow, so will find out where it makes boost compared to stock vf37
i was told it will make more power with a front mount intercooler or more boost
but stoped at at 25-23psi for now due to being stock engine.
Old 03-04-2010, 03:04 PM   #62
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
So I take it Blouch decided to test these in the UK first? Do you know what the pricing is on the turbo?
I am interested to see the Road results! BTW the dyno looks great!
Old 03-04-2010, 04:16 PM   #63
atc5
Member#: 69264
05 LGT
if anyone is looking for a vf37 turbo for a conversion or an AVO twinscroll cast bellmouth, pm me. I have them for sale.
**END COMMERCIAL****
Blouch's TS results look great!
atc5 is offline   Reply With Quote
Old 03-04-2010, 05:48 PM   #64
BigRigger
Member#: 129969
2005 Sti
Silver/Black
I really want to see some dyno charts using 91-93oct not E85.
BigRigger is offline   Reply With Quote
Old 03-04-2010, 10:43 PM   #65
EJ20IMPREZAREX
Member#: 211628
2004 VF37 WRX
MPS BUILT EJ22
wow nice powerband
EJ20IMPREZAREX is offline   Reply With Quote
Old 03-05-2010, 12:04 PM   #66
ebo03
Member#: 111008
2011 LGT
SSM
+1. Unfortunately E85 isn't available everywhere.
ebo03 is offline   Reply With Quote
Old 03-05-2010, 01:45 PM   #67
mikeesingh
Member#: 30183
1996 GC8 STI
best to contact Blouch if your in the USA for pricing
got boost logs today of road test in 4th gear
1 bar 3100rpm, 1.5 bar 3500rpm and 1.7 bar 3700rpm
Old 03-05-2010, 01:50 PM   #68
mikeesingh
Member#: 30183
1996 GC8 STI
i will be getting another map for our SUL which similar to your 93 octane but wont be for a few weeks yet
Old 03-05-2010, 08:17 PM   #69
im2ninja4u
Member#: 183389
wow 24psi by 3700 rpm almost stock
im2ninja4u is offline   Reply With Quote
Old 03-06-2010, 01:56 PM   #70
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
mmmm this is looking very nice. Larger intercooler, meth, exhaust, intake etc and this will be just shy of 400whp on 93.......I need.
Old 03-06-2010, 03:53 PM   #71
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
mikee, the engine you tested this on had AVCS, correct?
Hyper is offline   Reply With Quote
Old 03-06-2010, 11:41 PM   #72
retsej
Member#: 135850
nice airtemps
retsej is offline   Reply With Quote
Old 03-07-2010, 03:25 AM   #73
BigRigger
Member#: 129969
2005 Sti
Silver/Black
Ok so heres what we got so far
Litchfield = Ball Bearing CHRA and a wide range of trims but $$$$$
Blouch = Ball Bearing CHRA, seems to be a machined out vf37 with larger wheels
GT Pumps = Journal Bearing CHRA , TD05-20G based
Moore Performance = Something in the works???
AVO = Too little, too late.
Old 03-07-2010, 06:52 PM   #74
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
really impressive so far, I wonder what it will do on a 2.5L . I only wish it was bigger
juanmedina is online now   Reply With Quote
Old 03-07-2010, 06:55 PM   #75
juanmedina
Member#: 133146
07 FPgreen 7.37@95
Just for comparison my VF39 hits 25psi by 3700 rpm on my 2.5L on E85 .
Juan wants TS
APS twin scroll rotated turbo kit TSR-70 who would buy it or not? 949 Factory 2.5L Turbo Powertrain 237 02-07-2010 12:16 PM
my new gp moto twin scroll rotated turbo! 06redsuby Factory 2.5L Turbo Powertrain 20 02-15-2008 12:30 AM
Twin Scroll BB Info needed . discopotato03 Factory 2.0L Turbo Powertrain 2 05-10-2007 11:41 AM
New APS twin-scroll BB rotated turbo FOR USDM STI's!!! keaniegenie Factory 2.5L Turbo Powertrain 191 01-10-2007 01:12 PM
Will the new STI use a twin-scroll IHI turbo? bsix STi Forum Archive 0 01-09-2003 01:54 PM
Message Board Statistics All times are GMT -4. The time now is 10:29 PM.
