Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 03-30-2010, 04:16 PM   #1
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Default Element Tuning Time Attack STi 2 From a 148 MPH Crash To A New Track Record. Video
Just as we started to get the new car and myself sorted out our season is over but the new STi is performing better than we could have ever imagined.
New graphics from Speedesign look great. We wanted to do something new and different but keep that mean look the car had in all black. We couldn't finish completely as the vinyl wouldn't stick to the unfinished bumpers so we need to get those painted before the whole look is put together.
Rota DPT from WheelDude.com in 18x10 Matte Black hold the Hoosier 285s on very nicely!
New Sparco Circuit Pro Seats, Belts, and Steering wheel from OG Racing and Sparco USA keeping me safe.
One of the single largest and most critical improvements on the car is the Fulcrum Aero wing. Jim went above and beyond building us a reinforced with with improved double lap joint mounts.
Notice the heim joints for reduced stress on the mounts. The wing is also very easy to adjust because of this mount.
The final race of the NASA Mid Atlantic Championships was this past weekend at Summit Point Raceway. We updated our Element Tuning custom BC ER Series Coilovers with new valving and Swift Springs to increase front roll stiffness on the car in attempt to settle the rear end down under acceleration. We tested this at VIR warming up and ran a 1:59 which would have been good enough for 4th in the UTTC race so things were looking good.
On day one we set FTD breaking the old TTU lap record of 1:16.07 with a 1:15.4 lap but the cold track made it tough to get the heat I needed in my Hoosiers. On day two we tweaked the Fulcrum rear wing for about +45 lbs more downforce with only a 6 hp penalty in drag, dropped tire pressure on the driver's side, and we adjusted the front and rear clickers on the BC coilovers. With the track temp coming up we were able to set a new TTU track record at 1:14.439!
Enjoy the video, From a 148 MPH Crash To A New Track Record:
YouTube:
Pre Rebuild:
Starting the new Time Attack season we wanted to freshen up the engine and test a few new parts. We started out rebuilding an Element Tuning Pro Comp engine but we switch up the bearings and the compression ratio of the pistons to see how they hold up over a season of racing.
Numbers
Dyno: Dynojet Altered Atmosphere Gaithersburg, MD
Tuner: Phil Grabow Element Tuning
Wheel HP: 570whp UNCORRECTED
Wheel TQ: 492wtq UNCORRECTED
Baseline: 185 whp 08 WRX
Target Boost: 27 PSI
Target AFR: 11.8 AFR
Fuel: Sunoco 110 Octane with Hydramist (80% water)
Ambient Temp: 50
Elevation: 0
With a new engine I really didn’t want to run it too hard on the dyno so I stopped at 27 psi. I made quick work of the tuning with the Hydra 2.6 software and had all tweaked in as few WOT pulls as possible. In my previous dyno sessions the 1000cc fuel injectors were maxed out so this time around I bumped up the fuel pressure to 55 psi giving me about +20 more flow so I could have a little safety margin on the injector duty cycle. Maximum fuel injector duty cycle was 83% with the 1000cc, A1000 fuel pump, and 55 idle fuel pressure.
I totally forgot that I didn’t like the billet compressor wheel I ran late last year which netted me about 30 whp loss over our standard GT65 wheel (GT35R). With the higher compression and the BC STG 4 cams it looks like we gained back that loss however. The numbers are good for this dyno so I’m happy for now with the improvement.
Car Info
Year: 2006
Engine Management: Element Tuning Hydra EMS 2.6
Turbo: Element GT65 (testing new wheel)
Intercooler: Custom
Meth Kit: Hydramist 80/20 water/methanol
Injectors: UR 1000cc, Element Tuning Competition Surge Tan, Aeromotive A1000
Engine: Element Tuning Pro Comp: ET Rods, Manley 9.8:1 Pistons (custom ring pack), ET Big Valve Heads +1mm valves, BC STG4 cams, stock block and bore.
Intake Manifold: Subaru RS
Headers: Element
Uppipe: Element Tuning GT65
Downpipe: Element Tuning
CBE: Element Tuning
Other: Element Tuning Competition Catch Can
The BC ST4 cams required me to work on the AVCS mapping as compared to the Cosworth cams. I found that I had to carry the advance farther into the RPM range but in the end the Hydra EMS allowed me to get it exactly how I wanted it.
Having made some new changes to the car I wasn’t sure what the car would weigh in at so I had to have options available for HP so that I could stay in NASA TTU classification. At about 15.3 psi the car made 452 whp which should be low enough to keep me legal in that class.
With the new engine tuned we headed off to the second round of the NASA season at Virginia International Raceway. One of the major changes we made to the chassis was to have taller wing supports made so we could get the rear APR wing up into clean air in hopes of gaining down force. We also had added a rear diffuser to the flat panel underneath the car. After running at minimum power for practice and scrubbing in new tires the car felt great and the power delivery was awesome.
As we headed out for time session one disaster struck on the first lap! I was taking it easy to get the tires up to temperature but as I exited turn 6-7 the carbon wing structurally failed between the air foil and the mount. Not knowing this I entered the uphill esses at around 148 mph and this is what happened.
YouTube:
Thanks,
Phil Grabow
Element Tuning
Last edited by Element Tuning; 11-10-2010 at 01:16 PM. Reason: Updated results, pictures, and video
Element Tuning is offline   Reply With Quote
Old 03-30-2010, 04:22 PM   #2
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Ouch!
video doesn't work... Says it isn't available..
jigga is offline   Reply With Quote
Old 03-30-2010, 04:24 PM   #3
bgod
Member#: 100274
Awesome numbers on the tune.
But so sorry to see what the result was.
Glad you're okay. Hate to ask so early but what's the planned next step? Newer shell or a lighter shell?
bgod is offline   Reply With Quote
Old 03-30-2010, 04:33 PM   #4
midnight23
Member#: 204600
2013 Turbo BRZ
carbon fiber is indestructible 0.0
midnight23 is offline   Reply With Quote
Old 03-30-2010, 04:40 PM   #5
E85 WRX
Member#: 219412
amazing to walk away from something like that. that back end just came around like nothing.
E85 WRX is offline   Reply With Quote
Old 03-30-2010, 04:42 PM   #6
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
ohh my gosh phil....im glad you are ok...u were not kidding when you said the wing sent you sideways
rise up and come back stronger....good luck with the new build!!!
blowbyu24 is offline   Reply With Quote
Old 03-30-2010, 04:45 PM   #7
Element Tuning
Member#: 54918
673 WHP Element
Sorry the video is still being processed by Youtube.
Old 03-30-2010, 04:51 PM   #8
STi-MAN
Member#: 70252
05 STI
blue
phil, just wonder what happened on that turn left turn? did you let off?
STi-MAN is offline   Reply With Quote
Old 03-30-2010, 05:00 PM   #9
nhat
Member#: 140163
03 STi
hellaflunctional
good to see you walked away from the wreck!
come to a DFH meet sometime and i'll buy you a beer or two
nhat is offline   Reply With Quote
Old 03-30-2010, 05:15 PM   #10
CosworthSTI77
Member#: 195473
2007 STI
Phil THANK GOD you are OK ! I do believe that roll cage saved you, I am looking for one right NOW !!
CosworthSTI77 is offline   Reply With Quote
Old 03-30-2010, 05:16 PM   #11
jordanretro1223
Member#: 143039
2007 STI
Glad you are ok Phil. That looked like some crash.
jordanretro1223 is offline   Reply With Quote
Old 03-30-2010, 05:16 PM   #12
Element Tuning
Member#: 54918
673 WHP Element
Yeah I always ease up entering there until I'm going for my fast lap where I stay just about WOT until you head back to the right. I was still on my warm up lap taking it easy.
When the wing broke off I had way too much front downforce and no rear downforce and as I clipped the inside curbing on the left it just went up and around.
Old 03-30-2010, 05:22 PM   #13
MSP608
Member#: 149631
ST-3 STi
2.3L Evo
Still can't believe you only suffered a bruised arm from this. Glad you're okay and already picked up that shell.
MSP608 is offline   Reply With Quote
Old 03-30-2010, 05:24 PM   #14
[D.I.]WRX
Member#: 116314
WOW...glad to see you're doing ok!
[D.I.]WRX is offline   Reply With Quote
Old 03-30-2010, 05:25 PM   #15
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Wow... glad you're ok. Saw you tightening your harness belts right before the crash too!
Old 03-30-2010, 05:29 PM   #16
1_STi_2NV
Member#: 197567
Damn that sucks....THANK GOD your ok
that cf looks like it didn't got damage
1_STi_2NV is offline   Reply With Quote
Old 03-30-2010, 05:32 PM   #17
bertune
Member#: 107290
Damn Phil Glad to see you are OK! Your pocket is going to feel it more than your arm. Damn!
bertune is offline   Reply With Quote
Old 03-30-2010, 05:32 PM   #18
02WRX2.5
Member#: 63192
02 wrx
161mph Trapspeeds
wow hate to see the car in this state, glad to see you came thru it alright.
02WRX2.5 is offline   Reply With Quote
Old 03-30-2010, 05:39 PM   #19
mpsti05
Member#: 86741
05 STi.. Built
twinscroll35r Love/Hate
Damn man glad your ok! and WOW at the wing blowing right off!
mpsti05 is offline   Reply With Quote
Old 03-30-2010, 05:46 PM   #20
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Glad to see you weren't hurt bad phil! That was just nuts how it happened, at least you didn't roll 40 times.
Just goes to show how much wings really do for aero and keeping things to the pavement.
project_skyline is offline   Reply With Quote
Old 03-30-2010, 05:51 PM   #21
xsblack
Member#: 26530
2004 Sti
JBP
Wow that was a serious impact, glad to see you walked away. Good luck with whatever is next
xsblack is offline   Reply With Quote
Old 03-30-2010, 06:04 PM   #22
DJSuperSoul
Member#: 120004
2xx8 STI
grey
I am sure you always have someone else tighten your harness for you! hope your wrists come out okay in the next weeks. that was a hard hit to break the steering wheel.
time to look at a better wing solution? is there one?
DJSuperSoul is offline   Reply With Quote
Old 03-30-2010, 06:25 PM   #23
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
holy ****! all these subies biting the dust @ the track lately...
wrxtremeWGN is offline   Reply With Quote
Old 03-30-2010, 06:26 PM   #24
rallyracersti
Member#: 147522
2015 wrx
Wrb
thats insane.glad to see the cage did its job.
rallyracersti is offline   Reply With Quote
Old 03-30-2010, 06:53 PM   #25
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
I know i already told you but glad your ok!
Glad you were smart enough to let go of the steering wheel when you did!!!
Md05STI is offline   Reply With Quote
Element Tuning GT65 Bolt On Turbo, Hydra EMS, E85 fuel, 532whp, 07 STI 2.5 Element Tuning Proven Power Bragging 10 05-18-2010 10:21 PM
Element Tuning Time Attack STI- From Grassroots Motorsports GrassrootsMotorsports NASIOC Official News, Articles and Polls 43 05-03-2010 03:28 PM
Element Tuning Time Attack Race Car Wallpaper WorldOne Member's Car Gallery 18 04-21-2007 06:41 PM
Element Tuning Time Attack Car at Subiefest WorldOne Member's Car Gallery 47 02-25-2007 12:46 PM
Element Tuning Time Attack Project Element Tuning Member's Car Gallery 55 11-03-2004 12:18 PM
