Old 01-31-2010, 11:46 PM   #26
happs subi
Member#: 200288
2002 Impreza WRX
This is a great thread, has anyone noticed any difference?
happs subi is offline   Reply With Quote
Old 01-31-2010, 11:51 PM   #27
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
i would imagine a difference would be noticed only in long term and these "noticeable" differences would probably not be felt on the butt dyno but close inspection of countless before and after logs.
i think its more of a "piece of mind" mod.
scoobystas is offline   Reply With Quote
Old 02-01-2010, 08:46 AM   #28
S7un7
Member#: 181709
2004 WRX Stage II
This is a good idea. No need to empty a catch can. I don't know if I could shell out $300 for it though..
S7un7 is offline   Reply With Quote
Old 02-01-2010, 01:06 PM   #29
Jkonquer
Member#: 81058
05 impreza wrx sti
white/gold
any installs on sti? 04-05
Jkonquer is offline   Reply With Quote
Old 02-02-2010, 11:07 PM   #30
Twelvz
Member#: 11302
11 GT-R
10.x @130+
Group buy. $199.
Twelvz is offline   Reply With Quote
Old 02-03-2010, 08:19 AM   #31
Daishi00
Member#: 78952
2005 WRX
Which was closed a week ago
Daishi00 is offline   Reply With Quote
Old 02-06-2010, 02:06 PM   #32
fomaGT
Member#: 231047
I like this product. The price is too high for me.
fomaGT is offline   Reply With Quote
Old 02-06-2010, 04:37 PM   #33
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
If you don't want to pay MSRP, check our our dealers for a better price!
Justin
Old 02-07-2010, 09:43 PM   #34
Digitalfiend
Member#: 54823
2008 STI
Just thought I would add some pics of the install on my '08 STI. I also replaced my PCV valve at the same time (basically the whole Y- or T-connector and valve.) Interestingly enough, the line from the PCV valve to the intake manifold must have had water in it, which had frozen, because it was rock hard. I'm thinking of pulling that line and cleaning it out in-case some gunk formed. It was too f-ing cold today (-12C) to pull it off, plus it refused to budge when I did try, probably due to being frozen.
Anyhow (sorry for the dirty engine bay - long, cold, and salty winter):
On the '08 there isn't much room to run the lines to the AOS so I had to get creative and run the crankcase breather line underneath those other two lines. Worked out well, no kinking, etc.
Digitalfiend is offline   Reply With Quote
Old 02-07-2010, 11:05 PM   #35
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
Great write up... Now we just need 1 from someone w/ a FMIC set up
Old 02-08-2010, 01:37 AM   #36
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Think there is slight leak with mine as idle is a little rough. Guess using zip tie on every single fittings may not be such a bad idea like Digitalfiend did.
Old 02-08-2010, 02:04 AM   #37
Digitalfiend
Member#: 54823
2008 STI
Make sure you didn't accidentally unscrew one of the fittings from the AOS. I noticed that I did that to one of the fittings as I was fiddling with the hoses.
I was expecting a load of oil in the IC but there wasn't really any, just a little dribble. Last time there was quite a bit (compression test was fine) and the time before that it was clean.
My PCV valve was pretty non-functional when I replaced it today. I'm sure it was gummed up a bit from the cold but still, I'm glad I replaced it.
Old 02-16-2010, 03:41 PM   #38
brooklyngenius
Member#: 92841
2009 Bagged n Built
AWDTuning Stage 4.5 LGT
anybody done the install on a Legacy or 08+WRX???
brooklyngenius is offline   Reply With Quote
Old 02-18-2010, 02:19 PM   #39
9tiger
Member#: 211528
06 WRX STI
Just install the aos today, have one slight problem. The hose supplied seemed to small for the pcv port, I was only able to get about half inch of the hose onto the pcb port.
Were you guys able to get the hose on all the way or how did do this?
9tiger is offline   Reply With Quote
Old 02-19-2010, 12:02 AM   #40
teiva-boy
Member#: 22825
Does the center hex nut unscrew from the housing, or do you have to remove the hoses to unscrew the entire assembly when you need to add oil?
teiva-boy is offline   Reply With Quote
Old 02-19-2010, 01:30 AM   #41
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
The crankcase T is 1/2" and the hose is 1/2". The hose we include is heavy duty hose and sometimes it takes a bit of muscle to stretch the hose over the fittings. If you havent tried yet, put a little spit or water in the end of the hose before trying to get it on the fitting..that always helps.
yes you can remove only the center section...no need to remove any hoses.
Justin
Old 02-19-2010, 04:46 PM   #42
9tiger
Member#: 211528
06 WRX STI
Justin
I tried with some oil and still can't push it on any further, so I reused the stock hose with a 1/2 adapter to the supplied hose.
Thanks for the help anyways
Old 03-11-2010, 09:30 PM   #43
armyssoldierboy
Member#: 109424
06 AW STI
Twin Scroll HTA gt3076r
wow, I really like this aos. What's amazing though is how Barney style the install write up was and yet, people still ask questions. How bout yall stick your heads under your hood to look for the lines where numerous people have said.
Hey Grimm, being that most people seem to be orientating the nipples upward, have yall considered flipping the label/name around? Like this
armyssoldierboy is offline   Reply With Quote
Old 03-12-2010, 12:21 AM   #44
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
If anyone needs FMIC instructions, feel free to PM me.
Byzantium is offline   Reply With Quote
Old 03-12-2010, 08:08 PM   #45
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
I know this is the butt dyno or placebo, but my car feels better after I did this, however I did just change the plugs last week as well. So maybe a little bit of both. Could be the slightly warmer weather as well, as my car does not like the cold. It is probably just wishful thinking.
I like the product - only modification was an elbow that I used for the hose from the pcv.
Ernest is offline   Reply With Quote
Old 03-12-2010, 08:14 PM   #46
Byzantium
Member#: 207826
85k 2002 WRX
Ya, the only thing that didn't install pretty was ^ that one. It's awkwardly shoved between the 2 parts of my FMIC piping. Only other way was to let it rub on part of the throttle cable assembly and I wasn't comfortable with that.
Old 05-18-2010, 03:08 PM   #47
FlashEngineer
Member#: 183923
'08 EJ257
So one tube goes into the PCV?
FlashEngineer is offline   Reply With Quote
Old 05-18-2010, 03:51 PM   #48
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
This is a new one! My car doesn't like cold starts on cold mornings but once its all warmed up and ready to go, it loves the cold.
Anyone have more updates or maybe data logs post install?.
Maybe some one was able to add a degree of timing because the oil from the pvc system was no longer contaminating the fuel and so the AOS is acting as a good knock deterrent??
Old 05-18-2010, 03:58 PM   #49
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Double that, its too nice here in minnesota right now so if someone has this info that would be awesome to see.
Will
Old 05-18-2010, 05:34 PM   #50
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
How To Install: Perrin Cold Air Intake for 09 WRX Agile32wrx Interior & Exterior Modification 8 02-14-2010 01:12 PM
any reviews on the PROVA AOS air oil seperators? 949 Built Motor Discussion 0 07-26-2009 12:10 PM
How to install Tribeca (25mm) front sway bar on an 96 impreza brighton - pictures Ninja007 Brakes, Steering & Suspension 3 11-15-2008 09:37 AM
How to install SPT cold air intake??? Hybridz4eva Southern California Impreza Club Forum -- SCIC 20 05-11-2007 03:01 PM
