#1 |
Member#: 13617
Vehicle:2001 Legacy GT back to stock is a project too |
Hey Everyone,
This is for anyone that has any experience with manufacturing or that has looked into it. I am curious the process and average cost per part on something like an intercooler endtank or an intercooler tube. If my dreams are ever realized(and depending on costs) I would need a couple things cast and possibly a few things injection molded if possible. This would be on a larger scale but not huge, I'm thinking 20 per part. I know casting requires a mold, and I should be able to model the part in SolidWorks myself and hopefully create a mold from that. Would it be a matter of modeling the mold then having it CNC'd and then casting? If I take care of the modeling/engineering portion anyone have an estimated cost of the creation of the mold and casting? Secondly one thing I may have to do is a fairly organic shape not easily made by cutting/shaping tubing. In the attempts to make things as OEM quality as possible and ease of reproduction I am wondering about making resin based parts similar to the intake manifolds on the Legacy GT's and newer WRX's. Again I can likely model this in SolidWorks myself but I am not familiar with how complicated it is to get this created. Any thoughts on cost and process related would be much appreciated. Yes I have the ability to custom fabricate as well and my intent on doing this is to hopefully make the parts very consistent and high quality. Thanks for the help! Ben
#2 |
Member#: 81659
Vehicle:2010 Fozzy XT Ice Silver Metallic |
Id contact AMS they cast quite a few parts.
#3 | |
Member#: 101117
Vehicle:2009 WRX 5 door Blue |
One part might only cost you $500 to $1,000, far cheaper than trying to amortize a mold which could be hundreds of thousands. Castings vary depending on material and shape but you need patterns, machining after casting, must specify the alloys, etc etc. If you have a BSME you probably learned all you need, you just have to remember it. |
#4 |
Member#: 13617
#5 |
Member#: 198711
International
Vehicle:1989 MV Brumby TC White |
A friend and I had 50 Twin Weber manifolds made 20 years ago,back then it cost us $250.00 for the wooden patterns and the Foundry charged out at $50.00 for 1~10 units ,$35.00 for 50 units and if we wanted a run of 200 it would drop to $22.50 each.
We did all the finish machining ourselves. Quality manifolds back then sold for $180.00 to $250.00 each. People forget there are options other than CADCAE or CNC as it is more commonly called. |
#6 | |
Member#: 101117
CAE = Computer-Aided Analysis - not discussed here. CNC = Computer Numerical Control [machining] which is done with CAM software to generate the machine instructions. Try and find a pattern maker today to make you a manifold pattern for $250. In the meantime, if you have the CAD file we can make a plastic pattern overnight in a DDM machine. |
#7 |
Member#: 13617
Garandman, PM'd you.
If anyone else has other info as well that would be great. Thanks! Ben |
#8 |
Member#: 136945
Vehicle:2005 WRX/CRX/LGT Obs. Black |
Look up companys that sell/and have support for CAD/CAM systems like MasterCAM...most of these places have rapid prototype machines.
If you have a part drawing or even just a rough sketch someone should be able to help you. Once you have a prototype and can actually fit it and make any changes then seek out a casting place. |
#9 | |
Member#: 101117
A rough sketch or drawing doesn't help anyone: a 3D CAD file will help everyone. In Solidworks select File - Save-As and selecte .STL. That is the format used by RP machines. |
| Thread Tools | |
| Display Modes | |
| FS:IL bunch of aftermarket STI parts (make me offers) | Jasoncor | Engine/Power/Exhaust | 96 | 08-04-2010 07:38 PM |
| Cost of coating exhaust parts | me_and_my_wrx | General Community | 1 | 08-16-2004 06:27 PM |
| Cost of repainted parts? | Speed Revelation | Interior & Exterior Modification | 1 | 05-02-2003 07:32 AM |
| Cost of custom muffler installs on a WRX | Narcisse91 | Factory 2.0L Turbo Powertrain | 7 | 07-11-2002 11:01 AM |
