Old 03-22-2010, 02:32 PM   #1
dan240
Member#: 57969
2004 WRX
Default Resetting ECU before California Smog Test
Hello All,
I have a smog test coming up. I put my stock downpipe back on and removed my Cobb AP (revert to stock).
I have read that the ECU will need time to completely reset its self and be in a "ready" state. If I take it to be smogged before then I will fail when they plug into the OBDII port.
Is this true? How long does it take to reset? Can I speed up this process?
Thanks,
dan240 is offline   Reply With Quote
Old 03-22-2010, 03:01 PM   #2
the suicidal eggroll
Member#: 51961
2005 STi
Yes it's true
It takes a while to reset, at least 50+ miles or a few days of driving
I don't believe there's anything you can do to speed up the process
Old 03-22-2010, 03:03 PM   #3
fred.r
Member#: 204474
2002 Almost STi Wagn
RAW
From what the tech at my local dealer told me, you need to be between 1/4 empty and 1/4 full on fuel and drive it 60 miles for the ECU to set all the tables. FWIW.
fred.r is offline   Reply With Quote
Old 03-22-2010, 07:16 PM   #4
rkramer
Member#: 118209
2015 WRX Limitec
ODBII spec calls for a certain number of conditions to be set. (fuel level isn't one of them) Basically a couple full warm up/cool down cycles and some miles on the clock.
rkramer is offline   Reply With Quote
Old 03-22-2010, 07:22 PM   #5
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Originally Posted by dan240 View Post
Hello All,
Thanks,
If you find a person with a tactrix cable, you can have someone flash a map that forces all readiness codes.*
*Please check your state for legality issues
Jubert69 is offline   Reply With Quote
Old 03-22-2010, 07:45 PM   #6
timskyline86
Member#: 211913
:P (□)
(ಠ_ಠ)
I'm probably wrong, but I thought the AP copies and saves those stock values over before you switch maps.
OP how soon is your smog test? Cuz it sounds like your gonna need to put some miles under your belt.
Or you could lie and say you had maintenance done recently and it involved removing the battery. Maybe they will believe it....
timskyline86 is offline   Reply With Quote
Old 03-22-2010, 07:48 PM   #7
Member#: 230708
2002 02WRX STi Wagon
WRB, STi Hybrid swap 6spd
i have smogged a couple cars in the last year.. 97 honda prelude, 03 crown vic police intercepter and helped a friend smog a 300zx. The smog tech had me drive around town and back which was roughly 10-15 miles. He had me give it some heavy acceleration and slow cruising, and that reset the codes. Subarus may be different when it comes to mileage, but i would say 20 would be a good number to try if you were crunched for time.
ThaFlyinSoundman@aim is offline   Reply With Quote
Old 03-22-2010, 07:58 PM   #8
vusalterego
Member#: 198082
2009 tsx
forever dirty
vusalterego is offline   Reply With Quote
Old 03-22-2010, 08:07 PM   #9
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
I think a single 3rd or 4th gear pull should get a ready check from everything.
OUScooby is offline   Reply With Quote
Old 03-22-2010, 08:21 PM   #10
MannyMohawk#5
Member#: 98807
1999 RSTi
RHD BF5 & BJ6
It has nothing to do with fuel level, but 50-60 miles of city driving seems to always work for me.
MannyMohawk#5 is offline   Reply With Quote
Old 03-22-2010, 08:22 PM   #11
MannyMohawk#5
Member#: 98807
1999 RSTi
RHD BF5 & BJ6
It won't.
Old 10-04-2012, 01:41 AM   #12
UnknownAlly
Member#: 277330
2004 WRX
50 miles of city driving didnt work for me. Im now at 160 miles to be safe. Going to smog it tomorrow.
UnknownAlly is offline   Reply With Quote
Old 10-04-2012, 02:37 PM   #13
NOT_2_SLOW
Member#: 208817
2006 WRX TR Stg2++
While fuel levels don’t directly affect emissions they can affect emission components such as the "charcoal evap canister" Fuel tank must be between 3/4-1/2 tank IIRC before this systems properly registers.
NOT_2_SLOW is offline   Reply With Quote
Old 10-04-2012, 02:48 PM   #14
cmiovino
Member#: 134005
2004 WRX Premium
You need to take it on the highway for literally 2-3 minutes cursing above 40mph. It's another test that gets run. This has to be after 7 minutes of the car being on.. any time before that, it won't even start the test.
This tests for emissions. If you have a leak in the gas tank.. even a small one that won't pressurize the system, it throws a code. If you pass, another one of those damn 'ready' things gets checked off he ECU for emissions testing. It's one of about 7-8.
Old 10-04-2012, 02:59 PM   #15
radd269
Member#: 261241
2014 C63 AMG
you can also take it to a tuner; most tuners will reset the monitors for you for free
radd269 is offline   Reply With Quote
Old 10-12-2012, 05:38 PM   #16
UnknownAlly
Member#: 277330
2004 WRX
I passed the smog test with the bpv not bolted on all the way. The bolts came loose after hard driving.
Old 10-12-2012, 05:55 PM   #17
yankeesfan
Member#: 182065
so we are guessing now?
yankeesfan is offline   Reply With Quote
Old 10-13-2012, 02:27 AM   #18
TwinscrollGT35R
Member#: 256810
Reset the ecu and drive the car for a few days.
There is no single trick out there to speed up the ECU learning and get the monitors up quickly.
I flashed my truck back to stock and forgot about it and the smog tech asked when it failed why the monitors were not ready.. You need all but two up to pass. My quick thinking brought up that my 3000 watt sound system blew a fuse and killed the battery. He said oh no problem. Go drive it for a few days and said it could be from 50 to 200 miles.
I drove 70 miles and still not ready.. I ended up driving another 150 miles and they came up and I passed. But its all about key cycles, run time and ecu learning working together to get them to come up.
And as far as forcing them with a tune. The new smog computers in Ca scan for OEM map version numbers. They have been watching the tuning world for a few years now and have caught on.
Soon they will be failing people with reflashed ecus and requiring new ECU's that match the oem codes meaning they have not been flashed.
Just flash the car, Take a run to the mountains and by the time you get home it should be good to go the next day. Just make sure you stop a few times to shut the car off and turn it back on with at least 10-15 min between shut off and start up.
TwinscrollGT35R is offline   Reply With Quote
Old 10-13-2012, 10:08 AM   #19
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
Focal Active Setup
I didn't realize cursing was a requirement. Do I have to wait until 40mph to curse? Sometimes it slips out before I get to 30mph, depending who's in front of me on the merge ramp.
Ziggyrama is offline   Reply With Quote
california smog test? stickboie Subaru Conversions 19 10-12-2009 04:00 PM
will i pass the smog test in california? newerWRX Newbies & FAQs 14 04-08-2007 04:06 PM
Fail Smog Test after OBDII Reset truckresi Normally Aspirated Powertrain 9 07-30-2006 03:47 AM
Would the aftermarket FMIC fail the smog test in california. ix8vii Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 09-06-2005 03:17 PM
Smog/Reseting ECU question liigod Normally Aspirated Powertrain 5 07-11-2005 04:01 PM
